07-06-2018, 14:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | KMRX1000BM-B614 unable to patch cid (logs inside) Code: ---------- eMMC Device Information ---------- EMMC CID : 150100525831424D4207955CAC5CC34E EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2016 Rev.0x7 EMMC NAME: RX1BMB , S/N: 2505878620 EMMC NAME (HEX): 525831424D4200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RX1BMB_2505878620_20180705_1632.extcsd Done. Code: Running:SAMSUNG: CID patch... Writing CID! Skip loading eMMC Addon Firmware CMD Pullup Level:1969 mV CMD Active Level:2145 mV Box IO Level:1800 mV CLK Rate:21000 kHz Repairing eMMC CID... Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch ! Code: ---------- eMMC Device Information ---------- EMMC CID : 150100525831424D4207955CAC5CC34E EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2016 Rev.0x7 EMMC NAME: RX1BMB , S/N: 2505878620 EMMC NAME (HEX): 525831424D4200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RX1BMB_2505878620_20180705_1635.extcsd Done. nothing changed... |
07-07-2018, 12:21 | #5 (permalink) | |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | Quote:
HAVE A LOOK HERE ALSO PLEASE | |
07-07-2018, 12:49 | #6 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote: Its not a bug of software , its new security eMMC boot code. | |
07-07-2018, 15:26 | #7 (permalink) | |
this is same emmc KMRX1000BM-B614 . post 1 logs are from same emmc | |
