12-18-2019, 23:18 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Ortahisar
Member: 1929052 Status: Offline Thanks Meter: 22 | j530f after resef frp and screen lock phone is dead trouble in working phone j530f in ısp conenection first i reset frp and then screen lock but phone is dead now later i flash firmware u5 everything ok but pc detected only exynos 7870 port her is log EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: sboot.bin Unpacking Lz4: sboot.bin.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: boot.img Unpacking Lz4: boot.img.lz4 Unpacking file: recovery.img Unpacking Lz4: recovery.img.lz4 Unpacking file: modem.bin Unpacking file: system.img Unpacking Lz4: system.img.lz4 Unpacking file: cache.img Unpacking Lz4: cache.img.lz4 Unpacking file: hidden.img Unpacking Lz4: hidden.img.lz4 Unpacking file: modem_debug.bin Unpacking file: userdata.img Unpacking Lz4: userdata.img.lz4 Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1728784 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 692,18 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003500000 , filesize: 931840 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1044,27 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003D00000 , filesize: 19595552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2055,02 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005D00000 , filesize: 24942880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2071,85 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008B00000 , filesize: 38764496 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2041,40 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000F000000 , filesize: 2845458656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 4108 Done writing partition. Write speed: 2020,38 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000CF000000 , filesize: 19472672 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 2053,73 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 0000DB800000 , filesize: 10559728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 2027,73 KB/s Partition name: CP_DEBUG Filename: modem_debug.bin , Offset: 0000E1C00000 , filesize: 5242880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2068,97 KB/s Partition name: USERDATA Filename: userdata.img , Offset: 0000E3600000 , filesize: 1169810160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 557 Done writing partition. Write speed: 2042,27 KB/s Check BootConfig for the selected vendor All done time: [00:39:57:303] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 406 mV CMD Active Level: 1708 mV EMMC Device Information : EMMC CID: 150100414A544434520067D7FE50C4CF EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: AJTD4R , HEX: 414A54443452 , S/N: 67D7FE50 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJTD4R_67D7FE50_20191219_002002.extcsd EMMC Init completed. Filename: AJTD4R_67D7FE50_20191218_195235.extcsd Operation: Repairing ExtCsd ... Successfully Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 407 mV CMD Active Level: 1708 mV EMMC Device Information : EMMC CID: 150100414A544434520067D7FE50C4CF EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: AJTD4R , HEX: 414A54443452 , S/N: 67D7FE50 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJTD4R_67D7FE50_20191219_002033.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4,00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4,00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20,0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8,00 MB) Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4,00 MB) Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4,00 MB) Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4,00 MB) Partition: CARRIER, [000003400000 - 000003500000], size: 000000100000 (1,00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8,00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32,0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38,0 MB) Partition: OTA, [000008300000 - 000008B00000], size: 000000800000 (8,00 MB) Partition: RADIO, [000008B00000 - 00000E300000], size: 000005800000 (88,0 MB) Partition: TOMBSTONES, [00000E300000 - 00000E400000], size: 000000100000 (1,00 MB) Partition: PERSISTENT, [00000E400000 - 00000E480000], size: 000000080000 (512 KB) Partition: STEADY, [00000E480000 - 00000E880000], size: 000000400000 (4,00 MB) Partition: RESERVED2, [00000E880000 - 00000F000000], size: 000000780000 (7,50 MB) Partition: SYSTEM, [00000F000000 - 0000CF000000], size: 0000C0000000 (3,00 GB) Partition: CACHE, [0000CF000000 - 0000DB800000], size: 00000C800000 (200 MB) Partition: HIDDEN, [0000DB800000 - 0000E1C00000], size: 000006400000 (100 MB) Partition: CP_DEBUG, [0000E1C00000 - 0000E2100000], size: 000000500000 (5,00 MB) Partition: NAD_FW, [0000E2100000 - 0000E3500000], size: 000001400000 (20,0 MB) Partition: NAD_REFER, [0000E3500000 - 0000E3600000], size: 000000100000 (1,00 MB) Partition: USERDATA, [0000E3600000 - 0003AB3FBE00], size: 0002C7DFBE00 (11,1 GB) GPT header successfully parsed Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 405 mV CMD Active Level: 1710 mV EMMC Device Information : EMMC CID: 150100414A544434520067D7FE50C4CF EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: AJTD4R , HEX: 414A54443452 , S/N: 67D7FE50 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJTD4R_67D7FE50_20191219_002039.extcsd EMMC Init completed. Get firmware version Too many errors. Enabling ResetBox mode Error: Except: Mount [CACHE] failed PartType: LINUX Error: Except: Mount [HIDDEN] failed PartType: LINUX Error: Except: Mount [USERDATA] failed PartType: LINUX Error: Except: Unmount [CACHE/] failed Error: Except: Unmount [HIDDEN/] failed Error: Except: Unmount [USERDATA/] failed Brand = samsung Manufacturer = samsung Device = j5y17lte Model = SM-J530F Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 8.1.0 Firmware version = M1AJQ.J530FXXS5BSE3 Firmware date = Thu May 30 15:30:35 KST 2019 |
