11-08-2018, 10:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Supported files Z3X shell My eMMC chip is like this ---------- eMMC Device Information ---------- eMMC CID : 15010056545530304D080B8E82F6701A eMMC CSD : D02701320F5903FFF6DBFFFF8E40406C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2013 Rev.0x8 eMMC NAME: VTU00M , S/N: 193889014 eMMC NAME (HEX): 56545530304D IC Name: Samsung , KMVTU000LM-B503/16GB @FBGA153 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00014000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: VTU00M_ 193889014_20181108_0920.extcsd Done. I found out that there 4 Supported files possible to download from Z3x shell. There are EMMC_ROM1_512Mb_USER.rar and EMMC_ROM2_2Mb_BOOT.rar So I guess they are for eMMC. I unpacked them and started with EMMC_ROM1_512Mb_USER.rar I set: ROM to access ROM1( Main user data) Preset I left it for 128kB How should I set it? Next I wanted to programm ROM2 but it failed Checking NAND Image : C:\eMMC\i9300\EMMC_ROM2_00000000_00200000.bin Autodetected RAW data File successefuly loaded! Partition table scan: GPT: not present Why does it fail? What is GPT? Thanks? |
11-08-2018, 10:58 | #2 (permalink) | ||
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
You need select file, select ROM (1/2/3), press write or Set "Write All ROMs" and select multiple files Preset need to set "Lenght" address. Then you load files, "Lenght" is auto changed | ||
11-09-2018, 09:27 | #3 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for the reply.I updated firmware. At the end of the updating it says Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Will it be done automatically when I upload ROM1 and ROM2? Next I Set "Write All eMMC regions at once " Checking NAND Image : C:\eMMC\i9300\EMMC_ROM1_00000000_20000000.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Found ROM2 and automatically selected. Real (Hardware) Disk/Image size: 100000 sectors 512.0 MiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 30777310 Checking NAND Image : C:\eMMC\i9300\EMMC_ROM2_00000000_00200000.bin File successefuly loaded! As you can see there is a problem with ROM1. Can you please help/explain? Thanks |
