10-23-2018, 04:51 | #1 (permalink) |
Insane Poster Join Date: Nov 2009 Location: MOROCCO
Member: 1157644 Status: Offline Thanks Meter: 5 | CMD Pullup Level: 2000 mV CMD Active Level: 2299 mV EMMC Device Information : EMMC CID: 150100515831334D4200C3D5F2D5359A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: C3D5F2D5 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_C3D5F2D5_20181023_043912.extcsd EMMC Init completed. Get firmware version GPT header is found and is valid Checking for ROM2 ... ROM2 is blank not find dump for j250f ds 32gb in support area how to repair please can somone provide pit j250f ds 32gb with rom 2 dump plase Last edited by layder; 10-24-2018 at 09:39. Reason: merge posts |
10-24-2018, 09:43 | #3 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
also j250f file dump is present on support: | |
The Following User Says Thank You to layder For This Useful Post: |
