02-04-2014, 21:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | GT-i9300 NO PRODUCT - successfully repair with easy jtag - Step by step inside logs Loading eMMC Addon Firmware... CMD Pullup Level:1237 mV CMD Active Level:1722 mV EMMC CID 15010056545530304DF1F5C216FF6F5F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 4123137791 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_4123137791_20140102_1034.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1258 mV CMD Active Level:1722 mV EMMC CID 15010056545530304DF1F5C216FF6F5F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 4123137791 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_4123137791_20140102_1035.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:SAMSUNG: MoviNAND Format... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1258 mV CMD Active Level:1711 mV EMMC CID 15010056545530304DF1F5C216FF6F5F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 4123137791 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_4123137791_20140102_1035.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:Repair extCSD... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1237 mV CMD Active Level:1701 mV EMMC CID 15010056545530304DF1F5C216FF6F5F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 4123137791 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1227 mV CMD Active Level:1701 mV EMMC CID 15010056545530304DF1F5C216FF6F5F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 4123137791 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 222 kB/s Done !!! <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1227 mV CMD Active Level:1732 mV EMMC CID 15010056545530304DF1F5C216FF6F5F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 4123137791 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 222 kB/s Done !!! |
The Following 17 Users Say Thank You to drjaved_akhter For This Useful Post: |
02-08-2014, 11:06 | #7 (permalink) |
Freak Poster Join Date: Aug 2006 Location: kanpur
Member: 330372 Status: Offline Thanks Meter: 26 | really nice sir result of hard work but i fail to do every time weather its for wright rom 1 or rom2 i thing i am not able to connect phone properly i read lots mostly written connect properly please upload screen shot of your connected pcs with wire if possible it will help me lot thank you |
02-08-2014, 16:55 | #8 (permalink) | |
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
bro z3x support pinout see and enjoy great team z3x hard working result good luck | |
02-08-2014, 20:44 | #10 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | one more no product ok THANKS Z3X TEAM................. LOGS Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1691 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3224591479_20140003_0628.extcsd Done. <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!</font> CMD Active Level:1701 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3224591479_20140003_0629.extcsd Done. <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!</font> CMD Active Level:1701 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3224591479_20140003_0629.extcsd Done. <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1206 mV CMD Active Level:1711 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 116 kB/s Done !!! Running:SAMSUNG: BOOT and RPMB resize... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1216 mV CMD Active Level:1670 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3224591479_20140003_0630.extcsd Sending Internal Reconfiguration Request for BOOT ... Waiting for configuration Apply!!! Sending Internal Reconfiguration Request for RPMB ... BOOT1 and BOOT2 Size Set to : 0 KB RPMB Size Set to : 0 KB Waiting for configuration Apply!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1206 mV CMD Active Level:1711 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3224591479_20140003_0634.extcsd Done. Running:SAMSUNG: BOOT and RPMB resize... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1206 mV CMD Active Level:1701 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3224591479_20140003_0634.extcsd Sending Internal Reconfiguration Request for BOOT ... Waiting for configuration Apply!!! Sending Internal Reconfiguration Request for RPMB ... BOOT1 and BOOT2 Size Set to : 2048 KB RPMB Size Set to : 0 KB Waiting for configuration Apply!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1701 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3224591479_20140003_0657.extcsd Done. <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1216 mV CMD Active Level:1711 mV EMMC CID 15010056545530304DF7C0335C77CF0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0xf7 EMMC NAME: <b>VTU00M</b> , S/N: 3224591479 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 117 kB/s Done !!! |
The Following 5 Users Say Thank You to drjaved_akhter For This Useful Post: |
02-09-2014, 05:25 | #11 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | I Think Need This Thread With Sticky List For Easy Jtag User Who Have Don't Knowledge About eMMC Flashing Keep it Up Best Regard Bro:- Palash Ahammad |
The Following 5 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
02-09-2014, 09:57 | #13 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
