08-07-2018, 13:39 | #1 (permalink) |
Crazy Poster Join Date: Dec 2014 Location: Walling,syangja,nepal
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | j200g emmc dead how to recover Code: Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0100C01CD5DD0243, ,FW Ver.: 01.62 CMD Pullup Level:608 mV CMD Active Level:2093 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 150100464E313241420018D6D46A1454 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2017 Rev.0x0 EMMC NAME: FN12AB , S/N: 416732266 EMMC NAME (HEX): 464E3132414200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: FN12AB_ 416732266_20180807_1816.extcsd mmc_read_blocks(0x0 , 1 ), Reason: CMD CRC Error mmc_read_blocks(0x1 , 1 ), Reason: CMD Ready Timeout Error [Box Internal Failure] mmc_read_blocks(0xE8FFFF , 1 ), Reason: CMD Ready Timeout Error [Box Internal Failure] Partition table scan: GPT: not present Done. |
08-07-2018, 17:28 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | 1) Download and use last version of Software 2) Read SMART, if lifetime over 60-80% - eMMC is need to change 3) Use EasyJTAG_emmc_plus_1.5.2 software to write bootloader (Write by Vendor - Samsung). Use 4files latest Samsung original firmware, select BL, flash it |
The Following 2 Users Say Thank You to layder For This Useful Post: |
