12-03-2018, 14:23 | #1 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2874213 Status: Offline Thanks Meter: 9 | sm-j600f pinout opration successful CMD Pullup Level: 928 mV CMD Active Level: 1959 mV EMMC Device Information : EMMC CID: 150100424A5444345200DE0FFE764554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: DE0FFE76 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_DE0FFE76_20181203_155843.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: NAD_REFER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: DTBO, [000008300000 - 000008500000], size: 000000200000 (2.00 MB) Partition: RADIO, [000008500000 - 00000DD00000], size: 000005800000 (88.0 MB) Partition: PERSISTENT, [00000DD00000 - 00000DD80000], size: 000000080000 (512. KB) Partition: MISC, [00000DD80000 - 00000DE80000], size: 000000100000 (1.00 MB) Partition: STEADY, [00000DE80000 - 00000E280000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB) Partition: SYSTEM, [00000E800000 - 0000FC000000], size: 0000ED800000 (3.71 GB) Partition: VENDOR, [0000FC000000 - 000115000000], size: 000019000000 (400. MB) Partition: ODM, [000115000000 - 000130800000], size: 00001B800000 (440. MB) Partition: CACHE, [000130800000 - 000143400000], size: 000012C00000 (300. MB) Partition: HIDDEN, [000143400000 - 000143E00000], size: 000000A00000 (10.0 MB) Partition: OMR, [000143E00000 - 000145200000], size: 000001400000 (20.0 MB) Partition: CP_DEBUG, [000145200000 - 000145700000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [000145700000 - 000146B00000], size: 000001400000 (20.0 MB) Partition: USERDATA, [000146B00000 - 000747700000], size: 000600C00000 (24.0 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J600F CPU Abi = armeabi-v7a Android release = 8.0.0 Firmware version = R16NW.J600FXXU1ARE2 Firmware date = Wed May 2 20:46:30 KST 2018 Setting frequence to 21 Mhz CMD Pullup Level: 917 mV CMD Active Level: 1949 mV EMMC Device Information : EMMC CID: 150100424A5444345200DE0FFE764554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: DE0FFE76 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_DE0FFE76_20181203_155902.extcsd EMMC Init completed. Operation 'Remove FRP' Searching GPT ... GPT header is found and is valid FRP partition found (partname: PERSISTENT) Erasing FRP partition ... Done erasing partition. All done Setting frequence to 21 Mhz CMD Pullup Level: 928 mV CMD Active Level: 1949 mV EMMC Device Information : EMMC CID: 150100424A5444345200DE0FFE764554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: DE0FFE76 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_DE0FFE76_20181203_160232.extcsd EMMC Init completed. Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: bootloader_rom2 Address: 000000000000, size: 000000400000 eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 961.08 Kb/s Partition name: BOTA0 Address: 000000400000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.96 Kb/s Partition name: BOTA1 Address: 000000800000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.88 Kb/s Partition name: EFS Address: 000000C00000, size: 000001400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1065.81 Kb/s Partition name: CPEFS Address: 000002000000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1066.65 Kb/s Partition name: m9kefs1 Address: 000002800000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.27 Kb/s Partition name: m9kefs2 Address: 000002C00000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.68 Kb/s Partition name: m9kefs3 Address: 000003000000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.55 Kb/s Partition name: NAD_REFER Address: 000003400000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1067.95 Kb/s Partition name: PARAM Address: 000003500000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.28 Kb/s Partition name: BOOT Address: 000003D00000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1063.66 Kb/s Partition name: RECOVERY Address: 000005D00000, size: 000002600000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1064.11 Kb/s Partition name: DTBO Address: 000008300000, size: 000000200000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1069.17 Kb/s Partition name: RADIO Address: 000008500000, size: 000005800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1067.52 Kb/s Partition name: PERSISTENT Address: 00000DD00000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.22 Kb/s Partition name: MISC Address: 00000DD80000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1067.57 Kb/s Partition name: STEADY Address: 00000DE80000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.19 Kb/s Partition name: RESERVED2 Address: 00000E280000, size: 000000580000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1068.86 Kb/s Partition name: VENDOR Address: 0000FC000000, size: 000019000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1065.61 Kb/s Partition name: ODM Address: 000115000000, size: 00001B800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1037.62 Kb/s Partition name: OMR Address: 000143E00000, size: 000001400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 946.84 Kb/s Partition name: CP_DEBUG Address: 000145200000, size: 000000500000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1063.57 Kb/s Partition name: NAD_FW Address: 000145700000, size: 000001400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1065.30 Kb/s All done time: [00:18:15:509] Setting frequence to 21 Mhz CMD Pullup Level: 917 mV CMD Active Level: 1949 mV EMMC Device Information : EMMC CID: 150100424A5444345200DE0FFE764554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: DE0FFE76 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_DE0FFE76_20181203_162424.extcsd EMMC Init completed. Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: D:j600f\r2;3\EMMC_BJTD4R_ROM2_000000000000_0000004 00000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 958.68 Kb/s All done time: [00:00:05:470] Setting frequence to 21 Mhz CMD Pullup Level: 928 mV CMD Active Level: 1959 mV EMMC Device Information : EMMC CID: 150100424A5444345200DE0FFE764554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: DE0FFE76 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_DE0FFE76_20181203_162502.extcsd EMMC Init completed. Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: D:j600f\r2;3\EMMC_BJTD4R_ROM3_000000000000_0000004 00000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 960.41 Kb/s All done time: [00:00:05:410] |
12-03-2018, 22:37 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
When you run "read by vendor", ROM2/3 is already backuped No needs to read it | |
The Following User Says Thank You to layder For This Useful Post: |
