10-07-2017, 15:25 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2463805 Status: Offline Thanks Meter: 32 | LG D325 Easy Jtag done but still dead I got a LG D325 , it was dead. but that has EMMC permanent write protection. I wrote Boot1 and Boot 2 but still dead , only showing care suite emergency connectivity on device manger. can I fix this issue or the problem in EMMC ? thank you. here the logs detection Code: eMMC_tool Suite ver. 1.4.8.0 Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 3.3V Setting frequence to 21 Mhz HiPower mode is OFF EasyJTAG Box Serial = Card Serial = EasyJTAG Box Firmware = 01.58 Changelog: 08.08.2017 (ver 1.4.8.0) Fix: Bugs that have been found through your crash report Fix: Saving VCF for contacts Add: Multiple file selection for Samsung firmware Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button) Add: Intel vendor (for easy read/write ROM2/ROM3/GP1) Add: "Pinouts" tab (taken from the catalog of classic software) Add: Checker for Sony TrimArea Add: Speed graph for "Random verify emmc" Add: Fat16/Fat32/exFat support (Explorer) HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 195 mV CMD Active Level: 3073 mV EMMC Device Information : EMMC CID: 1501004B3558564D4206EFFECCFD1268 EMMC CSD: D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2015 , Rev: 06 EMMC NAME: K5XVMB , S/N: EFFECCFD , rev. 06 EMMC NAME (HEX): 4B3558564D42 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K5XVMB_EFFECCFD_20171007_190854.extcsd EMMC Init completed. Get firmware version Error reading at address: 000000000000 ... Retry #1 Error reading at address: 000000000000 ... Retry #2 Error reading at address: 000000000000 ... Retry #3 Error reading at address: 000000000000 ... Retry #4 Error reading at address: 000000000000 ... Retry #5 Too many errors. Reading has been stopped Code: HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 195 mV CMD Active Level: 3073 mV EMMC Device Information : EMMC CID: 1501004B3558564D4206EFFECCFD1268 EMMC CSD: D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2015 , Rev: 06 EMMC NAME: K5XVMB , S/N: EFFECCFD , rev. 06 EMMC NAME (HEX): 4B3558564D42 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K5XVMB_EFFECCFD_20171007_190854.extcsd EMMC Init completed. Get firmware version Error reading at address: 000000000000 ... Retry #1 Error reading at address: 000000000000 ... Retry #2 Error reading at address: 000000000000 ... Retry #3 Error reading at address: 000000000000 ... Retry #4 Error reading at address: 000000000000 ... Retry #5 Too many errors. Reading has been stopped HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 206 mV CMD Active Level: 3073 mV EMMC Device Information : EMMC CID: 1501004B3558564D4206EFFECCFD1268 EMMC CSD: D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2015 , Rev: 06 EMMC NAME: K5XVMB , S/N: EFFECCFD , rev. 06 EMMC NAME (HEX): 4B3558564D42 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K5XVMB_EFFECCFD_20171007_191012.extcsd EMMC Init completed. Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x01 Reg: 162 Value: 0x01 Successfully HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 206 mV CMD Active Level: 3062 mV EMMC Device Information : EMMC CID: 1501004B3558564D4206EFFECCFD1268 EMMC CSD: D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2015 , Rev: 06 EMMC NAME: K5XVMB , S/N: EFFECCFD , rev. 06 EMMC NAME (HEX): 4B3558564D42 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K5XVMB_EFFECCFD_20171007_191022.extcsd EMMC Init completed. Operation: Write all eMMC Regions at once Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x00 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: boot2.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 683.96 Kb/s All done |
10-07-2017, 17:58 | #2 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Here is my success report http://forum.gsmhosting.com/vbb/f672...-done-2257707/ I see your log boot partitions is wrong Set boot partitions ( No boot partition configured) And write rom1 dump file is available in support |
The Following 2 Users Say Thank You to royalnasim For This Useful Post: |
10-07-2017, 18:26 | #3 (permalink) | |
Member: 2463805 Status: Offline Thanks Meter: 32 | Quote:
One more question the EMMC has written protection Does it affect on the boot repair ? | |
10-07-2017, 19:01 | #5 (permalink) | |
I tried to remove the write protection in easy jtag plus, but I couldn't because I am noob. If you don't mind can you give a reference or something to verify. Thank you | |
03-22-2018, 05:48 | #7 (permalink) |
Member: 2463805 Status: Offline Thanks Meter: 32 | finally fixed 2 sets finally fixed 2 sets Code: eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = 0301200C8AB5FBA1 Card Serial = AA8E-9F6F EasyJTAG Box Firmware = 1.62 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting frequence to 21 Mhz CMD Pullup Level: 2103 mV CMD Active Level: 3093 mV EMMC Device Information : EMMC CID: 90014A4834473164040502A2258EA14C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G1d , EMMC NAME (HEX): 483447316400 , S/N: 02A2258E , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 10/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_02A2258E_20180322_100407.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000000400000 - 000004400000], size: 000004000000 Partition: sbl1, [000004400000 - 000004500000], size: 000000100000 Partition: rpm, [000004500000 - 000004580000], size: 000000080000 Partition: tz, [000004580000 - 000004600000], size: 000000080000 Partition: sdi, [000004600000 - 000004680000], size: 000000080000 Partition: aboot, [000004680000 - 000004880000], size: 000000200000 Partition: rpmb, [000004880000 - 000004900000], size: 000000080000 Partition: tzb, [000004900000 - 000004980000], size: 000000080000 Partition: abootb, [000004980000 - 000004B80000], size: 000000200000 Partition: pad, [000004B80000 - 000004D80000], size: 000000200000 Partition: modemst1, [000004D80000 - 000005080000], size: 000000300000 Partition: modemst2, [000005080000 - 000005380000], size: 000000300000 Partition: misc, [000005380000 - 000006380000], size: 000001000000 Partition: persist, [000006400000 - 000008400000], size: 000002000000 Partition: laf, [000008400000 - 000009A00000], size: 000001600000 Partition: boot, [000009C00000 - 00000B200000], size: 000001600000 Partition: recovery, [00000B200000 - 00000C800000], size: 000001600000 Partition: fsg, [00000C800000 - 00000CB00000], size: 000000300000 Partition: fsc, [00000CC00000 - 00000CC80000], size: 000000080000 Partition: ssd, [00000CC80000 - 00000CD00000], size: 000000080000 Partition: DDR, [00000D000000 - 00000D080000], size: 000000080000 Partition: encrypt, [00000D400000 - 00000D480000], size: 000000080000 Partition: rct, [00000D480000 - 00000D500000], size: 000000080000 Partition: drm, [00000D800000 - 00000E000000], size: 000000800000 Partition: sns, [00000E000000 - 00000E800000], size: 000000800000 Partition: factory, [00000E800000 - 00000FC00000], size: 000001400000 Partition: fota, [00000FC00000 - 000011C00000], size: 000002000000 Partition: sbl1b, [000011C00000 - 000011D00000], size: 000000100000 Partition: mpt, [000011D00000 - 000013D00000], size: 000002000000 Partition: cust, [000014000000 - 000017200000], size: 000003200000 Partition: eksst, [000017400000 - 000017480000], size: 000000080000 Partition: system, [000017800000 - 000075380000], size: 00005DB80000 Partition: cache, [000075380000 - 000084D80000], size: 00000FA00000 Partition: userdata, [000084D80000 - 0000E6D80000], size: 000062000000 Partition: grow, [0000E7000000 - 0000E8FFBE00], size: 000001FFBE00 GPT header successfully parsed Get firmware version Brand = lge Manufacturer = LGE Model = LG-D325 Phone platform = msm8610 CPU Abi = armeabi-v7a Android release = 4.4.2 Firmware version = KOT49I.A1392225267 Firmware date = Thu Feb 13 02:26:17 KST 2014 Setting frequence to 21 Mhz CMD Pullup Level: 2093 mV CMD Active Level: 3093 mV EMMC Device Information : EMMC CID: 90014A4834473164040502A2258EA14C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G1d , EMMC NAME (HEX): 483447316400 , S/N: 02A2258E , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 10/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_02A2258E_20180322_100424.extcsd EMMC Init completed. Opening file: D32510e_00.kdz Filename: D32510e_00.kdz Model: LG-D325 Software: D32510e BuildTime: 0000-00-00 00:00:00 Total Files: 31 The size of the last section has been updated Setting frequence to 21 Mhz CMD Pullup Level: 2093 mV CMD Active Level: 3093 mV EMMC Device Information : EMMC CID: 90014A4834473164040502A2258EA14C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G1d , EMMC NAME (HEX): 483447316400 , S/N: 02A2258E , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 10/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_02A2258E_20180322_100441.extcsd EMMC Init completed. Operation: Write by vendor (LG) Creating GPT-partitioninig GPT-partitioning done Filename: D32510e_00.kdz Model: LG-D325 Software: D32510e BuildTime: 0000-00-00 00:00:00 Total Files: 31 Unpacking files from the firmware. Please wait ... Unpack done Partition name: MODEM Filename: modem_8192.bin , Offset: 000000400000 , filesize: 34603008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 509.83 KB/s Partition name: SBL1 Filename: sbl1_139264.bin , Offset: 000004400000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 507.25 KB/s Partition name: RPM Filename: rpm_141312.bin , Offset: 000004500000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 507.03 KB/s Partition name: TZ Filename: tz_142336.bin , Offset: 000004580000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 505.68 KB/s Partition name: SDI Filename: sdi_143360.bin , Offset: 000004600000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 506.16 KB/s Partition name: ABOOT Filename: aboot_144384.bin , Offset: 000004680000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 509.73 KB/s Partition name: RPMB Filename: rpmb_148480.bin , Offset: 000004880000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 506.72 KB/s Partition name: TZB Filename: tzb_149504.bin , Offset: 000004900000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 507.48 KB/s Partition name: ABOOTB Filename: abootb_150528.bin , Offset: 000004980000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 509.84 KB/s Partition name: PERSIST Filename: persist_204800.bin , Offset: 000006400000 , filesize: 5242880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 495.94 KB/s Partition name: LAF Filename: laf_270336.bin , Offset: 000008400000 , filesize: 15728640 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 511.57 KB/s Partition name: BOOT Filename: boot_319488.bin , Offset: 000009C00000 , filesize: 9961472 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 510.38 KB/s Partition name: RECOVERY Filename: recovery_364544.bin , Offset: 00000B200000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 511.67 KB/s Partition name: FACTORY Filename: factory_475136.bin , Offset: 00000E800000 , filesize: 12058624 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 510.13 KB/s Partition name: SBL1B Filename: sbl1b_581632.bin , Offset: 000011C00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 508.10 KB/s Partition name: CUST Filename: cust_655360.bin , Offset: 000014000000 , filesize: 6815744 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 511.72 KB/s All done time: [00:03:32:693] |
