07-14-2016, 03:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | j500g j500h j500f no service problem solve Quote: Originally Posted by mrkey2014 WRITE CERT EROR BYPAS MSL.... Operation: Write CERT Selected model: SM-J500G Selected port: COM66 SAMSUNG Mobile USB Serial Port Software version: 25.8 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500G Android version: 5.1.1 Product code: Not Active Phone version: J500GXXU1APA2 PDA version: J500GXXU1APA2 CSC version: J500GOLB1AOK2 CSC country code: INDONESIA CSC sales code: XID HW version: Phone S/N: Modem board: MSM8916 RF cal date: 2015.09.09 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.25.8 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500G Selected port: Software version: 25.8 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500G Android version: 5.1.1 Product code: Not Active Phone version: J500GXXU1AOJ2 PDA version: J500GXXU1AOJ1 CSC version: J500GOLB1AOJ1 CSC country code: THAILAND CSC sales code: THL HW version: Phone S/N: RV1GB14K39K Modem board: MSM8916 RF cal date: 2015.11.20 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0338 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.25.8 |
The Following 3 Users Say Thank You to kothamamun For This Useful Post: |
