Old 07-04-2018, 08:35   #1 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
J200H Dead Boot Repair successfully completed by eMMC_tool Suite ver. 1.4.9.0
Using the official stock firmware J200HXXU0AQK2_J200HOJV0ARE1_J200HXXU0ARE1_ACR_5.1. 1
eMMC_tool Suite  ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial = 06010014FC294D61
Card Serial = AA34-B7FF
EasyJTAG Box Firmware = 1.62
Changelog:
12.12.2017 (ver 1.4.9.0)
   Fix:   Bugs that have been found through your crash report
   Fix:   RandomVerify function
   Fix:   Creation of GPT for Samsung (write by vendor)
   Fix:   Failed to mount large Fat partitions (explorer)
   Fix:   Extraction from contact2.db (explorer)
   Fix:   Error in the "build.prop" parser
   Fix:   CID Parser
   Add:  Support for EasyJtag Plus Box
   Add:  Path for TempDir and InitialDir (option in settings)
   Add:  Unpack Lenovo QSB (utilities)
   Add:  Selecting a PIT file from CSC (write by vendor Samsung)
   Add:  Detect for encrypted dumps from GPG Box
   Add:  Detect for FullDiskEncryption Partition (explorer)
   Add:  LinearVerify of the Partition (read by vendor)
   Add:  Information base about emmc compatibility (thanks to phonemicrodb)
   Add:  Resizing the window (for small screen resolutions)
   Add:  Converting large partitions in SparseImage when reading by vendor (option in settings)
   Add:  Mounting SparseImage (explorer)
   Add:  Automatic backup of the EFS partition for Samsung (read by vendor)
   Add:  Formatting of EFS partition for Samsung on request (write by vendor)
Setting frequence to 21 Mhz
CMD Pullup Level: 1753 mV
CMD Active Level: 2485 mV
EMMC Device Information :
EMMC CID: 90014A4838473474210169EA84D1920E
EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 69EA84D1 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 9/2015
   EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H8G4t_69EA84D1_20180704_003351.extcsd
EMMC Init completed.
Error:  First select the Pit-file
CMD Pullup Level: 1742 mV
CMD Active Level: 2495 mV
Backup saved: H8G4t_69EA84D1_20180704_003403.extcsd
Opening file: J23G_EUR_OPEN.pit
Pit: J23G_EUR_OPEN.pit
Entry count: 31
The size of the last section has been updated
J200HXXU0AQK2_J200HOJV0ARE1_J200HXXU0ARE1_HOME._ACR.tar
The list of files in the firmware:
spl.img
sboot.bin
sboot2.bin
param.lfs
boot.img
recovery.img
system.img
cache.img
hidden.img
sprdcp.img
sprddsp.img
nvitem.bin
Backup saved: H8G4t_69EA84D1_20180704_003416.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: spl.img
Unpacking file: sboot.bin
Unpacking file: sboot2.bin
Unpacking file: nvitem.bin
Unpacking file: sprddsp.img
Unpacking file: sprdcp.img
Unpacking file: param.lfs
Unpacking file: boot.img
Unpacking file: recovery.img
Unpacking file: cache.img
Unpacking file: system.img
Unpacking file: hidden.img
Partition name: BOOT
Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 285.17 KB/s
Partition name: SBOOT
Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 506.33 KB/s
Partition name: SBOOT2
Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes
Done writing partition. Write speed: 500.97 KB/s
Partition name: WFIXNV2
Filename: nvitem.bin , Offset: 000000900000 , filesize: 181868 bytes
Done writing partition. Write speed: 509.53 KB/s
Partition name: WDSP
Filename: sprddsp.img , Offset: 000000C00000 , filesize: 2097152 bytes
Done writing partition. Write speed: 503.40 KB/s
Partition name: MODEM
Filename: sprdcp.img , Offset: 000001000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 509.47 KB/s
Partition name: PARAM
Filename: param.lfs , Offset: 000002900000 , filesize: 573440 bytes
Done writing partition. Write speed: 508.15 KB/s
Partition name: KERNEL
Filename: boot.img , Offset: 000004600000 , filesize: 13796368 bytes
Done writing partition. Write speed: 509.99 KB/s
Partition name: RECOVERY
Filename: recovery.img , Offset: 000005600000 , filesize: 14533648 bytes
Done writing partition. Write speed: 510.45 KB/s
Partition name: CACHE
Filename: cache.img , Offset: 000007000000 , filesize: 42369312 bytes
Sparse image found v.1.0  Total chunks: 16
Done writing partition. Write speed: 510.26 KB/s
Partition name: SYSTEM
Filename: system.img , Offset: 000013800000 , filesize: 1421073920 bytes
Sparse image found v.1.0  Total chunks: 2270
Done writing partition. Write speed: 508.19 KB/s
Partition name: HIDDEN
Filename: hidden.img , Offset: 000071400000 , filesize: 27317232 bytes
Sparse image found v.1.0  Total chunks: 61
Done writing partition. Write speed: 505.22 KB/s
Critical error: Access violation at address 00E1387E in module 'eMMC_tool.exe'. Read of address 00000004.
Send a crash report. Please, wait ...
Backup saved: H8G4t_69EA84D1_20180704_020832.extcsd
CrashReport sent successfully
CMD Pullup Level: 1732 mV
Backup saved: H8G4t_69EA84D1_20180704_020845.extcsd
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-J200H
Phone platform = sc8830
CPU Abi = armeabi-v7a
Android release = 5.1.1
Firmware version = LMY48B.J200HXXU0AQK2
Firmware date = Mon Nov 13 22:32:54 KST 2017
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 07-04-2018, 17:30   #2 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
this verson is more stable than the latest one
Old 01-31-2021, 14:47   #3 (permalink)
Member: 2335681
Sonork: 100.1668903
Thanks Meter: 23
Warning: Health report is very BAD
Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time
Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used
Pre EOL information [267]: 0x03 Urgent
Scanning soft partitions
GPT header is found and is valid
Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 (2.00 MB)
Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB)
Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB)
Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB)
Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB)
Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB)
Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB)
Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 (8.00 MB)
Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 (8.00 MB)
Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 (4.00 MB)
Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 (1.00 MB)
Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 (1.00 MB)
Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 (1.00 MB)
Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 (1.00 MB)
Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 (1.00 MB)
Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 (2.00 MB)
Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 (20.0 MB)
Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 (5.00 MB)
Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 (2.00 MB)
Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 (16.0 MB)
Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 (16.0 MB)
Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 (1.00 MB)
Partition: persdata, [000006700000 - 000007000000], size: 000000900000 (9.00 MB)
Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 (200. MB)
Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 (1.46 GB)
Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 (30.0 MB)
Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 (5.47 GB)
GPT header successfully parsed
pleas sulition
Old 01-31-2021, 15:36   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
pleas sulition
solution is - replace eMMC
Page generated in 0.19571 seconds with 8 queries
