Old 12-28-2018, 16:45   #1 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Jio F90M Read Info,Read Flash,Write Flash,Reset Lock Done By EasyJTAG Classic 3.4
Read Info:
Read Info LOG Here:
Found 5 devices
COM1 ACPI\PNP0501 Communications Port (COM1)
COM42 root\rimports RIM Virtual Serial Port v2 (COM42)
COM59 root\rimports RIM Virtual Serial Port v2 (COM59)
COM149 USB\Vid_0325&Pid_0032&Rev_0100&MI_00 Easy Jtag Control Port (COM149)
COM469 USB\Vid_05c6&Pid_9008&Rev_0000 Qualcomm HS-USB QDLoader 9008 (COM469)
QC Core Version 2.10
Using Port :COM469
Detecting Device mode...
Using EDL Programmer :Z:\Chinese Firmware\JIO\Priemium Files\JIO F90M\JIO_F90M_FLASH FILE_BY_ROCKY CHAUHAN\F90M\LYF-F90M-GFT-000-02-17-270917\prog_emmc_firehose_8909_ddr.mbn
Sahara Connectting To Device
Sahara Downloading flash programmer: Z:\Chinese Firmware\JIO\Priemium Files\JIO F90M\JIO_F90M_FLASH FILE_BY_ROCKY CHAUHAN\F90M\LYF-F90M-GFT-000-02-17-270917\prog_emmc_firehose_8909_ddr.mbn
Waiting for flash programmer to boot
Device Class:sahara
Device Protocol:firehose
Emergency Mode:true
Connecting to flash programmer...
Connected to flash programmer
Partition table scan:
 GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 7FFFFFFFFFFFFF sectors 16.0 EiB
Soft (Partitioned) Disk/Image size: 747FBC sectors 3.6 GiB
Logical sector size: 0x200  bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 7634910
Partition info successfully found
Found Data areas (firmware parts) count is: 30
P0 (MODEM) [0x4000000 0x4000000] Size: 64.0MB
P1 (SBL1) [0x8000000 0x80000] Size: 512.0KB
P2 (SBL1BAK) [0x8080000 0x80000] Size: 512.0KB
P3 (ABOOT) [0x8100000 0x100000] Size: 1.0MB
P4 (ABOOTBAK) [0x8200000 0x100000] Size: 1.0MB
P5 (RPM) [0x8300000 0x80000] Size: 512.0KB
P6 (RPMBAK) [0x8380000 0x80000] Size: 512.0KB
P7 (TZ) [0x8400000 0xc0000] Size: 768.0KB
P8 (TZBAK) [0x84c0000 0xc0000] Size: 768.0KB
P9 (PAD) [0x8580000 0x100000] Size: 1.0MB
P10 (MODEMST1) [0x8680000 0x180000] Size: 1.500MB
P11 (MODEMST2) [0x8800000 0x180000] Size: 1.500MB
P12 (MISC) [0x8980000 0x100000] Size: 1.0MB
P13 (FSC) [0x8a80000 0x400] Size: 1.0KB
P14 (SSD) [0x8a80400 0x2000] Size: 8.0KB
P15 (SPLASH) [0x8a82400 0xa00000] Size: 10.0MB
P16 (DDR) [0xc000000 0x8000] Size: 32.0KB
P17 (FSG) [0xc008000 0x180000] Size: 1.500MB
P18 (SEC) [0xc188000 0x4000] Size: 16.0KB
P19 (BOOT) [0xc18c000 0x2000000] Size: 32.0MB
P20 (SYSTEM) [0xe18c000 0x32000000] Size: 800.0MB
P21 (PERSIST) [0x4018c000 0x2000000] Size: 32.0MB
P22 (USBMSC) [0x44000000 0x3e800000] Size: 1000.0MB
P23 (CACHE) [0x84000000 0x10000000] Size: 256.0MB
P24 (RECOVERY) [0x94000000 0x2000000] Size: 32.0MB
P25 (DEVINFO) [0x96000000 0x100000] Size: 1.0MB
P26 (KEYSTORE) [0x98000000 0x80000] Size: 512.0KB
P27 (OEM) [0x98080000 0x4000000] Size: 64.0MB
P28 (CONFIG) [0x9c080000 0x80000] Size: 512.0KB
P29 (USERDATA) [0x9c100000 0x4cefbe00] Size: 1.201GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000E18C000 (800.0MB)
Build ID:  MMB29M
Display Build ID:  LYF-F90M-000-02-17-270917
Release Base ID:  6.0.1
Device Model:  F90M
Device Name:  F90M
Device manufacturer:  LYF
Release Incremental ID:  LYF-F90M-000-02-17-270917
Architecture ABI:  armeabi-v7a
Device Platform:  msm8909
Product ID:  msm8909_512
Build Description:  msm8909_512-user 6.0.1 MMB29M eng.cme.20170927.123526 test-keys
Selected Qualcomm Interface
Operation status: 0 Success
Read Flash:
Write Flash:
Reset USER Lock:
Note:All Work Done Via EDL Mode
Thanks & Regards By:All TECH 4 You
The Following 14 Users Say Thank You to Yashbanswara For This Useful Post:
Old 12-30-2018, 08:54   #2 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Once Again Jio F120B Read Info,Read Flash Done In Easy JTAG Classic 3.4 Via EDL Mode
Today I Do Once Again Jio F120B Read Info & Read Flash Successfully In Easy JTAG Classic 3.4
Note:All Work Done Via EDL Mode Only
Read Info:
Read Flash:
Read Info & Read Flash LOG Here:
Using Port :COM103
Using EDL Programmer :Z:\Chinese Firmware\JIO\Priemium Files\Jio     F120B\J120B New Firmware (  Build Number=LYF-F120B-001-02-04-23818  )  In Easy JTAG Format\prog_emmc_firehose_8909_ddr.mbn
Sahara Downloading flash programmer: Z:\Chinese Firmware\JIO\Priemium Files\Jio     F120B\J120B New Firmware (  Build Number=LYF-F120B-001-02-04-23818  )  In Easy JTAG Format\prog_emmc_firehose_8909_ddr.mbn
Device Class:sahara
Emergency Mode:true
 GPT: present
Build ID:  MMB29M
Display Build ID:  LYF-F120B-001-02-04-230818
Release Incremental ID:  LYF-F120B-001-02-04-230818
Device Model:  F120B
Device Name:  F120B
Device manufacturer:  Jio
Build Description:  msm8909_512-user 6.0.1 MMB29M eng.buildsystem4.20180823.203401 dev-keys
Using Port :COM103
Connecting to device without external programmers...
Device Class:sahara
Emergency Mode:true
 GPT: present
Save GPT partition to XML file
Download MODEM size 0x4000000:
Downloaded raw image at speed   9.1429 MB/s
Download SBL1 size 0x80000:
Downloaded raw image at speed   0.5000 MB/s
Download SBL1BAK size 0x80000:
Download ABOOT size 0x100000:
Downloaded raw image at speed   1.0000 MB/s
Download ABOOTBAK size 0x100000:
Download RPM size 0x80000:
Download RPMBAK size 0x80000:
Download TZ size 0xC0000:
Downloaded raw image at speed   0.7500 MB/s
Download TZBAK size 0xC0000:
Download PAD size 0x100000:
Download MODEMST1 size 0x180000:
Downloaded raw image at speed   1.5000 MB/s
Download MODEMST2 size 0x180000:
Download MISC size 0x100000:
Download FSC size 0x400:
Downloaded raw image at speed   0.0010 MB/s
Download SSD size 0x2000:
Downloaded raw image at speed   0.0078 MB/s
Download SPLASH size 0xA00000:
Downloaded raw image at speed   5.0000 MB/s
Download DDR size 0x8000:
Downloaded raw image at speed   0.0312 MB/s
Download FSG size 0x180000:
Download SEC size 0x4000:
Downloaded raw image at speed   0.0156 MB/s
Download BOOT size 0x2000000:
Downloaded raw image at speed   6.4000 MB/s
Download SYSTEM size 0x32000000:
Downloaded raw image at speed   9.6386 MB/s
Download PERSIST size 0x2000000:
Downloaded raw image at speed   8.0000 MB/s
Download USBMSC size 0x3E800000:
Downloaded raw image at speed   8.4746 MB/s
Download CACHE size 0x10000000:
Downloaded raw image at speed   9.4815 MB/s
Download RECOVERY size 0x2000000:
Download DEVINFO size 0x100000:
Download KEYSTORE size 0x80000:
Download OEM size 0x4000000:
Download CONFIG size 0x80000:
Download USERDATA size 0x4CEFBE00:
Downloaded raw image at speed   8.8560 MB/s
T
The Following 3 Users Say Thank You to Yashbanswara For This Useful Post:
Old 12-30-2018, 16:28   #3 (permalink)
Nishan_Raja's Avatar
Member: 2554807
Thanks Meter: 612
Oppo a33 read info / read firmarw /reset code with easy -jtaj
OPPO A33 READ INFO / READ FIRMARW /RESET CODE WITH EASY -JTAG
READ INFO
Device Class:sahara
Emergency Mode:true
Reading QC Device information...
Firehose protocol already booted
Using Port :COM3
Device Class:sahara
Emergency Mode:true
GPT: present
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Last usable sector: 30535646
Found Data areas (firmware parts) count is: 37
P0 (MODEM) [0x800000 0x4000000] Size: 64.0MB
P1 (DDR) [0x4800000 0x8000] Size: 32.0KB
P2 (FSG) [0x4808000 0x180000] Size: 1.500MB
P3 (SEC) [0x4988000 0x4000] Size: 16.0KB
P4 (FSC) [0x5000000 0x400] Size: 1.0KB
P5 (SSD) [0x5000400 0x2000] Size: 8.0KB
P6 (SBL1) [0x5002400 0x80000] Size: 512.0KB
P7 (SBL1BAK) [0x5082400 0x80000] Size: 512.0KB
P8 (ABOOT) [0x5800000 0x100000] Size: 1.0MB
P9 (ABOOTBAK) [0x5900000 0x100000] Size: 1.0MB
P10 (RPM) [0x6000000 0x80000] Size: 512.0KB
P11 (RPMBAK) [0x6080000 0x80000] Size: 512.0KB
P12 (TZ) [0x6100000 0x80000] Size: 512.0KB
P13 (TZBAK) [0x6180000 0x80000] Size: 512.0KB
P14 (HYP) [0x6200000 0x80000] Size: 512.0KB
P15 (HYPBAK) [0x6280000 0x80000] Size: 512.0KB
P16 (MODEMST1) [0x6300000 0x180000] Size: 1.500MB
P17 (MODEMST2) [0x6480000 0x180000] Size: 1.500MB
P18 (OPPODYCNVBK) [0x6600000 0xa00000] Size: 10.0MB
P19 (OPPOSTANVBK) [0x7000000 0xa00000] Size: 10.0MB
P20 (LOGO) [0x7a00000 0x1000000] Size: 16.0MB
P21 (BOOT) [0x9000000 0x2000000] Size: 32.0MB
P22 (RECOVERY) [0xb000000 0x2000000] Size: 32.0MB
P23 (SYSTEM) [0xd000000 0x94000000] Size: 2.312GB
P24 (DEVINFO) [0xa1000000 0x100000] Size: 1.0MB
P25 (CACHE) [0xa1800000 0x8000000] Size: 128.0MB
P26 (PERSIST) [0xa9800000 0x2000000] Size: 32.0MB
P27 (MISC) [0xab800000 0x100000] Size: 1.0MB
P28 (KEYSTORE) [0xab900000 0x80000] Size: 512.0KB
P29 (CONFIG) [0xab980000 0x8000] Size: 32.0KB
P30 (OEM) [0xab988000 0x4000000] Size: 64.0MB
P31 (DRIVER) [0xaf988000 0x2000000] Size: 32.0MB
P32 (RESERVE1) [0xb1988000 0x200000] Size: 2.0MB
P33 (RESERVE2) [0xb1b88000 0x1000000] Size: 16.0MB
P34 (RESERVE3) [0xb2b88000 0x200000] Size: 2.0MB
P35 (RESERVE4) [0xb2d88000 0x1000000] Size: 16.0MB
P36 (USERDATA) [0xb3d88000 0x2f0073e00] Size: 11.750GB
Detected LINUX(Android) SYSTEM : 0x000D000000 (2.312GB)
Device Model: A33f
Device Name: A33f
Product ID: A33f
Display Build ID: A33fEX_11_170531
Build ID: LMY47V
Release Incremental ID: eng.root.20170531
Release Base ID: 5.1.1
Device manufacturer: OPPO
Device Platform: msm8916
Build Description: msm8916_32-user 5.1.1 LMY47V eng.root.20170531 release-keys
READ FIRMWARE
Using Port :COM3
Device Class:sahara
Emergency Mode:true
GPT: present
Downloaded raw image at speed 10.6667 MB/s
Download TZ size 0x80000:
Download TZBAK size 0x80000:
Download HYP size 0x80000:
Download HYPBAK size 0x80000:
Download OPPODYCNVBK size 0xA00000:
Download OPPOSTANVBK size 0xA00000:
Download LOGO size 0x1000000:
Download SYSTEM size 0x94000000:
Downloaded raw image at speed 12.8696 MB/s
Download CACHE size 0x8000000:
Downloaded raw image at speed 12.8000 MB/s
Download CONFIG size 0x8000:
Download DRIVER size 0x2000000:
Download RESERVE1 size 0x200000:
Downloaded raw image at speed 2.0000 MB/s
Download RESERVE2 size 0x1000000:
Download RESERVE3 size 0x200000:
Download RESERVE4 size 0x1000000:
Download USERDATA size 0x2F0073E00:
Downloaded raw image at speed 13.2080 MB/s
RESET CODE
Device Class:sahara
Emergency Mode:true
GPT: present
Detected LINUX(Android) USERDATA : 0x00B3D88000 (11.750GB)
Mount EXT4 fs...
Starting EXT4 journal...
Removing 2: /d/system/locksettings.db ...
Removing 2: /d/system/locksettings.db-wal ...
Removing 2: /d/system/locksettings.db-shm ...
Shutting down EXT4...
BR NISHAN RAJA
The Following User Says Thank You to Nishan_Raja For This Useful Post:
Old 12-31-2018, 08:39   #4 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Jio F120B Forensic Explorer DataRecover Successfully In Easy JTAG Plus Suite v1.5.3.0
Hello Everyone
Today In My Shop Jio F120B With Hang On LOGO Condition But Customer Data Was Important So I Do This By Easy JTAG Plus Suite v1.5.3.0 By Jio F120B Forensic Explorer Data Recover Successfully
In Now Days Easy JTAG Will Give Chance Make More Money By Easy JTAG
Image Recover Successfully
The Following 4 Users Say Thank You to Yashbanswara For This Useful Post:
Old 01-02-2019, 16:58   #5 (permalink)
Member: 1613469
Thanks Meter: 192
Xiaomi Redmi Note 5A msm8917
read info, backup gpt 100%
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
The Following 3 Users Say Thank You to washipolar For This Useful Post:
Old 01-06-2019, 05:07   #6 (permalink)
Member: 2226456
Sonork: jerrenn
Thanks Meter: 83
oppo a37f pattern remove by easy jtag plus via usb method
tnx easy jtag plus team
The Following User Says Thank You to jennydahan For This Useful Post:
Old 01-11-2019, 14:58   #7 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Xiaomi Redmi 5A ( MCI3B ) FRP Remove Done By Easy JTAG Plus 1.5.3.0 Via EDL Mode Only
Today In My Shop Come Xiaomi Redmi 5A ( MCI3B ) With FRP Lock Than I Do This
1.Click Remove FRP
2.From HS-QDLoader 9008
3.Custom Loader
4.Select Qualcomm_Factory_Loader_MSM8917_Xiaomi
5.Finally Got Success & Remove FRP Sucessfully
LOG Here:
Operation: Remove FRP
Search HS-USB QDLoader 9008 devices ...
Qualcomm HS-USB QDLoader 9008 (COM6) is connected
Connect to Sahara ...
Connection with Sahara was successful
Serial: 0x0000000082DE1D53
HW_ID: 0x000560E100000000
HASH: 0x57158EAF1814D78FD2B3105ECE4DB18A817A08AC664A5782A925F3FF8403D39A
SBL_SW: 0x0000000000000000
CPU: Qualcomm Snapdragon 425 (MSM8917)
Firehose Info:
SBL_SW: 0x0000000000000003
MSM: MSM8917
Sending FlashLoader. Please, wait ...
FlashLoader was successfully uploaded to the device.
Connect to FlashLoader ...
   EMMC NAME: HBG4a2  Vendor: SKHYNIX  S/N: 1D39D402
   EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
Connection with FlashLoader was successful
Searching GPT ...
GPT header is found and is valid
GPT header successfully parsed
FRP partition found (partname: config)
Erasing FRP partition ...
If the device does not load for a long time - try wiping the data in the recovery
All done
In Now Days Easy JTAG Giving Chance Make More Money By Easy JTAG
So Take More Mobile & Make More Money By Easy JTAG
The Following User Says Thank You to Yashbanswara For This Useful Post:
Old 01-12-2019, 09:06   #8 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Jio F220B Read Info,Read Flash,Write Flash Done By EasyJTAG Classic 3.4 Via EDL Mode
Hello Everyone Today I Do Once Again Jio F220B Read Info ,Read Flash & Write Flash Successfully In Easy JTAG Classic 3.4
Read Info:
Read XML Firmware Successfully:
Write XML Firmware Successfully:
In Now Days Easy JTAG Giving Chance Make More Money By Easy JTAG So Take More Mobile & Make More Money By Easy JTAG
Old 01-12-2019, 14:34   #9 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Lenovo Vibe C ( A2020a40 ) Read Info & FRP Done By Easy JTAG Plus Via EDL Mode Only
Read Info:
Read Info LOG Here
Using Port :COM13
Using EDL Programmer :C:\Program Files\Z3X\EASYJTAG\Loaders\prog_emmc_firehose_8909_ddr.mbn
Sahara Downloading flash programmer: C:\Program Files\Z3X\EASYJTAG\Loaders\prog_emmc_firehose_8909_ddr.mbn
Device Class:sahara
Emergency Mode:true
 GPT: present
Found Data areas (firmware parts) count is: 29
P20 (SYSTEM) [0xe18c000 0x93333800] Size: 2.299GB
P21 (PERSIST) [0xa14bf800 0x2000000] Size: 32.0MB
P22 (CACHE) [0xa34bf800 0x10000000] Size: 256.0MB
P23 (RECOVERY) [0xb34bf800 0x2000000] Size: 32.0MB
P24 (DEVINFO) [0xb54bf800 0x100000] Size: 1.0MB
P25 (KEYSTORE) [0xb8000000 0x80000] Size: 512.0KB
P26 (OEM) [0xb8080000 0x4000000] Size: 64.0MB
P27 (CONFIG) [0xbc080000 0x80000] Size: 512.0KB
P28 (USERDATA) [0xbc100000 0x2e7cfbe00] Size: 11.621GB
Detected LINUX(Android) SYSTEM : 0x000E18C000 (2.299GB)
Build ID:  LMY47V
Display Build ID:  A2020a40_S197_170717_ROW
Release Incremental ID:  A2020a40_USR_S197_1707170945_Q8909_ROW
Device Model:  Lenovo A2020a40
Device Name:  angus3A4
Device manufacturer:  LENOVO
Product ID:  angus3A4
Build Description:  angus3A4-user 5.1.1 LMY47V A2020a40_S197_170717_ROW release-keys
FRP Remove Successfully
FRP Remove LOG Here
Serial: 0x0000000007D00D0A
HW_ID: 0x009600E100000000
HASH: 0xCC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998421ADAD42A380F
CPU: Qualcomm Snapdragon 210 (MSM8909)
Firehose Info:
MSM: MSM8909
   EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
Searching GPT ...
All done
Old 01-14-2019, 07:48   #10 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Oppo A57 ( CPH1701 ) Read Info & FRP Remove Done By Easy JTAG Via EDL Mode Only
Read Info Successfully:
Read Info LOG Here
Using Port :COM13
Using EDL Programmer :C:\Program Files\Z3X\EASYJTAG\Loaders\msm_8937_v4.mbn
Sahara Downloading flash programmer: C:\Program Files\Z3X\EASYJTAG\Loaders\msm_8937_v4.mbn
Device Class:sahara
Emergency Mode:true
 GPT: present
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Last usable sector: 61071326
Found Data areas (firmware parts) count is: 56
P0 (MODEM) [0x800000 0x8000000] Size: 128.0MB
P1 (FSC) [0x8800000 0x400] Size: 1.0KB
P2 (SSD) [0x8800400 0x2000] Size: 8.0KB
P3 (SBL1) [0x8802400 0x80000] Size: 512.0KB
P4 (SBL1BAK) [0x8882400 0x80000] Size: 512.0KB
P5 (RPM) [0x8902400 0x80000] Size: 512.0KB
P6 (RPMBAK) [0x8982400 0x80000] Size: 512.0KB
P7 (TZ) [0x8a02400 0x200000] Size: 2.0MB
P8 (TZBAK) [0x8c02400 0x200000] Size: 2.0MB
P9 (DEVCFG) [0x8e02400 0x40000] Size: 256.0KB
P10 (DEVCFGBAK) [0x8e42400 0x40000] Size: 256.0KB
P11 (DSP) [0x8e82400 0x1000000] Size: 16.0MB
P12 (MODEMST1) [0x9e82400 0x180000] Size: 1.500MB
P13 (MODEMST2) [0xa002400 0x180000] Size: 1.500MB
P14 (OPPODYCNVBK) [0xa182400 0xa00000] Size: 10.0MB
P15 (OPPOSTANVBK) [0xab82400 0xa00000] Size: 10.0MB
P16 (LOGO) [0xb582400 0x1000000] Size: 16.0MB
P17 (DDR) [0xc800000 0x8000] Size: 32.0KB
P18 (FSG) [0xc808000 0x180000] Size: 1.500MB
P19 (SEC) [0xc988000 0x4000] Size: 16.0KB
P20 (SPLASH) [0xd000000 0xb00000] Size: 11.0MB
P21 (ABOOT) [0xe000000 0x100000] Size: 1.0MB
P22 (ABOOTBAK) [0xe100000 0x100000] Size: 1.0MB
P23 (BOOT) [0xe200000 0x4000000] Size: 64.0MB
P24 (RECOVERY) [0x12200000 0x4000000] Size: 64.0MB
P25 (DEVINFO) [0x16200000 0x100000] Size: 1.0MB
P26 (CACHE) [0x16800000 0x10000000] Size: 256.0MB
P27 (SYSTEM) [0x26800000 0x10c000000] Size: 4.187GB
P28 (PERSIST) [0x132800000 0x2000000] Size: 32.0MB
P29 (MISC) [0x134800000 0x100000] Size: 1.0MB
P30 (KEYSTORE) [0x134900000 0x80000] Size: 512.0KB
P31 (CONFIG) [0x134980000 0x8000] Size: 32.0KB
P32 (OEM) [0x134988000 0x10000000] Size: 256.0MB
P33 (LIMITS) [0x145000000 0x8000] Size: 32.0KB
P34 (MOTA) [0x145800000 0x80000] Size: 512.0KB
P35 (DIP) [0x145880000 0x100000] Size: 1.0MB
P36 (MDTP) [0x145980000 0x2000000] Size: 32.0MB
P37 (SYSCFG) [0x147980000 0x80000] Size: 512.0KB
P38 (MCFG) [0x147a00000 0x400000] Size: 4.0MB
P39 (CMNLIB) [0x148000000 0x40000] Size: 256.0KB
P40 (CMNLIBBAK) [0x148040000 0x40000] Size: 256.0KB
P41 (CMNLIB64) [0x148080000 0x40000] Size: 256.0KB
P42 (CMNLIB64BAK) [0x1480c0000 0x40000] Size: 256.0KB
P43 (KEYMASTER) [0x148100000 0x40000] Size: 256.0KB
P44 (KEYMASTERBAK) [0x148140000 0x40000] Size: 256.0KB
P45 (APDP) [0x148800000 0x40000] Size: 256.0KB
P46 (MSADP) [0x148840000 0x40000] Size: 256.0KB
P47 (DPO) [0x148880000 0x2000] Size: 8.0KB
P48 (DRIVER) [0x148882000 0x2000000] Size: 32.0MB
P49 (RESERVE1) [0x14a882000 0x200000] Size: 2.0MB
P50 (RESERVE2) [0x14aa82000 0x1000000] Size: 16.0MB
P51 (RESERVE3) [0x14ba82000 0x200000] Size: 2.0MB
P52 (RESERVE4) [0x14bc82000 0x1000000] Size: 16.0MB
P53 (RESERVE_EXP1) [0x14cc82000 0x200000] Size: 2.0MB
P54 (RESERVE_EXP2) [0x14ce82000 0x200000] Size: 2.0MB
P55 (USERDATA) [0x14d082000 0x5fab79e00] Size: 23.916GB
Detected LINUX(Android) SYSTEM : 0x0026800000 (4.187GB)
Device Model:  CPH1701
Device Name:  CPH1701
Product ID:  CPH1701
Display Build ID:  CPH1701EX_11_A.34_180806
Build ID:  MMB29M
Release Incremental ID:  eng.root.20180806.181819
Architecture ABI:  arm64-v8a
Device Platform:  msm8937
Build Description:  msm8937_64-user 6.0.1 MMB29M eng.root.20180806.181819 release-keys
FRP Remove Successfully LOG Here
Qualcomm HS-USB QDLoader 9008 (COM13) is connected
Serial: 0x00000000B31FC415
HW_ID: 0x0006B0E100000000
HASH: 0x77A22B92A1BCD0C4D3AAA10AA9F1B2C36D51C0CA7429B5201D0FD1D5F5B53BBC
CPU: Qualcomm Snapdragon 435 (MSM8940)
Firehose Info:
MSM: MSM8937
   EMMC NAME: HBG4a2  Vendor: SKHYNIX  S/N: 5591648C
Searching GPT ...
All done
Old 01-14-2019, 10:58   #11 (permalink)
Member: 575256
Thanks Meter: 34
Redmi 4A FRP done miui10
eMMC_tool Suite ver. 1.5.3.0 (release date: 28.12.2018)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.23403)
Looking for EasyJTAG box...
EasyJTAG API ver. 2201
EasyJTAG Box Serial = 0100200464C04934
Card Serial = AAA49DD1
EasyJTAG Box Firmware = 1.63
Changelog:
28.12.2018 (ver 1.5.3.0)
Fix: Bugs that have been found through your crash report
Fix: Scatter file processing (MTK)
Fix: Contact Extractor
Fix: Preloader parser
Fix: FAT partitions mounting
Fix: Minor interface changes
Add: Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
Add: Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
Add: Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
Add: Auto/Manual loaders select for Qualcom HS-USB QDLoader 9008 interface
Add: Samsung firmware lz4 unpack support (Write by vendor - Samsung)
Add: Import from cm2qlm xml backups (Write by vendor - Qualcomm)
Add: Unpack Bootloader.img archive from Motorola firmware files
Add: Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
Add: Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
Add: Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
Add: Explorer: Pin and Password decoding (only English and Russian letters)
Qualcomm HS-USB QDLoader 9008 (COM41) is connected
Serial: 0x00000000B4AD767E
HASH: 0x57158EAF1814D78FD2B3105ECE4DB18A817A08AC664A5782 A925F3FF8403D39A
Internal loader found
EMMC NAME: QX13MB Vendor: SAMSUNG S/N: BEC3F228
Searching GPT ...
All done
The Following 2 Users Say Thank You to sbycell For This Useful Post:
Old 01-15-2019, 09:26   #12 (permalink)
Member: 575256
Thanks Meter: 34
Originally Posted by sbycell View Post
It is screnshoot frp redmiA miui
The Following User Says Thank You to sbycell For This Useful Post:
Old 01-19-2019, 14:42   #13 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Vivo V9 ( 1723 ) FRP Remove Done By Easy JTAG Plus On EDL Mode Only
Hello Everyone Today In My Shop Come Vivo V9 ( 1723 ) With FRP Lock Than I Do This In Easy JTAG Plus & Finally FRP Remove Successfully
FRP Remove Successfully By Easy jtag Plus
Log Here:
Serial: 0x0000000038FCD7EF
HW_ID: 0x000460E100000000
HASH: 0x60BA997FEF6DA9F05885FA11F1DD6D2A90D052A257A09C2075D7246CC73C0D43
CPU: Qualcomm Snapdragon 625 (MSM8953)
   EMMC NAME: RH64AB  Vendor: SAMSUNG  S/N: A0EADA40
   EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
Searching GPT ...
All done
Old 01-19-2019, 15:26   #14 (permalink)
Member: 729012
Thanks Meter: 3
Asus zb602kl
HS-USB QDLoader 9008 not found
Qualcomm HS-USB QDLoader 9008 (COM10) is connected
Serial: 0x0000000000DDE09D
HW_ID: 0x000CC0E100000000
HASH: 0x7CD366EF83A08283AFD180486C2DDF0BEF4327ECF6C5DB07 CA461A68BC22C6C4
CPU: Qualcomm Snapdragon 636 (SDM636)
Firehose Info:
HW_ID: 0x3006000000000000
MSM: SDM660
The selected firehose may not be compatible with this device.
It may damage your device.
EMMC NAME: DH6DMB S/N: 77F2908C
Searching GPT ...
FRP partition found (partname: frp)
All done
The Following User Says Thank You to ed_mobstyle For This Useful Post:
Old 01-29-2019, 06:45   #15 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Redmi Note 4G (2014912) Remove User Lock Without Lose Any DATA By Easy JTAG Plus
Today In My Shop Come Xiaomi Redmi Mi Note 4g (2014912) HM NOTE 1S With Lock But Customer Was Saying His DATA Important So I Do This In Easy JTAG Plus & Finally User Unlock Done Without Lose Any Data.
Read Info
LOG Here
Using Port :COM13
Using EDL Programmer :C:\Program Files\Z3X\EASYJTAG\Loaders\Qualcomm_Factory_Loader_MSM8916_Xiaomi.mbn
Sahara Downloading flash programmer: C:\Program Files\Z3X\EASYJTAG\Loaders\Qualcomm_Factory_Loader_MSM8916_Xiaomi.mbn
Device Class:sahara
Emergency Mode:true
Caution: invalid backup GPT header, but valid main header!
 GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB
Last usable sector: 30777310
P0 (SBL1) [0x4400 0x80000] Size: 512.0KB
P1 (SBL1BAK) [0x84400 0x80000] Size: 512.0KB
P2 (ABOOT) [0x104400 0x100000] Size: 1.0MB
P3 (ABOOTBAK) [0x204400 0x100000] Size: 1.0MB
P4 (RPM) [0x304400 0x80000] Size: 512.0KB
P5 (RPMBAK) [0x384400 0x80000] Size: 512.0KB
P6 (TZ) [0x404400 0x80000] Size: 512.0KB
P7 (TZBAK) [0x484400 0x80000] Size: 512.0KB
P8 (HYP) [0x504400 0x80000] Size: 512.0KB
P9 (HYPBAK) [0x584400 0x80000] Size: 512.0KB
P10 (PAD) [0x604400 0x100000] Size: 1.0MB
P11 (MODEMST1) [0x704400 0x180000] Size: 1.500MB
P12 (MODEMST2) [0x884400 0x180000] Size: 1.500MB
P13 (MISC) [0xa04400 0x100000] Size: 1.0MB
P14 (FSC) [0xb04400 0x400] Size: 1.0KB
P15 (SSD) [0xb04800 0x2000] Size: 8.0KB
P16 (SPLASH) [0xb06800 0xa00000] Size: 10.0MB
P17 (KEYSTORE) [0x1506800 0x80000] Size: 512.0KB
P18 (CONFIG) [0x1586800 0x8000] Size: 32.0KB
P19 (OEM) [0x158e800 0x4000000] Size: 64.0MB
P20 (DDR) [0x8000000 0x8000] Size: 32.0KB
P21 (MODEM) [0x8008000 0x4000000] Size: 64.0MB
P22 (FSG) [0xc008000 0x180000] Size: 1.500MB
P23 (SEC) [0xc188000 0x4000] Size: 16.0KB
P24 (BOOT) [0xc18c000 0x2000000] Size: 32.0MB
P25 (SYSTEM) [0xe18c000 0x60000000] Size: 1.500GB
P26 (PERSIST) [0x6e18c000 0x2000000] Size: 32.0MB
P27 (CACHE) [0x7018c000 0x18000000] Size: 384.0MB
P28 (RECOVERY) [0x8818c000 0x2000000] Size: 32.0MB
P29 (USERDATA) [0x8a18c000 0x32126fe00] Size: 12.517GB
Detected LINUX(Android) SYSTEM : 0x000E18C000 (1.500GB)
Build ID:  KTU84P
Display Build ID:  KTU84P
Release Incremental ID:  V9.2.3.0.KHKMIEK
Release Base ID:  4.4.4
Device Name:  *****
Product ID:  *****
Build Description:  *****-user 4.4.4 KTU84P V9.2.3.0.KHKMIEK release-keys
Device manufacturer:  Xiaomi
Device Model:  HM NOTE 1S
Remove User Lock Without Lose Any Data Successfully
[CENTER][CENTER]
LOG Here
Operation: Remove Android Locks
Serial: 0x00000000138D9D17
HW_ID: 0x007050E100000000
CPU: Qualcomm Snapdragon 410 (MSM8916)
   EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
Searching GPT ...
Mount [modem] successfully   PartType: FAT16
Mount [system] successfully   PartType: LINUX
Mount [persist] successfully   PartType: LINUX
Mount [cache] successfully   PartType: LINUX
Mount [data] successfully   PartType: LINUX
Delete object: data/system/password.key
Delete object: data/system/gesture.key
Delete object: data/system/locksettings.db
Delete object: data/system/locksettings.db-wal
Delete object: data/system/locksettings.db-shm
All done
Now Customer Happy & I Am Also Happy
So feel the power Of Easy JTAG
Page generated in 0.55657 seconds with 8 queries
