01-28-2017, 20:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: on moon right now !
Member: 469192 Status: Offline Thanks Meter: 48 | j700h help please there is no emmc name and sn and cant write rom 1,2,3 and extsd file EMMC CID : 3C3C00000601000DFFFFFFFFFFFF0000 EMMC CSD : 5A5A00000000000000000000000000E8 EMMC Manufacturer ID: 0000 , OEM ID: 0000 EMMC Date: 00/0000 Rev.0x0 EMMC NAME: , S/N: 0 EMMC NAME (HEX): 20202020202000 EMMC ROM1 (Main User Data) Capacity: 0 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x00 Device NOT support partitioning feature Device cannot have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: _ 0_20170128_2230.extcsd Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:484 mV CMD Active Level:2175 mV Box IO Level:2800 mV CLK Rate:7000 khz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. You must select ROM file first! Z3X EasyJtag Software ver. 2.5.0.4 Skip loading eMMC Addon Firmware CMD Pullup Level:484 mV CMD Active Level:2175 mV Box IO Level:2800 mV CLK Rate:7000 khz Erasing 00400000 bytes from 00000000 ...ROM1 Erase Length has been corrected to 0x000000000400 bytes... Erase Done. Processing file...F:\j70000000h gtag\400073_1137026488_20160408_1211.extcsd Processing file...F:\j70000000h gtag\ROM1_VENESSIA.bin Processing file...F:\j70000000h gtag\ROM2_VENESSIA.bin Processing file...F:\j70000000h gtag\ROM3_VENESSIA.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.4 Skip loading eMMC Addon Firmware CMD Pullup Level:484 mV CMD Active Level:2175 mV Box IO Level:2800 mV CLK Rate:7000 khz Writing... Done. Z3X EasyJtag Software ver. 2.5.0.4 Skip loading eMMC Addon Firmware CMD Pullup Level:484 mV CMD Active Level:2175 mV Input file : F:\j70000000h gtag\ROM1_VENESSIA.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Length has been corrected to 0x0000000400 bytes... Retry writing adress 0x00000000 (Attempt #1)... Retry Fail! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail! Retry writing adress 0x00000000 (Attempt #4)... Retry Fail! Retry writing adress 0x00000000 (Attempt #5)... Retry Fail! Write Block Failed, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.4 Skip loading eMMC Addon Firmware CMD Pullup Level:484 mV CMD Active Level:2175 mV Input file : F:\j70000000h gtag\ROM2_VENESSIA.bin Writing 0000000000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Access to current partition forbidden ( size=0 ) Done. Z3X EasyJtag Software ver. 2.5.0.4 Skip loading eMMC Addon Firmware CMD Pullup Level:484 mV CMD Active Level:2175 mV Input file : F:\j70000000h gtag\ROM3_VENESSIA.bin Writing 0000000000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Access to current partition forbidden ( size=0 ) Done. |
01-29-2017, 02:06 | #4 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: Philippines
Member: 405730 Status: Offline Thanks Meter: 184 | Quote:
01-29-2017, 09:10 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Best ways is ISP .but sometimes in this model wrong/bad vcc/q can make same thing so please check vcc/vccq and connect both together |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
