11-20-2016, 08:39 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | samsung j100h emmc repaire done with jtag Samsung j100h Dead Recover With Easy Jtag You See Here Chunk Error But Now Handset Go In Download Mode And Flash With Odin Now Set Working Fine Sucessfully Dead Boot Recovered |
The Following 18 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-29-2016, 06:08 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | kindly share the file you used pls. btw, useful info. |
The Following 3 Users Say Thank You to bronce For This Useful Post: |
12-03-2016, 17:04 | #5 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2656356 Status: Offline Thanks Meter: 3 | Hello, My friend bring his SM-J100h/DS to me asking for repair. it was stuck on boot so i tried to Wipe Data / Factory Reset, but there were many errors, something like "E: can't mount....." After that, i flashed it with ODIN 3.09 + the latest firmware (September 29, 2016 based on my country code) The flash was successful and PASS 100%.. but still stuck on boot logo. so, i found a video on Youtube about this.. i did everything exactly the same: ROM => J100H_XXU0AOA1_OXE0AOA1 (contain files as shown below) BL => BL_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship AP => AP_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship CP => CP_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship CSC => CSC_OXE_J100HOXE0AOA1_CL333157_QB3542504_REV01_use r_low_ship PIT => J13G (Repartition) The flash once again PASS 100% and the device rebooted automatically but NO POWER. It is completely DEAD now. i removed the Battery, put it on again, still cannot be powered on. i plugged in the USB charging cable, still no power, no charging indicator. It's now completely dead. What shall i do now? Somebody please help me.. i'm a dead man now.. Many thanks in advance |
The Following 3 Users Say Thank You to kimdonghwan For This Useful Post: |
12-03-2016, 17:16 | #6 (permalink) | |
Freak Poster Join Date: May 2007
Member: 507911 Status: Offline Thanks Meter: 22 | Quote:
The Following 2 Users Say Thank You to juwana_pati For This Useful Post: |
12-16-2016, 14:18 | #8 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | Samsung J100H/DS Boot Repair Pinout / Dead Boot Repair File Samsung J100H/DS Boot Repair Pinout / Dead Boot Repair File Code: Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: , ,FW Ver.: 01.55 CMD Pullup Level:2031 mV CMD Active Level:2371 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004E4A325A4D42009E73B45192AC EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2015 Rev.0x0 EMMC NAME: NJ2ZMB , S/N: 2658382929 EMMC NAME (HEX): 4E4A325A4D4200 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: NJ2ZMB_2658382929_20161009_1201.extcsd Done. Z3X EasyJtag Software ver. 2.4.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2371 mV Input file : E:\JTAG\Z3X Easy-JTAG\J100H\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing 0040000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 941 kB/s Br Suny125 |
The Following 8 Users Say Thank You to Suny125 For This Useful Post: |
01-15-2017, 19:42 | #10 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | this phone hynix emmc you just lucky repair this emmc ... for 100% repair you change it to samsung i solved many time with kmnjs/kmn5x/kmkjs or you can used mercedes emmc kmi8 to make it 1gb ram / 16 gb storage back up extcd rom1 512 rom2 rom3 . then write it to new emmc the flash it with 4 files (dont use pit or phone will random error ) -- done |
The Following 4 Users Say Thank You to bagus.dps For This Useful Post: |
02-26-2017, 10:59 | #11 (permalink) |
Freak Poster Join Date: May 2008 Location: IN Age: 36
Member: 768205 Status: Offline Thanks Meter: 45 | SM-J100H Partitioning not detected... SM-J100H DEAD AFTER FLAH Partitioning not detected... ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473262110104412CD0222C EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 71380176 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _ 71380176_20170226_1439.extcsd Searching for partition tables... Partitioning not detected... Done. |
The Following 3 Users Say Thank You to ramrajbhopal For This Useful Post: |
02-26-2017, 21:16 | #12 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi as i see in your log ,Your phone is SPD based CPU I have no idea about this model but i think SPD no show Partitions like MTK Anyway Please Write Pit+latest BL via Easy Plus |
The Following 6 Users Say Thank You to BABAK NURI For This Useful Post: |
02-27-2017, 00:30 | #14 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | no u r wrong i done many j1 Code: ---------- eMMC Device Information ----------EMMC CID : 90014A48344732621101C66824096218 EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 06/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 3328713737 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _3328713737_20160823_1755.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (SBOOT) Range: [0X400000,0X5FFE00] ,Len: 200000 MMCBLK0P1 (SBOOT2) Range: [0X600000,0X7FFE00] ,Len: 200000 MMCBLK0P2 (WFIXNV1) Range: [0X800000,0X8FFE00] ,Len: 100000 MMCBLK0P3 (WFIXNV2) Range: [0X900000,0X9FFE00] ,Len: 100000 MMCBLK0P4 (TDFIXNV1) Range: [0XA00000,0XAFFE00] ,Len: 100000 MMCBLK0P5 (TDFIXNV2) Range: [0XB00000,0XBFFE00] ,Len: 100000 MMCBLK0P6 (WDSP) Range: [0XC00000,0XFFFE00] ,Len: 400000 MMCBLK0P7 (MODEM) Range: [0X1000000,0X17FFE00] ,Len: 800000 MMCBLK0P8 (MODEM2) Range: [0X1800000,0X1FFFE00] ,Len: 800000 MMCBLK0P9 (TDDSP) Range: [0X2000000,0X23FFE00] ,Len: 400000 MMCBLK0P10 (FOTA_SIG) Range: [0X2400000,0X24FFE00] ,Len: 100000 MMCBLK0P11 (WRUNTIMENV1) Range: [0X2500000,0X25FFE00] ,Len: 100000 MMCBLK0P12 (WRUNTIMENV2) Range: [0X2600000,0X26FFE00] ,Len: 100000 MMCBLK0P13 (TDRUNTIMENV1) Range: [0X2700000,0X27FFE00] ,Len: 100000 MMCBLK0P14 (TDRUNTIMENV2) Range: [0X2800000,0X28FFE00] ,Len: 100000 MMCBLK0P15 (PARAM) Range: [0X2900000,0X2AFFE00] ,Len: 200000 MMCBLK0P16 (EFS) Range: [0X2B00000,0X3EFFE00] ,Len: 1400000 MMCBLK0P17 (PRODNV) Range: [0X3F00000,0X43FFE00] ,Len: 500000 MMCBLK0P18 (RESERVED2) Range: [0X4400000,0X44FFE00] ,Len: 100000 MMCBLK0P19 (KERNEL) Range: [0X4500000,0X54FFE00] ,Len: 1000000 MMCBLK0P20 (RECOVERY) Range: [0X5500000,0X64FFE00] ,Len: 1000000 MMCBLK0P21 (CSC) Range: [0X6500000,0X12CFFE00] ,Len: C800000 MMCBLK0P22 (SYSTEM) Range: [0X12D00000,0X53CFFE00] ,Len: 41000000 MMCBLK0P23 (HIDDEN) Range: [0X53D00000,0X564FFE00] ,Len: 2800000 MMCBLK0P24 (USERDATA) Range: [0X56500000,0XE80FFE00] ,Len: 91C00000 Done...Presets has been updated... Done. |
The Following User Says Thank You to anasshe For This Useful Post: |
