11-16-2018, 11:42 | #1 (permalink) |
Crazy Poster Join Date: Dec 2014 Location: Walling,syangja,nepal
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | i flashed lattest frimware from sam frimware but set not power on plese help me log is here Code: Setting frequence to 21 Mhz CMD Pullup Level: 1815 mV CMD Active Level: 2526 mV EMMC Device Information : EMMC CID: 150100514536364D42007A53D4023554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG , EMMC NAME: QE66MB , EMMC NAME (HEX): 514536364D42 , S/N: 7A53D402 , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QE66MB_7A53D402_20181116_140459.extcsd EMMC Init completed. Opening file: J2Y18LTE_MEA_OPEN.pit Pit: J2Y18LTE_MEA_OPEN.pit Entry count: 52 The size of the last section has been updated BL_J250FXWU2ARC6_CL13211865_QB17352985_REV00_user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: aboot.mbn sbl1.mbn rpm.mbn tz.mbn devcfg.mbn non-hlos.bin cmnlib.mbn keymaster.mbn lksecapp.mbn sec.dat apdp.mbn msadp.mbn AP_J250FXWU2ARC6_CL13211865_QB17352985_REV00_user_low_ship_MULTI_CERT_meta.tar.md5 The list of files in the firmware: boot.img recovery.img system.img.ext4 persist.img.ext4 userdata.img.ext4 meta-data/ meta-data/fota.zip Setting frequence to 21 Mhz CMD Pullup Level: 1815 mV CMD Active Level: 2516 mV EMMC Device Information : EMMC CID: 150100514536364D42007A53D4023554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG , EMMC NAME: QE66MB , EMMC NAME (HEX): 514536364D42 , S/N: 7A53D402 , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QE66MB_7A53D402_20181116_140511.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: devcfg.mbn Unpacking file: sec.dat Unpacking file: keymaster.mbn Unpacking file: cmnlib.mbn Unpacking file: lksecapp.mbn Unpacking file: apdp.mbn Unpacking file: msadp.mbn Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Unpacking file: non-hlos.bin Unpacking file: system.img.ext4 Unpacking file: userdata.img.ext4 Partition name: SBL1 Filename: sbl1.mbn , Offset: 000000400000 , filesize: 380100 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 760.30 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000000510000 , filesize: 1179272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 793.13 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000000710000 , filesize: 218656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 740.03 KB/s Partition name: TZ Filename: tz.mbn , Offset: 000000790000 , filesize: 1572352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 829.52 KB/s Partition name: DEVCFG Filename: devcfg.mbn , Offset: 000000A10000 , filesize: 94428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 589.41 KB/s Partition name: SEC Filename: sec.dat , Offset: 000000D50000 , filesize: 692 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 13.57 KB/s Partition name: KEYMASTER Filename: keymaster.mbn , Offset: 000000D54000 , filesize: 259032 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 767.63 KB/s Partition name: CMNLIB Filename: cmnlib.mbn , Offset: 000000DD4000 , filesize: 238496 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 749.32 KB/s Partition name: LKSECAPP Filename: lksecapp.mbn , Offset: 000000E54000 , filesize: 270944 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 614.46 KB/s Partition name: APDP Filename: apdp.mbn , Offset: 000000ED4000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 428.44 KB/s Partition name: MSADP Filename: msadp.mbn , Offset: 000000F14000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 397.51 KB/s Partition name: BOOT Filename: boot.img , Offset: 000002E00000 , filesize: 14289168 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 495.23 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000004E00000 , filesize: 15866128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 829.02 KB/s Partition name: PERSIST Filename: persist.img.ext4 , Offset: 000008301000 , filesize: 4743292 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8 Done writing partition. Write speed: 334.55 KB/s Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000011980000 , filesize: 25401088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 727.55 KB/s Partition name: SYSTEM Filename: system.img.ext4 , Offset: 000013800000 , filesize: 2837423428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 4206 Done writing partition. Write speed: 805.76 KB/s Partition name: USERDATA Filename: userdata.img.ext4 , Offset: 0000F5400000 , filesize: 863198596 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 286 Done writing partition. Write speed: 827.34 KB/s All done time: [01:49:29:286] Code: eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = 0100C01CD5DD0243 Card Serial = AA49-BC99 EasyJTAG Box Firmware = 1.62 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting frequence to 21 Mhz CMD Pullup Level: 2670 mV CMD Active Level: 2763 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 Mhz CMD Pullup Level: 1433 mV CMD Active Level: 2402 mV EMMC Device Information : EMMC CID: 150100514536364D42007A53D4023554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG , EMMC NAME: QE66MB , EMMC NAME (HEX): 514536364D42 , S/N: 7A53D402 , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QE66MB_7A53D402_20181116_185305.extcsd EMMC Init completed. Opening file: J2Y18LTE_MEA_OPEN.pit Pit: J2Y18LTE_MEA_OPEN.pit Entry count: 52 The size of the last section has been updated BL_J250FXXU2ARD3_CL13338766_QB17796286_REV00_user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: aboot.mbn sbl1.mbn rpm.mbn tz.mbn devcfg.mbn non-hlos.bin cmnlib.mbn keymaster.mbn lksecapp.mbn sec.dat apdp.mbn msadp.mbn Setting frequence to 21 Mhz CMD Pullup Level: 1443 mV CMD Active Level: 2413 mV EMMC Device Information : EMMC CID: 150100514536364D42007A53D4023554 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG , EMMC NAME: QE66MB , EMMC NAME (HEX): 514536364D42 , S/N: 7A53D402 , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QE66MB_7A53D402_20181116_185321.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: devcfg.mbn Unpacking file: sec.dat Unpacking file: keymaster.mbn Unpacking file: cmnlib.mbn Unpacking file: lksecapp.mbn Unpacking file: apdp.mbn Unpacking file: msadp.mbn Unpacking file: non-hlos.bin Partition name: SBL1 Filename: sbl1.mbn , Offset: 000000400000 , filesize: 380108 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 761.14 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000000510000 , filesize: 1195364 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 809.01 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000000710000 , filesize: 218656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 751.30 KB/s Partition name: TZ Filename: tz.mbn , Offset: 000000790000 , filesize: 1572352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 829.63 KB/s Partition name: DEVCFG Filename: devcfg.mbn , Offset: 000000A10000 , filesize: 94428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 595.69 KB/s Partition name: SEC Filename: sec.dat , Offset: 000000D50000 , filesize: 692 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 13.48 KB/s Partition name: KEYMASTER Filename: keymaster.mbn , Offset: 000000D54000 , filesize: 259032 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 772.48 KB/s Partition name: CMNLIB Filename: cmnlib.mbn , Offset: 000000DD4000 , filesize: 238496 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 752.38 KB/s Partition name: LKSECAPP Filename: lksecapp.mbn , Offset: 000000E54000 , filesize: 270944 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 715.10 KB/s Partition name: APDP Filename: apdp.mbn , Offset: 000000ED4000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 428.94 KB/s Partition name: MSADP Filename: msadp.mbn , Offset: 000000F14000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 429.45 KB/s Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000011980000 , filesize: 25401088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 828.75 KB/s All done time: [00:00:50:847] Last edited by layder; 11-17-2018 at 09:38. Reason: merge posts |
11-17-2018, 09:40 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
1.4.9.0 sometime create bad GPT | |
The Following User Says Thank You to layder For This Useful Post: |
