-   Easy-Jtag (http://forum.gsmhosting.com/vbb/f672/)
-   -   lava pixel v1 emmc not connecting with emmc socket (http://forum.gsmhosting.com/vbb/f672/lava-pixel-v1-emmc-not-connecting-emmc-socket-2495378/)
Bhagat20 10-25-2018 14:23
i have lava pixel v1, it is dead after flash, i connected emmc with jtag emmc socket, but emmc not connecting with adaptor, giving below error:
Box Drivers version: 0.0.0.0
Z3X Card Serial : AA0B-B341 , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 6 serial devices
COM31 root\rimports RIM Virtual Serial Port v2 (COM31)
COM33 root\rimports RIM Virtual Serial Port v2 (COM33)
COM1 ACPI\PNP0501 Nuvoton Communications Port (COM1)
COM2 ACPI\PNP0501 Nuvoton Communications Port (COM2)
COM138 usb\vid_0bb4&pid_0005&mi_02 Android Gadget VCOM Driver (COM138)
COM7 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM7)
Selected pinout: GEN2 High Speed Pinout
Change EasyJTAG Pinout OK
Compression if OFF
Z3X EasyJtag Software ver. 3.2.0.3
Loading eMMC GEN2 Firmware... IO: 2800 mV
Initial pull results:
clock: 1840mV pin connected ok
command: 1854mV pin connected ok
data0: 1850mV pin connected ok
data1: 1840mV pin connected ok
data2: 1827mV pin connected ok
data3: 1848mV pin connected ok
data4: 1851mV pin connected ok
data5: 1838mV pin connected ok
data6: 1853mV pin connected ok
data7: 1850mV pin connected ok
Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.30
Box IO Level:2800 mV
CLK Rate:42000 kHz
Bus Width:8bit,SDR
HiPower mode is ON!
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
everytime only giving this error, please suggest can the above skhynix emmc connected with socket, or else how to connect?
Please someone help, how to connect emmc ic, with emmc socket or is there any test points to connect with adaptor?
layder 10-25-2018 20:16
All pin connected ok, emmc is Dead
Bhagat20 10-26-2018 06:07
Thank you for the reply but always showing this error in every phones connected, please check the box driver version in post #1, its showing 0.0.0.0,, I saw in other thread because old hardware they are having this problem, but I have new easy JTAG plus, still giving that error?
layder 10-26-2018 10:33
driver version information is not meaningful.
you should not give it important
I use EasyJTAG Plus software in the main (99% of time). Аnd do not pay attention to this kind of lettering
Bhagat20 10-26-2018 15:25
OK sir..... I have many phones in scrap with me like n7100, redmi note 3, redmi 2, and others, some hang on logo and some encryption unsuccessful, will try all that once I give back all customers phones, and see if I am able to connect those phones or not, because till now not even single phone connected with emmc pinouts and even with desoldered emmc in 3 weeks from the time I bought easy JTAG plus box, only getting 2 errors , 1-cmd timeout error and 2-emmc dead, will check all other phones soon.
layder 10-26-2018 17:17
It is very unlikely that you have a box hardware problem.
All box are tested during manufacture and before sale.
chenzuming 10-26-2018 17:45
pixel v1 is not emmc,this is ufs ic
Bhagat20 10-27-2018 04:58
Please refer the below link, this guy has repaired his pixel v1 emmc ic with easy jtag:
http://forum.gsmhosting.com/vbb/f672...g-box-2258257/
Pixel v1 had skhynix ic, is that supported with easy jtag socket? I am using windows 7 pack 1, is easy jtag plus compatible with win7? If there is any hardware problem in box will it be replaced? I'll still try on some other working phones as well after giving back customers phone.
Sir thank you for your support, finally micromax q372 emmc connected with socket :
q372 emmc logs:
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 90014A48384731650507DD0938AE52E7
EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: DD0938AE , rev. 0x07
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G1e_DD0938AE_20181027_185017.extcsd
EMMC Init completed.
Warning: Health report is very BAD
Device Life Time Estimation (MLC) [269]: 0x08 70% - 80% device life time used
Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used
Pre EOL information [267]: 0x01 Normal
Get firmware version
Brand = Micromax
Manufacturer = Micromax
Model = Micromax Q372
Phone platform = mt6582
CPU Abi = armeabi-v7a
Mediatek platform = MT6582
Android release = 5.0
Firmware version = ALPS.L0.MP2.V1_TINNO6582.WT.L_P18
Firmware date = Sat Aug 22 18:57:42 CST 2015
Please suggest how to repair?
layder 10-27-2018 21:17
Brand = Micromax
mediatek cpu phones you can flashing via flashtool
health status did not may be repaired.
EasyJTAG compatible wih windows 7/8/10, and XP
Pixel v1 is a mtk 6582 phone, it can work with BGA221 eMMC.
BGA221 eMMC is supported by EasyJTAG
Page generated in 0.27043 seconds with 5 queries
