04-02-2017, 06:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 640052 Status: Offline Thanks Meter: 66 | lg d380 dead boot CMD Pullup Level:3155 mV CMD Active Level:3238 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040506A1D268817E EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 08/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 111268456 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 111268456_20170402_1334.extcsd Searching for partition tables... mmc_read_blocks(0 , 40 ), Reason: CMD Timeout Error Partitioning not detected... Done. |
The Following User Says Thank You to jonar23 For This Useful Post: |
04-02-2017, 07:15 | #2 (permalink) |
Insane Poster Join Date: Apr 2012 Location: Kerala
Member: 1753851 Status: Offline Thanks Meter: 32 | This Emmc Is Skynix . Try To Remove Emmc Password Using Z3x Jtag Tool . If Not Work No Possible Way Yet. |
The Following 2 Users Say Thank You to Suhaib3boys For This Useful Post: |
