02-12-2018, 04:45 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | j110h ds still dead after write all roms i need to know what steps needed to revive j110h as there is no manual or any posts about anyone doing anything on j110h with easy jtag that is success. so please i need manual or instructions on how or what to do with this kind of phones. here is logs : Code: Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x10 Power ReadOnly locking: possible Permanent ReadOnly locking: not possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Found Data areas (firmware parts) count is: 26 Partition info successfully found --------------------------------------------- P0 (SBOOT) [0x400000 0x200000] Size: 2.0MB P1 (SBOOT2) [0x600000 0x200000] Size: 2.0MB P2 (WFIXNV1) [0x800000 0x100000] Size: 1.0MB P3 (WFIXNV2) [0x900000 0x100000] Size: 1.0MB P4 (TDFIXNV1) [0xa00000 0x100000] Size: 1.0MB P5 (TDFIXNV2) [0xb00000 0x100000] Size: 1.0MB P6 (WDSP) [0xc00000 0x400000] Size: 4.0MB P7 (MODEM) [0x1000000 0x800000] Size: 8.0MB P8 (MODEM2) [0x1800000 0x800000] Size: 8.0MB P9 (TDDSP) [0x2000000 0x400000] Size: 4.0MB P10 (FOTA_SIG) [0x2400000 0x100000] Size: 1.0MB P11 (WRUNTIMENV1) [0x2500000 0x100000] Size: 1.0MB P12 (WRUNTIMENV2) [0x2600000 0x100000] Size: 1.0MB P13 (TDRUNTIMENV1) [0x2700000 0x100000] Size: 1.0MB P14 (TDRUNTIMENV2) [0x2800000 0x100000] Size: 1.0MB P15 (PARAM) [0x2900000 0x200000] Size: 2.0MB P16 (EFS) [0x2b00000 0x1400000] Size: 20.0MB P17 (PRODNV) [0x3f00000 0x500000] Size: 5.0MB P18 (RESERVED2) [0x4400000 0x100000] Size: 1.0MB P19 (KERNEL) [0x4500000 0x1000000] Size: 16.0MB P20 (RECOVERY) [0x5500000 0x1000000] Size: 16.0MB P21 (PERSDATA) [0x6500000 0x900000] Size: 9.0MB P22 (CSC) [0x6e00000 0xc800000] Size: 200.0MB P23 (SYSTEM) [0x13600000 0x40600000] Size: 1.5GB P24 (HIDDEN) [0x53c00000 0x3a00000] Size: 58.0MB P25 (USERDATA) [0x57600000 0x90c00000] Size: 2.261GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0013600000 (1.5GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Done. Running:Repair extCSD... Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:3176 mV CMD Active Level:3269 mV Box IO Level:3300 mV CLK Rate:7000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0] Power off notification [POWER_OFF_LONG_TIME: 0x50] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.5 Done. Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:3176 mV CMD Active Level:3269 mV Length limit is enabled! Input file : C:\Users\Leahophiambershankz\Desktop\JTAG FULL DUMP\SM-J110h by Kiro\SAMSUNG_SM-J110H_emmc_direct_dump_320MB\EXT_CSD.BIN Writing 0000000200 bytes to 0000000000... ROM1 (USER ROM) Retry writing address 0x0000000000 (Attempt #0)... Retry Success! Done, time taken: 5 sec. Average Write Speed: 0 kB/s Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:3176 mV CMD Active Level:3269 mV Input file : C:\Users\Leahophiambershankz\Desktop\JTAG FULL DUMP\SM-J110h by Kiro\SAMSUNG_SM-J110H_emmc_direct_dump_320MB\Samsung_SM-J110H_emmc_dump_ROM2.BIN Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 6 sec. Average Write Speed: 624 kB/s Z3X EasyJtag Software ver. 2.9.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:3176 mV CMD Active Level:3269 mV Input file : C:\Users\Leahophiambershankz\Desktop\JTAG FULL DUMP\SM-J110h by Kiro\SAMSUNG_SM-J110H_emmc_direct_dump_320MB\Samsung_SM-J110H_emmc_dump_ROM3.BIN Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done, time taken: 6 sec. Average Write Speed: 627 kB/s |
02-12-2018, 06:42 | #2 (permalink) |
Insane Poster Join Date: Sep 2015
Member: 2459405 Status: Offline Thanks Meter: 17 | 1. Detect emmc 2. Factory format 3. Hardware partition 4. Disconnect all line or remove adapter and z3x box 5.Open easy jtag plus 6. Write full dump by kiro.. Sundan mo lang maigi yan kabayan..GOODLUCK |
The Following User Says Thank You to mgc03 For This Useful Post: |
02-12-2018, 08:20 | #3 (permalink) | |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | Quote:
4. disconnect 5. open easy jtag 6. write full dump how will i write? via usb? | |
02-12-2018, 09:15 | #4 (permalink) | |
Member: 2459405 Status: Offline Thanks Meter: 17 | Quote:
write dump by kiro using easy jtag plus bro Last edited by mgc03; 02-12-2018 at 09:20. | |
