12-03-2017, 07:03 | #1 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | j100ml jtag done but still dead Quote:
tried 2 times. 1st time is with system, after all done, i check emmc in easy jtag, it said Get firmware version Firmware info not found so i try to power phone but no luck,. then i try write again. the logs is at the top. no error i see. but still dead. any suggestions? | |
12-05-2017, 06:57 | #3 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Soul Society
Member: 2669319 Status: Offline Thanks Meter: 421 | Operation: Write by vendor (Samsung) Creating GPT-partitioninig Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Writing PIT at address: 000000080000 GPT-partitioning done => Resolder First then use this dump File. Make Sure also that you enhance user data area. Good Luck |
The Following 2 Users Say Thank You to Taguro-GSMLover For This Useful Post: |
12-06-2017, 23:30 | #4 (permalink) |
Junior Member Join Date: Dec 2017 Location: iran-sari
Member: 2786231 Status: Offline Thanks Meter: 6 | hi i think this is your problem why your phone is dead becuse your emmc can be damaged or have bad sector please read this Creating GPT-partitioninig Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Writing PIT at address: 000000080000 GPT-partitioning done you have problem is writing at start pit partation if you dont get any answer you need to change emmc |
12-21-2017, 01:57 | #5 (permalink) |
No Life Poster Join Date: Dec 2014 Location: u.a.e
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | emmc size 4g user data 3728 problem is in first emmc size you can't write pit file cut first 8 mb from your emmc user data 3720 your phone will back to alive Sent from my SM-G900F using Tapatalk Last edited by mojahed.br; 12-21-2017 at 02:04. |
12-21-2017, 04:04 | #6 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | Quote:
or a 500gb hardrive of your computer is it exactly 500gb in your computer? btw ts mostly its emmc fault, if like that i read 1st 512mb userdata,boot1,boot2 and ext_sd set write_rel_user write all back-up in case still cannot on dl latest firm and pit file use Direct eMMC Samsung Flasher leave it blank the system and userdata for saving time this is not totaly solution if youre lucky can use for couple of month sometimes hanging after 5-8 application bootloop already the best solution is change new emmc | |
12-21-2017, 13:28 | #7 (permalink) |
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | from first write gpt is wrong after that emmc is ok Creating GPT-partitioninig Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Writing PIT at address: 000000080000 GPT-partitioning done Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 759.55 Kb/s see first not all rom1 ((user area)) is bad cut first 8 mb from user area if you don't know you can learn open your main and think if you have 500gb hard desk you can repartion to 250gb,250gb like c,d and you can install windows in d if bad sector in c section Sent from my SM-G900F using Tapatalk Last edited by mojahed.br; 12-21-2017 at 14:03. |
The Following User Says Thank You to mojahed.br For This Useful Post: |
12-23-2017, 05:31 | #8 (permalink) |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | it's' emmc fault. even if i write anything, when i check emmc, there is no pit or firmware installed. so i guess, emmc is not writable anymore. |
