02-24-2018, 08:07 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 640052 Status: Offline Thanks Meter: 66 | j200f how to repair damage GPT? please guide me to repair damage GPT after write rom still not go to download mode Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: F, ,FW Ver.: 01.62 CMD Pullup Level:484 mV CMD Active Level:2330 mV Box IO Level:3300 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A4838473474920123A66D2F63AA EMMC CSD : D02701320F5903FFFFFFFFE78A40002A EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 06/2016 Rev.0x1 EMMC NAME: H8G4t , S/N: 598109487 EMMC NAME (HEX): 48384734742000 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4t _ 598109487_20180224_1501.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 15269854 Found Data areas (firmware parts) count is: 23 Partition info successfully found --------------------------------------------- P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x400000] Size: 4.0MB P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB P3 (CPEFS) [0x2000000 0x800000] Size: 8.0MB P4 (M9KEFS1) [0x2800000 0x400000] Size: 4.0MB P5 (M9KEFS2) [0x2c00000 0x400000] Size: 4.0MB P6 (M9KEFS3) [0x3000000 0x400000] Size: 4.0MB P7 (CARRIER) [0x3400000 0x400000] Size: 4.0MB P8 (PARAM) [0x3800000 0x800000] Size: 8.0MB P9 (BOOT) [0x4000000 0xd00000] Size: 13.0MB P10 (RECOVERY) [0x4d00000 0xf00000] Size: 15.0MB P11 (OTA) [0x5c00000 0x800000] Size: 8.0MB P12 (CDMA-RADIO) [0x6400000 0x400000] Size: 4.0MB P13 (RADIO) [0x6800000 0x2800000] Size: 40.0MB P14 (TOMBSTONES) [0x9000000 0x400000] Size: 4.0MB P15 (TDATA) [0x9400000 0x400000] Size: 4.0MB P16 (PERSISTENT) [0x9800000 0x100000] Size: 1.0MB P17 (PERSDATA) [0x9900000 0xc00000] Size: 12.0MB P18 (RESERVED2) [0xa500000 0x300000] Size: 3.0MB P19 (SYSTEM) [0xa800000 0x90000000] Size: 2.250GB P20 (CACHE) [0x9a800000 0xc800000] Size: 200.0MB P21 (HIDDEN) [0xa7000000 0x2800000] Size: 40.0MB P22 (USERDATA) [0xa9800000 0x128400000] Size: 4.628GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000A800000 (2.250GB) --------------------------------------------- Done. |
02-28-2018, 09:38 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
