03-13-2020, 16:24 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: IRAN Age: 39
Member: 1391134 Status: Offline Thanks Meter: 47 | jkm-lx1 boot repair done eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 0A00E013F603DAEE Card Serial = AAEC997E EasyJTAG Box Firmware = 1.63 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report HiPower mode is ON Setting frequence to 3 MHz CMD Pullup Level: 3145 mV CMD Active Level: 3248 mV EMMC Device Information : EMMC CID: 13014E53304A333859100D4B2A58269A EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: S0J38Y_0D4B2A58_20200313_003039.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: bota1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: efs, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: cpefs, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: carrier, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: param, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: boot, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: recovery, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: ota, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: cdma-radio, [000008B00000 - 000008F00000], size: 000000400000 (4.00 MB) Partition: radio, [000008F00000 - 00000E700000], size: 000005800000 (88.0 MB) Partition: tombstones, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB) Partition: dnt, [00000E800000 - 00000E900000], size: 000000100000 (1.00 MB) Partition: persistent, [00000E900000 - 00000E980000], size: 000000080000 (512. KB) Partition: persdata, [00000E980000 - 00000F580000], size: 000000C00000 (12.0 MB) Partition: reserved2, [00000F580000 - 00000F800000], size: 000000280000 (2.50 MB) Partition: system, [00000F800000 - 000093000000], size: 000083800000 (2.05 GB) Partition: cache, [000093000000 - 00009F800000], size: 00000C800000 (200. MB) Partition: hidden, [00009F800000 - 0000A2000000], size: 000002800000 (40.0 MB) Partition: userdata, [0000A2000000 - 000747C00000], size: 0006A5C00000 (26.5 GB) GPT header successfully parsed Get firmware version Firmware info not found HiPower mode is ON Setting frequence to 3 MHz CMD Pullup Level: 3165 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 13014E53304A333859100D4B2A58269A EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: S0J38Y_0D4B2A58_20200313_003707.extcsd EMMC Init completed. Opening file: JKM-BD_1.0.0.29_Download.xml HiPower mode is ON Setting frequence to 3 MHz CMD Pullup Level: 3155 mV CMD Active Level: 3258 mV EMMC Device Information : EMMC CID: 13014E53304A333859100D4B2A58269A EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: S0J38Y_0D4B2A58_20200313_003729.extcsd EMMC Init completed. Opening file: Hisi_AT_Partially_Erase_kirin670.xml HiPower mode is ON Setting frequence to 3 MHz CMD Pullup Level: 3165 mV CMD Active Level: 3248 mV EMMC Device Information : EMMC CID: 13014E53304A333859100D4B2A58269A EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: S0J38Y_0D4B2A58_20200313_003758.extcsd EMMC Init completed. Opening file: JKM-BD_1.0.0.29_Download.xml HiPower mode is ON Setting frequence to 3 MHz CMD Pullup Level: 3145 mV CMD Active Level: 3248 mV EMMC Device Information : EMMC CID: 13014E53304A333859100D4B2A58269A EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: S0J38Y_0D4B2A58_20200313_003918.extcsd EMMC Init completed. Opening file: JKM-BD_1.0.0.29_Download.xml HiPower mode is ON Setting frequence to 3 MHz CMD Pullup Level: 3135 mV CMD Active Level: 3248 mV EMMC Device Information : EMMC CID: 13014E53304A333859100D4B2A58269A EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: S0J38Y_0D4B2A58_20200313_003931.extcsd EMMC Init completed. Opening file: JKM-BD_1.0.0.29_Download.xml HiPower mode is ON Setting frequence to 3 MHz CMD Pullup Level: 3165 mV CMD Active Level: 3269 mV EMMC Device Information : EMMC CID: 13014E53304A333859100D4B2A58269A EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: S0J38Y_0D4B2A58_20200313_004638.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x08 Reg: 177 Value: 0x02 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: boot1.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 108.93 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: boot2.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 108.93 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000100000000 Filename: userarea_4GiB.bin eMMC switching to ROM1 Writing partition... Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #1 Done writing partition. Write speed: 177.82 KB/s All done time: [06:34:24:918] after boot repair with easy jtag phone is ok txxxxx z3x team |
The Following 4 Users Say Thank You to sagad For This Useful Post: |
03-16-2020, 01:06 | #3 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | you could write board firmware by write by vendor https://firmware.gem-flash.com/index...file&id=133599 |
The Following User Says Thank You to abo anas zayan For This Useful Post: |
