12-04-2018, 21:48 | #1 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2813429 Status: Offline Thanks Meter: 1 | J200h all done no power 29/11/2018 16:18:58> EasyJTAG API ver. 2100 29/11/2018 16:18:58> Setting IO Levels to 1.8V 29/11/2018 16:18:58> Setting frequence to 12 Mhz 29/11/2018 16:18:58> EasyJTAG Box Serial = 29/11/2018 16:18:58> EasyJTAG Box Firmware = 2.30 29/11/2018 16:18:58> Setting interface to EasyJtag2/ISP_HiPower 29/11/2018 16:18:58> Setting bus width to 1 Bit 29/11/2018 16:18:58> HiPower mode is ON 29/11/2018 16:18:58> Setting frequence to 12 Mhz 29/11/2018 16:18:58> CMD Pullup Level: 1772 mV 29/11/2018 16:18:58> CMD Active Level: 1875 mV 29/11/2018 16:18:58> eMMC Init returned = 0 29/11/2018 16:18:58> EMMC Device Information : 29/11/2018 16:18:58> EMMC CID: 90014A48384734742101A269311C929F 29/11/2018 16:18:58> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400013 29/11/2018 16:18:58> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4t , HEX: 483847347400 , S/N: A269311C , rev. 0x01 29/11/2018 16:18:58> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2015 29/11/2018 16:18:58> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 29/11/2018 16:18:58> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 29/11/2018 16:18:58> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 29/11/2018 16:18:58> EMMC Permanent Write Protection: No 29/11/2018 16:18:58> EMMC Temporary Write Protection: No 29/11/2018 16:18:58> Extended CSD Information : 29/11/2018 16:18:58> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 29/11/2018 16:18:58> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 29/11/2018 16:18:58> Boot Bus Config: 0x00 , width 1bit 29/11/2018 16:18:59> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 29/11/2018 16:18:59> Supported partition features [PARTITIONING_SUPPORT]: 0x07 29/11/2018 16:18:59> Device supports partitioning features 29/11/2018 16:18:59> Device can have enhanced technological features in partitions and user data area 29/11/2018 16:18:59> Device can have extended partitions attribute 29/11/2018 16:18:59> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 29/11/2018 16:18:59> Backup saved: H8G4t_A269311C_20181129_161859.extcsd 29/11/2018 16:18:59> EMMC Init completed. 29/11/2018 16:18:59> 29/11/2018 16:18:59> Scan from: H8G4t 29/11/2018 16:18:59> 29/11/2018 16:18:59> Vendor: Samsung 29/11/2018 16:18:59> Searching GPT ... 29/11/2018 16:18:59> GPT header is found and is valid 29/11/2018 16:18:59> 29/11/2018 16:19:00> GPT header successfully parsed 29/11/2018 16:19:00> 29/11/2018 16:19:00> Scan done 29/11/2018 16:19:00> 29/11/2018 16:19:00> Mount [efs] successfully PartType: LINUX 29/11/2018 16:19:00> Mount [productinfo] successfully PartType: LINUX 29/11/2018 16:19:00> Mount [persdata] successfully PartType: LINUX 29/11/2018 16:19:00> Mount [cache] successfully PartType: LINUX 29/11/2018 16:19:00> Mount [system] successfully PartType: LINUX 29/11/2018 16:19:00> Mount [hidden] successfully PartType: LINUX 29/11/2018 16:19:00> Mount [data] successfully PartType: LINUX 29/11/2018 16:19:00> 29/11/2018 16:25:59> Looking for EasyJTAG box... 29/11/2018 16:25:59> EasyJTAG API ver. 2100 29/11/2018 16:25:59> Setting IO Levels to 1.8V 29/11/2018 16:25:59> Setting frequence to 12 Mhz 29/11/2018 16:25:59> EasyJTAG Box Serial = 29/11/2018 16:25:59> EasyJTAG Box Firmware = 2.30 29/11/2018 16:25:59> Setting interface to EasyJtag2/ISP_HiPower 29/11/2018 16:25:59> Setting bus width to 1 Bit 29/11/2018 16:25:59> HiPower mode is ON 29/11/2018 16:25:59> Setting frequence to 12 Mhz 29/11/2018 16:25:59> CMD Pullup Level: 1774 mV 29/11/2018 16:25:59> CMD Active Level: 1875 mV 29/11/2018 16:25:59> eMMC Init returned = 0 29/11/2018 16:26:00> EMMC Device Information : 29/11/2018 16:26:00> EMMC CID: 90014A48384734742101A269311C929F 29/11/2018 16:26:00> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400013 29/11/2018 16:26:00> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4t , HEX: 483847347400 , S/N: A269311C , rev. 0x01 29/11/2018 16:26:00> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2015 29/11/2018 16:26:00> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 29/11/2018 16:26:00> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 29/11/2018 16:26:00> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 29/11/2018 16:26:00> EMMC Permanent Write Protection: No 29/11/2018 16:26:00> EMMC Temporary Write Protection: No 29/11/2018 16:26:00> Extended CSD Information : 29/11/2018 16:26:00> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 29/11/2018 16:26:00> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 29/11/2018 16:26:00> Boot Bus Config: 0x00 , width 1bit 29/11/2018 16:26:00> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 29/11/2018 16:26:00> Supported partition features [PARTITIONING_SUPPORT]: 0x07 29/11/2018 16:26:00> Device supports partitioning features 29/11/2018 16:26:00> Device can have enhanced technological features in partitions and user data area 29/11/2018 16:26:00> Device can have extended partitions attribute 29/11/2018 16:26:00> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 29/11/2018 16:26:00> Backup saved: H8G4t_A269311C_20181129_162600.extcsd 29/11/2018 16:26:00> EMMC Init completed. 29/11/2018 16:26:00> 29/11/2018 16:26:00> Scanning soft partitions 29/11/2018 16:26:00> GPT header is found and is valid 29/11/2018 16:26:00> Partition: sboot, [000000400000 - 000000600000], size: 000000200000 (2,00 MB) 29/11/2018 16:26:00> Partition: sboot2, [000000600000 - 000000800000], size: 000000200000 (2,00 MB) 29/11/2018 16:26:00> Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: wdsp, [000000C00000 - 000001000000], size: 000000400000 (4,00 MB) 29/11/2018 16:26:00> Partition: modem, [000001000000 - 000001800000], size: 000000800000 (8,00 MB) 29/11/2018 16:26:00> Partition: modem2, [000001800000 - 000002000000], size: 000000800000 (8,00 MB) 29/11/2018 16:26:00> Partition: tddsp, [000002000000 - 000002400000], size: 000000400000 (4,00 MB) 29/11/2018 16:26:00> Partition: fota_sig, [000002400000 - 000002500000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: param, [000002900000 - 000002B00000], size: 000000200000 (2,00 MB) 29/11/2018 16:26:00> Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 (20,0 MB) 29/11/2018 16:26:00> Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 (5,00 MB) 29/11/2018 16:26:00> Partition: reserved2, [000004400000 - 000004600000], size: 000000200000 (2,00 MB) 29/11/2018 16:26:00> Partition: kernel, [000004600000 - 000005600000], size: 000001000000 (16,0 MB) 29/11/2018 16:26:00> Partition: recovery, [000005600000 - 000006600000], size: 000001000000 (16,0 MB) 29/11/2018 16:26:00> Partition: persistent, [000006600000 - 000006700000], size: 000000100000 (1,00 MB) 29/11/2018 16:26:00> Partition: persdata, [000006700000 - 000007000000], size: 000000900000 (9,00 MB) 29/11/2018 16:26:00> Partition: cache, [000007000000 - 000013800000], size: 00000C800000 (200 MB) 29/11/2018 16:26:00> Partition: system, [000013800000 - 000071400000], size: 00005DC00000 (1,46 GB) 29/11/2018 16:26:00> Partition: hidden, [000071400000 - 000073200000], size: 000001E00000 (30,0 MB) 29/11/2018 16:26:00> Partition: userdata, [000073200000 - 0001D1FFBE00], size: 00015EDFBE00 (5,48 GB) 29/11/2018 16:26:00> GPT header successfully parsed 29/11/2018 16:26:00> 29/11/2018 16:26:00> Get firmware version 29/11/2018 16:26:01> 29/11/2018 16:26:02> Brand = samsung 29/11/2018 16:26:02> Manufacturer = samsung 29/11/2018 16:26:02> Model = SM-J200H 29/11/2018 16:26:02> Phone platform = sc8830 29/11/2018 16:26:02> CPU Abi = armeabi-v7a 29/11/2018 16:26:02> Android release = 5.1.1 29/11/2018 16:26:02> Firmware version = LMY48B.J200HXXU0APK1 29/11/2018 16:26:02> Firmware date = Tue Nov 8 13:26:48 KST 2016 |
