Old 02-19-2018, 09:49   #1 (permalink)
Member: 1079917
Sonork: 100.1663316
Thanks Meter: 49
Asus T00P invalid Boot image Repair Done
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial = 1029261B332297B3
Card Serial = AA0C-E794
EasyJTAG Box Firmware = 2.21
Changelog:
12.12.2017 (ver 1.4.9.0)
Fix: Bugs that have been found through your crash report
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 18 Mhz
CMD Pullup Level: 2049 mV
CMD Active Level: 2474 mV
EMMC Device Information :
EMMC CID: 90014A484147326505030087C0E0617D
EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3
EMMC Manufacture Name: SKHYNIX , EMMC NAME: HAG2e , EMMC NAME (HEX): 484147326500 , S/N: 0087C0E0 , rev. 0x03
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2014
EMMC ROM 1 (Main User Data) Capacity: 14992 MB (0003A9000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC GP1 (GP Partition 1) Capacity: 40 MB , WR_REL (000002800000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x06 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: HAG2e_0087C0E0_20180219_124731.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: reserved, [000000005000 - 000008005000], size: 000008000000
Partition: panic, [000008005000 - 000008805000], size: 000000800000
Partition: factory, [000008805000 - 00000A805000], size: 000002000000
Partition: spare, [00000A805000 - 00000B005000], size: 000000800000
Partition: config, [00000B005000 - 00000D005000], size: 000002000000
Partition: cache, [00000D005000 - 00002D005000], size: 000020000000
Partition: APD, [00002D005000 - 000039005000], size: 00000C000000
Partition: ADF, [000039005000 - 00003B005000], size: 000002000000
Partition: system, [00003B005000 - 00008C405000], size: 000051400000
Partition: data, [00008C405000 - 0001D1000000], size: 000144BFB000
GPT header successfully parsed
Get firmware version
Firmware info not found
CMD Pullup Level: 2050 mV
CMD Active Level: 2473 mV
Backup saved: HAG2e_0087C0E0_20180219_124827.extcsd
Operation: Write Dump
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Input file: D:\Easy Jtag\Dump\Asus- T00P\Zenfone 5 By repair Az\EMMC_H8G2d_ROM2_000000000000_000000400000.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 808.96 KB/s
All done time: [00:00:05:383]
CMD Pullup Level: 2053 mV
Backup saved: HAG2e_0087C0E0_20180219_124901.extcsd
The size has been corrected for the file size
Writing to: GP1 , start: 0x000000000000 , size: 0x000000800000
Input file: D:\Easy Jtag\Dump\Asus- T00P\Zenfone 5 By repair Az\EMMC_H8G2d_GP1_000000000000_000000800000.bin
eMMC switching to GP1
Done writing partition. Write speed: 757.88 KB/s
All done time: [00:00:11:078]
Backup saved: HAG2e_0087C0E0_20180219_124943.extcsd
Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000
Input file: D:\Easy Jtag\Dump\Asus- T00P\Zenfone 5 By repair Az\EMMC_H8G2d_ROM1_000000000000_000020000000.bin
eMMC switching to ROM1
Done writing partition. Write speed: 2007.16 KB/s
All done time: [00:04:22:082]
Backup saved: HAG2e_0087C0E0_20180219_125414.extcsd
CMD Pullup Level: 108 mV
CMD Active Level: 2397 mV
Can't init device. Reason: CMD Timeout Error
CMD Pullup Level: 2048 mV
CMD Active Level: 2471 mV
Backup saved: HAG2e_0087C0E0_20180219_125844.extcsd
Backup saved: HAG2e_0087C0E0_20180219_125854.extcsd
This operation is only performed for the Samsung eMMC
Backup saved: HAG2e_0087C0E0_20180219_125911.extcsd
Backup saved: HAG2e_0087C0E0_20180219_125919.extcsd
Operation: Universal Factory Format
Please, wait ...
Error: CARD Lock/Unlock Error
CMD Pullup Level: 2052 mV
Backup saved: HAG2e_0087C0E0_20180219_125927.extcsd
Backup saved: HAG2e_0087C0E0_20180219_125932.extcsd
Please, wait ...
Backup saved: HAG2e_0087C0E0_20180219_125948.extcsd
Operation: Changing GP sizes (final write) ...
GP1 size: 8 MB , WR_REL: 1 , ENH 0
GP1 size: 0 MB , WR_REL: 1 , ENH 0
HW_PART error. Reason: Card already partitioned
Backup saved: HAG2e_0087C0E0_20180219_125958.extcsd
Backup saved: HAG2e_0087C0E0_20180219_130012.extcsd
GP1 size: 40 MB , WR_REL: 1 , ENH 0
Backup saved: HAG2e_0087C0E0_20180219_130022.extcsd
Backup saved: HAG2e_0087C0E0_20180219_130028.extcsd
Backup saved: HAG2e_0087C0E0_20180219_130102.extcsd
Backup saved: HAG2e_0087C0E0_20180219_130114.extcsd
Filename: H8G2d_02A67B81_20170529_144502.extcsd
Writing BootConfig ...
Reg: 179 Value: 0x00
Reg: 177 Value: 0x06
Reg: 162 Value: 0x01
Done
All done
Backup saved: HAG2e_0087C0E0_20180219_130138.extcsd
Backup saved: HAG2e_0087C0E0_20180219_130206.extcsd
Writing to: ROM1 , start: 0x000000000000 , size: 0x0001D2000000
Input file: D:\Easy Jtag\Dump\Asus- T00P\ASUS_T00P-A500KL_V11.3.1.14_M1.4.12_F\userarea.bin
Done writing partition. Write speed: 2014.28 KB/s
All done time: [01:03:10:855]
Backup saved: HAG2e_0087C0E0_20180219_140826.extcsd
Partition: sbl1, [000000004400 - 000000044400], size: 000000040000
Partition: sdi, [000000044400 - 00000004C400], size: 000000008000
Partition: rpm, [00000004C400 - 0000000C9400], size: 00000007D000
Partition: tz, [0000000C9400 - 000000146400], size: 00000007D000
Partition: aboot, [000000146400 - 000000646400], size: 000000500000
Partition: ddr, [000001000000 - 000001008000], size: 000000008000
Partition: boot, [000001008000 - 000002008000], size: 000001000000
Partition: modem, [000002008000 - 000006008000], size: 000004000000
Partition: pad, [000007000000 - 000007100000], size: 000000100000
Partition: modemst1, [000007100000 - 000007280000], size: 000000180000
Partition: modemst2, [000007280000 - 000007400000], size: 000000180000
Partition: fsg, [000008000000 - 000008180000], size: 000000180000
Partition: asusdata, [000009000000 - 000009100000], size: 000000100000
Partition: asusdata2, [000009100000 - 000009200000], size: 000000100000
Partition: asuskey, [000009200000 - 000009300000], size: 000000100000
Partition: asuskey2, [000009300000 - 000009400000], size: 000000100000
Partition: asuskey3, [000009400000 - 000009500000], size: 000000100000
Partition: asuskey4, [000009500000 - 000009900000], size: 000000400000
Partition: asuskey5, [000009900000 - 000009D00000], size: 000000400000
Partition: asusfw, [000009D00000 - 000011D00000], size: 000008000000
Partition: sysconf, [000011D00000 - 000012100000], size: 000000400000
Partition: asusgpt, [000012100000 - 000012400000], size: 000000300000
Partition: fsc, [000012400000 - 000012400400], size: 000000000400
Partition: ssd, [000012400400 - 000012402400], size: 000000002000
Partition: misc, [000012402400 - 000012502400], size: 000000100000
Partition: persist, [000013000000 - 000015000000], size: 000002000000
Partition: recovery, [000015000000 - 000016000000], size: 000001000000
Partition: tombstones, [000016000000 - 00001A000000], size: 000004000000
Partition: asusgpt1, [00001A000000 - 00001A100000], size: 000000100000
Partition: asusgpt2, [00001A100000 - 00001A200000], size: 000000100000
Partition: ADF, [00001B000000 - 00001D000000], size: 000002000000
Partition: sbl1bak, [00001D000000 - 00001D040000], size: 000000040000
Partition: rpmbak, [00001D040000 - 00001D0BD000], size: 00000007D000
Partition: tzbak, [00001D0BD000 - 00001D13A000], size: 00000007D000
Partition: abootbak, [00001D13A000 - 00001D63A000], size: 000000500000
Partition: cache, [00001E000000 - 00004C000000], size: 00002E000000
Partition: APD, [00004C000000 - 000065000000], size: 000019000000
Partition: system, [000065000000 - 0000CC000000], size: 000067000000
Partition: userdata, [0000CC000000 - 0001D1FFBE00], size: 000105FFBE00
Brand = asus
Manufacturer = asus
Model = ASUS_T00P
Phone platform = msm8226
CPU Abi = armeabi-v7a
Android release = 4.4.2
Firmware version = OPEN_Phone-userdebug 4.4.2 KOT49H OPEN_Phone-11.3.1.14-20140922-F test-keys
Firmware date = Mon Sep 22 12:37:39 CST 2014
Old 05-13-2019, 07:10   #2 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 480
please give us link for the file..
Page generated in 0.27796 seconds with 9 queries
