04-24-2018, 06:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | LG-F460s boot repair,. pls help,.... boot write failed while upgrading to v20c by other tech,. using easy jtag plus: 4/23/2018 8:25:58 PM> 4/23/2018 8:25:58 PM> eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018) 4/23/2018 8:26:01 PM> Microsoft Windows 10 (64 bit) build 10586 (10.0.10586.0) 4/23/2018 8:26:01 PM> 4/23/2018 8:26:01 PM> Looking for EasyJTAG box... 4/23/2018 8:26:01 PM> EasyJTAG API ver. 2100 4/23/2018 8:26:02 PM> OpenUSB returned = 0 4/23/2018 8:27:32 PM> EasyJTAG Box Serial = 01005hehehe1BB65 4/23/2018 8:27:37 PM> Card Serial = Ahehe096 4/23/2018 8:27:37 PM> EasyJTAG Box Firmware = 1.62 4/23/2018 8:27:37 PM> 4/23/2018 8:27:58 PM> Looking for EasyJTAG box... 4/23/2018 8:27:58 PM> EasyJTAG API ver. 2100 4/23/2018 8:27:58 PM> Setting IO Levels to 1.8V 4/23/2018 8:27:58 PM> Setting frequence to 21 Mhz 4/23/2018 8:27:58 PM> EasyJTAG Box Serial = 010050heheheBB65 4/23/2018 8:27:58 PM> EasyJTAG Box Firmware = 1.62 4/23/2018 8:27:59 PM> Setting frequence to 21 Mhz 4/23/2018 8:28:00 PM> CMD Pullup Level: 2083 mV 4/23/2018 8:28:00 PM> CMD Active Level: 1206 mV 4/23/2018 8:28:00 PM> eMMC Init returned = 0 4/23/2018 8:28:00 PM> EMMC Device Information : 4/23/2018 8:28:00 PM> EMMC CID: 110100303332474534005DB095BD7182 4/23/2018 8:28:00 PM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 4/23/2018 8:28:00 PM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032GE4 , HEX: 303332474534 , S/N: 5DB095BD , rev. 0x00 4/23/2018 8:28:00 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014 4/23/2018 8:28:00 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 4/23/2018 8:28:00 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 4/23/2018 8:28:00 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 4/23/2018 8:28:00 PM> EMMC Permanent Write Protection: No 4/23/2018 8:28:00 PM> EMMC Temporary Write Protection: No 4/23/2018 8:28:00 PM> Extended CSD Information : 4/23/2018 8:28:00 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 4/23/2018 8:28:00 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 4/23/2018 8:28:00 PM> Boot Bus Config: 0x00 , width 1bit 4/23/2018 8:28:00 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 4/23/2018 8:28:00 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 4/23/2018 8:28:00 PM> Device supports partitioning features 4/23/2018 8:28:00 PM> Device can have enhanced technological features in partitions and user data area 4/23/2018 8:28:00 PM> Device can have extended partitions attribute 4/23/2018 8:28:00 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 4/23/2018 8:28:00 PM> Backup saved: 032GE4_5DB095BD_20180423_202800.extcsd 4/23/2018 8:28:00 PM> EMMC Init completed. 4/23/2018 8:28:00 PM> 4/23/2018 8:28:13 PM> Looking for EasyJTAG box... 4/23/2018 8:28:13 PM> EasyJTAG API ver. 2100 4/23/2018 8:28:13 PM> Setting IO Levels to 1.8V 4/23/2018 8:28:13 PM> Setting frequence to 21 Mhz 4/23/2018 8:28:13 PM> EasyJTAG Box Serial = 0100501F46B1BB65 4/23/2018 8:28:13 PM> EasyJTAG Box Firmware = 1.62 4/23/2018 8:28:14 PM> Setting frequence to 21 Mhz 4/23/2018 8:28:14 PM> CMD Pullup Level: 2052 mV 4/23/2018 8:28:14 PM> CMD Active Level: 1206 mV 4/23/2018 8:28:15 PM> eMMC Init returned = 0 4/23/2018 8:28:15 PM> EMMC Device Information : 4/23/2018 8:28:15 PM> EMMC CID: 110100303332474534005DB095BD7182 4/23/2018 8:28:15 PM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 4/23/2018 8:28:15 PM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032GE4 , HEX: 303332474534 , S/N: 5DB095BD , rev. 0x00 4/23/2018 8:28:15 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014 4/23/2018 8:28:15 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 4/23/2018 8:28:15 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 4/23/2018 8:28:15 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 4/23/2018 8:28:15 PM> EMMC Permanent Write Protection: No 4/23/2018 8:28:15 PM> EMMC Temporary Write Protection: No 4/23/2018 8:28:15 PM> Extended CSD Information : 4/23/2018 8:28:15 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 4/23/2018 8:28:15 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 4/23/2018 8:28:15 PM> Boot Bus Config: 0x00 , width 1bit 4/23/2018 8:28:15 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 4/23/2018 8:28:15 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 4/23/2018 8:28:15 PM> Device supports partitioning features 4/23/2018 8:28:15 PM> Device can have enhanced technological features in partitions and user data area 4/23/2018 8:28:15 PM> Device can have extended partitions attribute 4/23/2018 8:28:15 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 4/23/2018 8:28:15 PM> Backup saved: 032GE4_5DB095BD_20180423_202815.extcsd 4/23/2018 8:28:15 PM> EMMC Init completed. 4/23/2018 8:28:15 PM> 4/23/2018 8:28:15 PM> Opening file: D:\F460S20C_00.kdz 4/23/2018 8:28:15 PM> 4/23/2018 8:28:15 PM> Filename: F460S20C_00.kdz 4/23/2018 8:28:15 PM> Model: LG-F460S 4/23/2018 8:28:15 PM> Software: LGF460SAT-00-V20c-SKT-KR-DEC-26-2014+0_user 4/23/2018 8:28:15 PM> BuildTime: 0000-00-00 00:00:00 4/23/2018 8:28:15 PM> Total Files: 39 4/23/2018 8:28:15 PM> 4/23/2018 8:28:15 PM> The size of the last section has been updated 4/23/2018 8:28:23 PM> 4/23/2018 8:28:23 PM> Looking for EasyJTAG box... 4/23/2018 8:28:23 PM> EasyJTAG API ver. 2100 4/23/2018 8:28:23 PM> Setting IO Levels to 1.8V 4/23/2018 8:28:23 PM> Setting frequence to 21 Mhz 4/23/2018 8:28:23 PM> EasyJTAG Box Serial = 0100501F46B1BB65 4/23/2018 8:28:23 PM> EasyJTAG Box Firmware = 1.62 4/23/2018 8:28:24 PM> Setting frequence to 21 Mhz 4/23/2018 8:28:24 PM> CMD Pullup Level: 2072 mV 4/23/2018 8:28:24 PM> CMD Active Level: 1237 mV 4/23/2018 8:28:25 PM> eMMC Init returned = 0 4/23/2018 8:28:25 PM> EMMC Device Information : 4/23/2018 8:28:25 PM> EMMC CID: 110100303332474534005DB095BD7182 4/23/2018 8:28:25 PM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 4/23/2018 8:28:25 PM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032GE4 , HEX: 303332474534 , S/N: 5DB095BD , rev. 0x00 4/23/2018 8:28:25 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014 4/23/2018 8:28:25 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 4/23/2018 8:28:25 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 4/23/2018 8:28:25 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 4/23/2018 8:28:25 PM> EMMC Permanent Write Protection: No 4/23/2018 8:28:25 PM> EMMC Temporary Write Protection: No 4/23/2018 8:28:25 PM> Extended CSD Information : 4/23/2018 8:28:25 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 4/23/2018 8:28:25 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 4/23/2018 8:28:25 PM> Boot Bus Config: 0x00 , width 1bit 4/23/2018 8:28:25 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 4/23/2018 8:28:25 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 4/23/2018 8:28:25 PM> Device supports partitioning features 4/23/2018 8:28:25 PM> Device can have enhanced technological features in partitions and user data area 4/23/2018 8:28:25 PM> Device can have extended partitions attribute 4/23/2018 8:28:25 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 4/23/2018 8:28:25 PM> Backup saved: 032GE4_5DB095BD_20180423_202825.extcsd 4/23/2018 8:28:25 PM> EMMC Init completed. 4/23/2018 8:28:25 PM> 4/23/2018 8:28:25 PM> Operation: Write by vendor (LG) 4/23/2018 8:28:25 PM> 4/23/2018 8:28:25 PM> Creating GPT-partitioninig 4/23/2018 8:28:25 PM> Writing PrimaryGPT at address: 000000000000 4/23/2018 8:28:27 PM> Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #1 4/23/2018 8:28:28 PM> Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #2 4/23/2018 8:28:30 PM> Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error ... Retry #3 4/23/2018 8:28:32 PM> Too many errors. Writing has been stopped pls help team,. do not have any reference for these,.. just soldered, connect and write by vendor,. |
04-25-2018, 04:26 | #4 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | now dead,... 4/25/2018 9:46:34 AM> eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018) 4/25/2018 9:46:37 AM> Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) 4/25/2018 9:46:37 AM> 4/25/2018 9:46:37 AM> Looking for EasyJTAG box... 4/25/2018 9:46:37 AM> EasyJTAG API ver. 2100 4/25/2018 9:46:38 AM> OpenUSB returned = 0 4/25/2018 9:46:39 AM> EasyJTAG Box Serial = 0100501F4665 4/25/2018 9:46:40 AM> Card Serial = AA4 4/25/2018 9:46:40 AM> EasyJTAG Box Firmware = 1.62 4/25/2018 9:46:40 AM> 4/25/2018 9:47:09 AM> Looking for EasyJTAG box... 4/25/2018 9:47:10 AM> EasyJTAG API ver. 2100 4/25/2018 9:47:10 AM> Setting IO Levels to 1.8V 4/25/2018 9:47:10 AM> Setting frequence to 21 Mhz 4/25/2018 9:47:10 AM> EasyJTAG Box Serial = 0100501F46B1BB65 4/25/2018 9:47:10 AM> EasyJTAG Box Firmware = 1.62 4/25/2018 9:47:11 AM> Setting frequence to 21 Mhz 4/25/2018 9:47:11 AM> CMD Pullup Level: 82 mV 4/25/2018 9:47:11 AM> CMD Active Level: 1443 mV 4/25/2018 9:47:11 AM> eMMC Init returned = -1 4/25/2018 9:47:11 AM> Can't init device. Reason: CMD Timeout Error 4/25/2018 9:47:11 AM> 4/25/2018 9:47:31 AM> Looking for EasyJTAG box... 4/25/2018 9:47:31 AM> EasyJTAG API ver. 2100 4/25/2018 9:47:31 AM> Setting IO Levels to 1.8V 4/25/2018 9:47:31 AM> Setting frequence to 21 Mhz 4/25/2018 9:47:31 AM> EasyJTAG Box Serial = 0100501F46B1BB65 4/25/2018 9:47:31 AM> EasyJTAG Box Firmware = 1.62 4/25/2018 9:47:32 AM> Setting frequence to 21 Mhz 4/25/2018 9:47:32 AM> CMD Pullup Level: 1742 mV 4/25/2018 9:47:32 AM> CMD Active Level: 1433 mV 4/25/2018 9:47:33 AM> eMMC Init returned = 0 4/25/2018 9:47:33 AM> EMMC Device Information : 4/25/2018 9:47:33 AM> EMMC CID: 110100303332474534005DB095BD7182 4/25/2018 9:47:33 AM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 4/25/2018 9:47:33 AM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032GE4 , HEX: 303332474534 , S/N: 5DB095BD , rev. 0x00 4/25/2018 9:47:33 AM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014 4/25/2018 9:47:33 AM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 4/25/2018 9:47:33 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 4/25/2018 9:47:33 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 4/25/2018 9:47:33 AM> EMMC Permanent Write Protection: No 4/25/2018 9:47:33 AM> EMMC Temporary Write Protection: No 4/25/2018 9:47:33 AM> Extended CSD Information : 4/25/2018 9:47:33 AM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 4/25/2018 9:47:33 AM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 4/25/2018 9:47:33 AM> Boot Bus Config: 0x00 , width 1bit 4/25/2018 9:47:33 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 4/25/2018 9:47:33 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 4/25/2018 9:47:33 AM> Device supports partitioning features 4/25/2018 9:47:33 AM> Device can have enhanced technological features in partitions and user data area 4/25/2018 9:47:33 AM> Device can have extended partitions attribute 4/25/2018 9:47:33 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 4/25/2018 9:47:33 AM> Backup saved: 032GE4_5DB095BD_20180425_094733.extcsd 4/25/2018 9:47:33 AM> EMMC Init completed. 4/25/2018 9:47:33 AM> 4/25/2018 9:47:33 AM> Get firmware version 4/25/2018 9:47:33 AM> 4/25/2018 9:47:34 AM> Brand = lge 4/25/2018 9:47:34 AM> Manufacturer = LGE 4/25/2018 9:47:34 AM> Model = LG-F460S 4/25/2018 9:47:34 AM> Phone platform = apq8084 4/25/2018 9:47:34 AM> CPU Abi = armeabi-v7a 4/25/2018 9:47:34 AM> Android release = 4.4.2 4/25/2018 9:47:34 AM> Firmware version = KOT49I.F460S11e 4/25/2018 9:47:34 AM> Firmware date = Thu May 12 17:52:01 KST 2016 4/25/2018 9:47:44 AM> 4/25/2018 9:47:44 AM> Looking for EasyJTAG box... 4/25/2018 9:47:44 AM> EasyJTAG API ver. 2100 4/25/2018 9:47:44 AM> Setting IO Levels to 2.8V 4/25/2018 9:47:44 AM> Setting frequence to 21 Mhz 4/25/2018 9:47:44 AM> EasyJTAG Box Serial = 010050 4/25/2018 9:47:44 AM> EasyJTAG Box Firmware = 1.62 4/25/2018 9:47:45 AM> Setting frequence to 21 Mhz 4/25/2018 9:47:45 AM> CMD Pullup Level: 1794 mV 4/25/2018 9:47:45 AM> CMD Active Level: 2031 mV 4/25/2018 9:47:45 AM> eMMC Init returned = 0 4/25/2018 9:47:45 AM> EMMC Device Information : 4/25/2018 9:47:45 AM> EMMC CID: 110100303332474534005DB095BD7182 4/25/2018 9:47:45 AM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 4/25/2018 9:47:45 AM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032GE4 , HEX: 303332474534 , S/N: 5DB095BD , rev. 0x00 4/25/2018 9:47:45 AM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014 4/25/2018 9:47:45 AM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 4/25/2018 9:47:45 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 4/25/2018 9:47:45 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 4/25/2018 9:47:45 AM> EMMC Permanent Write Protection: No 4/25/2018 9:47:45 AM> EMMC Temporary Write Protection: No 4/25/2018 9:47:45 AM> Extended CSD Information : 4/25/2018 9:47:45 AM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 4/25/2018 9:47:45 AM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 4/25/2018 9:47:45 AM> Boot Bus Config: 0x00 , width 1bit 4/25/2018 9:47:45 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 4/25/2018 9:47:45 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 4/25/2018 9:47:45 AM> Device supports partitioning features 4/25/2018 9:47:45 AM> Device can have enhanced technological features in partitions and user data area 4/25/2018 9:47:45 AM> Device can have extended partitions attribute 4/25/2018 9:47:45 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 4/25/2018 9:47:45 AM> Backup saved: 032GE4_5DB095BD_20180425_094745.extcsd 4/25/2018 9:47:45 AM> EMMC Init completed. 4/25/2018 9:47:45 AM> 4/25/2018 9:48:16 AM> Looking for EasyJTAG box... 4/25/2018 9:48:16 AM> EasyJTAG API ver. 2100 4/25/2018 9:48:16 AM> Setting IO Levels to 2.8V 4/25/2018 9:48:16 AM> Setting frequence to 21 Mhz 4/25/2018 9:48:16 AM> EasyJTAG Box Serial = 0100501F46B1BB65 4/25/2018 9:48:16 AM> EasyJTAG Box Firmware = 1.62 4/25/2018 9:48:17 AM> Setting frequence to 21 Mhz 4/25/2018 9:48:17 AM> CMD Pullup Level: 1784 mV 4/25/2018 9:48:17 AM> CMD Active Level: 2010 mV 4/25/2018 9:48:17 AM> eMMC Init returned = 0 4/25/2018 9:48:17 AM> EMMC Device Information : 4/25/2018 9:48:17 AM> EMMC CID: 110100303332474534005DB095BD7182 4/25/2018 9:48:17 AM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 4/25/2018 9:48:17 AM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032GE4 , HEX: 303332474534 , S/N: 5DB095BD , rev. 0x00 4/25/2018 9:48:17 AM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014 4/25/2018 9:48:17 AM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 4/25/2018 9:48:17 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 4/25/2018 9:48:17 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 4/25/2018 9:48:17 AM> EMMC Permanent Write Protection: No 4/25/2018 9:48:17 AM> EMMC Temporary Write Protection: No 4/25/2018 9:48:17 AM> Extended CSD Information : 4/25/2018 9:48:17 AM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 4/25/2018 9:48:17 AM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 4/25/2018 9:48:17 AM> Boot Bus Config: 0x00 , width 1bit 4/25/2018 9:48:17 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 4/25/2018 9:48:17 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 4/25/2018 9:48:17 AM> Device supports partitioning features 4/25/2018 9:48:17 AM> Device can have enhanced technological features in partitions and user data area 4/25/2018 9:48:17 AM> Device can have extended partitions attribute 4/25/2018 9:48:17 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 4/25/2018 9:48:17 AM> Backup saved: 032GE4_5DB095BD_20180425_094817.extcsd 4/25/2018 9:48:18 AM> EMMC Init completed. 4/25/2018 9:48:18 AM> 4/25/2018 9:48:18 AM> Opening file: C:\Users\trensh laptop\Desktop\F460S20C_00.kdz 4/25/2018 9:48:18 AM> 4/25/2018 9:48:18 AM> Filename: F460S20C_00.kdz 4/25/2018 9:48:18 AM> Model: LG-F460S 4/25/2018 9:48:18 AM> Software: LGF460SAT-00-V20c-SKT-KR-DEC-26-2014+0_user 4/25/2018 9:48:18 AM> BuildTime: 0000-00-00 00:00:00 4/25/2018 9:48:18 AM> Total Files: 39 4/25/2018 9:48:18 AM> 4/25/2018 9:48:18 AM> The size of the last section has been updated 4/25/2018 9:48:29 AM> 4/25/2018 9:48:29 AM> Looking for EasyJTAG box... 4/25/2018 9:48:29 AM> EasyJTAG API ver. 2100 4/25/2018 9:48:29 AM> Setting IO Levels to 2.8V 4/25/2018 9:48:29 AM> Setting frequence to 21 Mhz 4/25/2018 9:48:29 AM> EasyJTAG Box Serial = 0100501 4/25/2018 9:48:29 AM> EasyJTAG Box Firmware = 1.62 4/25/2018 9:48:30 AM> Setting frequence to 21 Mhz 4/25/2018 9:48:30 AM> CMD Pullup Level: 1815 mV 4/25/2018 9:48:30 AM> CMD Active Level: 2000 mV 4/25/2018 9:48:31 AM> eMMC Init returned = 0 4/25/2018 9:48:31 AM> EMMC Device Information : 4/25/2018 9:48:31 AM> EMMC CID: 110100303332474534005DB095BD7182 4/25/2018 9:48:31 AM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 4/25/2018 9:48:31 AM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032GE4 , HEX: 303332474534 , S/N: 5DB095BD , rev. 0x00 4/25/2018 9:48:31 AM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2014 4/25/2018 9:48:31 AM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 4/25/2018 9:48:31 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 4/25/2018 9:48:31 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 4/25/2018 9:48:31 AM> EMMC Permanent Write Protection: No 4/25/2018 9:48:31 AM> EMMC Temporary Write Protection: No 4/25/2018 9:48:31 AM> Extended CSD Information : 4/25/2018 9:48:31 AM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 4/25/2018 9:48:31 AM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 4/25/2018 9:48:31 AM> Boot Bus Config: 0x00 , width 1bit 4/25/2018 9:48:31 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 4/25/2018 9:48:31 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 4/25/2018 9:48:31 AM> Device supports partitioning features 4/25/2018 9:48:31 AM> Device can have enhanced technological features in partitions and user data area 4/25/2018 9:48:31 AM> Device can have extended partitions attribute 4/25/2018 9:48:31 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 4/25/2018 9:48:31 AM> Backup saved: 032GE4_5DB095BD_20180425_094831.extcsd 4/25/2018 9:48:31 AM> EMMC Init completed. 4/25/2018 9:48:31 AM> 4/25/2018 9:48:31 AM> Operation: Write by vendor (LG) 4/25/2018 9:48:31 AM> 4/25/2018 9:48:31 AM> Creating GPT-partitioninig 4/25/2018 9:48:31 AM> Writing PrimaryGPT at address: 000000000000 4/25/2018 9:48:31 AM> Writing BackupGPT at address: 000747BFBE00 4/25/2018 9:48:31 AM> GPT-partitioning done 4/25/2018 9:48:31 AM> 4/25/2018 9:48:31 AM> Filename: F460S20C_00.kdz 4/25/2018 9:48:31 AM> Model: LG-F460S 4/25/2018 9:48:31 AM> Software: LGF460SAT-00-V20c-SKT-KR-DEC-26-2014+0_user 4/25/2018 9:48:31 AM> BuildTime: 0000-00-00 00:00:00 4/25/2018 9:48:31 AM> Total Files: 39 4/25/2018 9:48:31 AM> 4/25/2018 9:48:31 AM> Unpacking files from the firmware. Please wait ... 4/25/2018 9:49:27 AM> Unpack done 4/25/2018 9:49:27 AM> 4/25/2018 9:49:27 AM> Partition name: MODEM 4/25/2018 9:49:27 AM> Filename: modem_32768.bin , Offset: 000001000000 , filesize: 87031808 bytes 4/25/2018 9:49:27 AM> eMMC switching to ROM1 4/25/2018 9:49:27 AM> Erasing partition... 4/25/2018 9:49:34 AM> Writing partition... 4/25/2018 9:52:15 AM> Done writing partition. Write speed: 526.46 KB/s 4/25/2018 9:52:15 AM> Partition name: SBL1 4/25/2018 9:52:15 AM> Filename: sbl1_229376.bin , Offset: 000007000000 , filesize: 524288 bytes 4/25/2018 9:52:15 AM> eMMC switching to ROM1 4/25/2018 9:52:16 AM> Erasing partition... 4/25/2018 9:52:16 AM> Writing partition... 4/25/2018 9:52:17 AM> Done writing partition. Write speed: 535.55 KB/s 4/25/2018 9:52:17 AM> Partition name: SDI 4/25/2018 9:52:17 AM> Filename: sdi_231424.bin , Offset: 000007100000 , filesize: 524288 bytes 4/25/2018 9:52:17 AM> eMMC switching to ROM1 4/25/2018 9:52:17 AM> Erasing partition... 4/25/2018 9:52:18 AM> Writing partition... 4/25/2018 9:52:19 AM> Done writing partition. Write speed: 518.63 KB/s 4/25/2018 9:52:19 AM> Partition name: SEC 4/25/2018 9:52:19 AM> Filename: sec_262144.bin , Offset: 000008000000 , filesize: 524288 bytes 4/25/2018 9:52:19 AM> eMMC switching to ROM1 4/25/2018 9:52:19 AM> Erasing partition... 4/25/2018 9:52:20 AM> Writing partition... 4/25/2018 9:52:21 AM> Done writing partition. Write speed: 536.08 KB/s 4/25/2018 9:52:21 AM> Partition name: ABOOT 4/25/2018 9:52:21 AM> Filename: aboot_295936.bin , Offset: 000009080000 , filesize: 2097152 bytes 4/25/2018 9:52:21 AM> eMMC switching to ROM1 4/25/2018 9:52:21 AM> Erasing partition... 4/25/2018 9:52:22 AM> Writing partition... 4/25/2018 9:52:25 AM> Done writing partition. Write speed: 548.00 KB/s 4/25/2018 9:52:25 AM> Partition name: RPM 4/25/2018 9:52:25 AM> Filename: rpm_300032.bin , Offset: 000009280000 , filesize: 524288 bytes 4/25/2018 9:52:26 AM> eMMC switching to ROM1 4/25/2018 9:52:26 AM> Erasing partition... 4/25/2018 9:52:26 AM> Writing partition... 4/25/2018 9:52:27 AM> Done writing partition. Write speed: 533.83 KB/s 4/25/2018 9:52:27 AM> Partition name: TZ 4/25/2018 9:52:27 AM> Filename: tz_302080.bin , Offset: 000009380000 , filesize: 524288 bytes 4/25/2018 9:52:27 AM> eMMC switching to ROM1 4/25/2018 9:52:28 AM> Erasing partition... 4/25/2018 9:52:28 AM> Writing partition... 4/25/2018 9:52:29 AM> Done writing partition. Write speed: 525.40 KB/s 4/25/2018 9:52:29 AM> Partition name: BOOT 4/25/2018 9:52:29 AM> Filename: boot_327680.bin , Offset: 00000A000000 , filesize: 14155776 bytes 4/25/2018 9:52:29 AM> eMMC switching to ROM1 4/25/2018 9:52:29 AM> Erasing partition... 4/25/2018 9:52:31 AM> Writing partition... 4/25/2018 9:52:56 AM> Done writing partition. Write speed: 555.14 KB/s 4/25/2018 9:52:56 AM> Partition name: PERSIST 4/25/2018 9:52:56 AM> Filename: persist_360448.bin , Offset: 00000B000000 , filesize: 5242880 bytes 4/25/2018 9:52:56 AM> eMMC switching to ROM1 4/25/2018 9:52:56 AM> Erasing partition... 4/25/2018 9:52:57 AM> Writing partition... 4/25/2018 9:53:06 AM> Done writing partition. Write speed: 548.19 KB/s 4/25/2018 9:53:06 AM> Partition name: RECOVERY 4/25/2018 9:53:06 AM> Filename: recovery_425984.bin , Offset: 00000D000000 , filesize: 15204352 bytes 4/25/2018 9:53:06 AM> eMMC switching to ROM1 4/25/2018 9:53:07 AM> Erasing partition... 4/25/2018 9:53:08 AM> Writing partition... 4/25/2018 9:53:35 AM> Done writing partition. Write speed: 553.64 KB/s 4/25/2018 9:53:35 AM> Partition name: LAF 4/25/2018 9:53:35 AM> Filename: laf_655360.bin , Offset: 000014000000 , filesize: 18874368 bytes 4/25/2018 9:53:35 AM> eMMC switching to ROM1 4/25/2018 9:53:35 AM> Erasing partition... 4/25/2018 9:53:37 AM> Writing partition... 4/25/2018 9:54:10 AM> Done writing partition. Write speed: 556.91 KB/s 4/25/2018 9:54:10 AM> Partition name: FACTORY 4/25/2018 9:54:10 AM> Filename: factory_851968.bin , Offset: 00001A000000 , filesize: 16777216 bytes 4/25/2018 9:54:10 AM> eMMC switching to ROM1 4/25/2018 9:54:10 AM> Erasing partition... 4/25/2018 9:54:12 AM> Writing partition... 4/25/2018 9:54:42 AM> Done writing partition. Write speed: 549.47 KB/s 4/25/2018 9:54:42 AM> Partition name: SYSTEM 4/25/2018 9:54:42 AM> Filename: system_917504.bin , Offset: 00001C000000 , filesize: 134742016 bytes 4/25/2018 9:54:42 AM> eMMC switching to ROM1 4/25/2018 9:54:42 AM> Erasing partition... 4/25/2018 9:54:50 AM> Writing partition... 4/25/2018 9:58:50 AM> Done writing partition. Write speed: 550.03 KB/s 4/25/2018 9:58:50 AM> Partition name: SYSTEM 4/25/2018 9:58:50 AM> Filename: system_1180936.bin , Offset: 0000240A1000 , filesize: 133693440 bytes 4/25/2018 9:58:50 AM> eMMC switching to ROM1 4/25/2018 9:58:50 AM> Erasing partition... 4/25/2018 9:58:58 AM> Writing partition... 4/25/2018 10:02:56 AM> Done writing partition. Write speed: 548.14 KB/s 4/25/2018 10:02:56 AM> Partition name: SYSTEM 4/25/2018 10:02:56 AM> Filename: system_1445752.bin , Offset: 00002C1EF000 , filesize: 132644864 bytes 4/25/2018 10:02:56 AM> eMMC switching to ROM1 4/25/2018 10:02:57 AM> Erasing partition... 4/25/2018 10:03:05 AM> Writing partition... 4/25/2018 10:07:01 AM> Done writing partition. Write speed: 548.70 KB/s 4/25/2018 10:07:01 AM> Partition name: SYSTEM 4/25/2018 10:07:01 AM> Filename: system_1705224.bin , Offset: 0000340A1000 , filesize: 524288 bytes 4/25/2018 10:07:01 AM> eMMC switching to ROM1 4/25/2018 10:07:01 AM> Erasing partition... 4/25/2018 10:07:02 AM> Writing partition... 4/25/2018 10:07:03 AM> Done writing partition. Write speed: 581.34 KB/s 4/25/2018 10:07:03 AM> Partition name: SYSTEM 4/25/2018 10:07:03 AM> Filename: system_1709184.bin , Offset: 000034290000 , filesize: 131596288 bytes 4/25/2018 10:07:03 AM> eMMC switching to ROM1 4/25/2018 10:07:03 AM> Erasing partition... 4/25/2018 10:07:11 AM> Writing partition... 4/25/2018 10:11:07 AM> Done writing partition. Write speed: 543.93 KB/s 4/25/2018 10:11:07 AM> Partition name: SYSTEM 4/25/2018 10:11:07 AM> Filename: system_1970040.bin , Offset: 00003C1EF000 , filesize: 132644864 bytes 4/25/2018 10:11:07 AM> eMMC switching to ROM1 4/25/2018 10:11:08 AM> Erasing partition... 4/25/2018 10:11:16 AM> Writing partition... 4/25/2018 10:15:15 AM> Done writing partition. Write speed: 541.44 KB/s 4/25/2018 10:15:15 AM> Partition name: SYSTEM 4/25/2018 10:15:15 AM> Filename: system_2229512.bin , Offset: 0000440A1000 , filesize: 524288 bytes 4/25/2018 10:15:15 AM> eMMC switching to ROM1 4/25/2018 10:15:16 AM> Erasing partition... 4/25/2018 10:15:16 AM> Writing partition... 4/25/2018 10:15:17 AM> Done writing partition. Write speed: 495.70 KB/s 4/25/2018 10:15:17 AM> Partition name: SYSTEM 4/25/2018 10:15:17 AM> Filename: system_2233472.bin , Offset: 000044290000 , filesize: 131596288 bytes 4/25/2018 10:15:17 AM> eMMC switching to ROM1 4/25/2018 10:15:17 AM> Erasing partition... 4/25/2018 10:15:26 AM> Writing partition... 4/25/2018 10:19:21 AM> Done writing partition. Write speed: 547.51 KB/s 4/25/2018 10:19:21 AM> Partition name: SYSTEM 4/25/2018 10:19:21 AM> Filename: system_2494328.bin , Offset: 00004C1EF000 , filesize: 132644864 bytes 4/25/2018 10:19:21 AM> eMMC switching to ROM1 4/25/2018 10:19:21 AM> Erasing partition... 4/25/2018 10:19:29 AM> Writing partition... 4/25/2018 10:23:27 AM> Done writing partition. Write speed: 544.38 KB/s 4/25/2018 10:23:27 AM> Partition name: SYSTEM 4/25/2018 10:23:27 AM> Filename: system_2753800.bin , Offset: 0000540A1000 , filesize: 524288 bytes 4/25/2018 10:23:27 AM> eMMC switching to ROM1 4/25/2018 10:23:28 AM> Erasing partition... 4/25/2018 10:23:28 AM> Writing partition... 4/25/2018 10:23:30 AM> Done writing partition. Write speed: 429.28 KB/s 4/25/2018 10:23:30 AM> Partition name: SYSTEM 4/25/2018 10:23:30 AM> Filename: system_2757760.bin , Offset: 000054290000 , filesize: 131596288 bytes 4/25/2018 10:23:30 AM> eMMC switching to ROM1 4/25/2018 10:23:30 AM> Erasing partition... 4/25/2018 10:23:38 AM> Writing partition... 4/25/2018 10:27:30 AM> Done writing partition. Write speed: 553.42 KB/s 4/25/2018 10:27:30 AM> Partition name: SYSTEM 4/25/2018 10:27:30 AM> Filename: system_3018616.bin , Offset: 00005C1EF000 , filesize: 132644864 bytes 4/25/2018 10:27:30 AM> eMMC switching to ROM1 4/25/2018 10:27:31 AM> Erasing partition... 4/25/2018 10:27:39 AM> Writing partition... 4/25/2018 10:31:36 AM> Done writing partition. Write speed: 547.00 KB/s 4/25/2018 10:31:36 AM> Partition name: SYSTEM 4/25/2018 10:31:36 AM> Filename: system_3278088.bin , Offset: 0000640A1000 , filesize: 524288 bytes 4/25/2018 10:31:36 AM> eMMC switching to ROM1 4/25/2018 10:31:36 AM> Erasing partition... 4/25/2018 10:31:37 AM> Writing partition... 4/25/2018 10:31:38 AM> Done writing partition. Write speed: 494.63 KB/s 4/25/2018 10:31:38 AM> Partition name: SYSTEM 4/25/2018 10:31:38 AM> Filename: system_3282048.bin , Offset: 000064290000 , filesize: 131596288 bytes 4/25/2018 10:31:38 AM> eMMC switching to ROM1 4/25/2018 10:31:38 AM> Erasing partition... 4/25/2018 10:31:46 AM> Writing partition... 4/25/2018 10:35:49 AM> Done writing partition. Write speed: 529.35 KB/s 4/25/2018 10:35:49 AM> Partition name: SYSTEM 4/25/2018 10:35:49 AM> Filename: system_3542904.bin , Offset: 00006C1EF000 , filesize: 132644864 bytes 4/25/2018 10:35:49 AM> eMMC switching to ROM1 4/25/2018 10:35:50 AM> Erasing partition... 4/25/2018 10:35:58 AM> Writing partition... 4/25/2018 10:39:56 AM> Done writing partition. Write speed: 544.13 KB/s 4/25/2018 10:39:56 AM> Partition name: SYSTEM 4/25/2018 10:39:56 AM> Filename: system_3805048.bin , Offset: 0000741EF000 , filesize: 132644864 bytes 4/25/2018 10:39:56 AM> eMMC switching to ROM1 4/25/2018 10:39:56 AM> Erasing partition... 4/25/2018 10:40:04 AM> Writing partition... 4/25/2018 10:44:07 AM> Done writing partition. Write speed: 534.88 KB/s 4/25/2018 10:44:07 AM> Partition name: SYSTEM 4/25/2018 10:44:07 AM> Filename: system_4067192.bin , Offset: 00007C1EF000 , filesize: 132644864 bytes 4/25/2018 10:44:07 AM> eMMC switching to ROM1 4/25/2018 10:44:07 AM> Erasing partition... 4/25/2018 10:44:15 AM> Writing partition... 4/25/2018 10:48:12 AM> Done writing partition. Write speed: 546.28 KB/s 4/25/2018 10:48:12 AM> Partition name: SYSTEM 4/25/2018 10:48:12 AM> Filename: system_4329336.bin , Offset: 0000841EF000 , filesize: 68157440 bytes 4/25/2018 10:48:12 AM> eMMC switching to ROM1 4/25/2018 10:48:13 AM> Erasing partition... 4/25/2018 10:48:17 AM> Writing partition... 4/25/2018 10:50:20 AM> Done writing partition. Write speed: 542.80 KB/s 4/25/2018 10:50:20 AM> Partition name: SYSTEM 4/25/2018 10:50:20 AM> Filename: system_4587520.bin , Offset: 00008C000000 , filesize: 524288 bytes 4/25/2018 10:50:20 AM> eMMC switching to ROM1 4/25/2018 10:50:20 AM> Erasing partition... 4/25/2018 10:50:21 AM> Writing partition... 4/25/2018 10:50:22 AM> Done writing partition. Write speed: 535.68 KB/s 4/25/2018 10:50:22 AM> Partition name: SYSTEM 4/25/2018 10:50:22 AM> Filename: system_4849664.bin , Offset: 000094000000 , filesize: 524288 bytes 4/25/2018 10:50:22 AM> eMMC switching to ROM1 4/25/2018 10:50:22 AM> Erasing partition... 4/25/2018 10:50:23 AM> Writing partition... 4/25/2018 10:50:24 AM> Done writing partition. Write speed: 525.90 KB/s 4/25/2018 10:50:24 AM> Partition name: SYSTEM 4/25/2018 10:50:24 AM> Filename: system_5111808.bin , Offset: 00009C000000 , filesize: 524288 bytes 4/25/2018 10:50:24 AM> eMMC switching to ROM1 4/25/2018 10:50:24 AM> Erasing partition... 4/25/2018 10:50:24 AM> Writing partition... 4/25/2018 10:50:25 AM> Done writing partition. Write speed: 518.30 KB/s 4/25/2018 10:50:25 AM> Partition name: SYSTEM 4/25/2018 10:50:25 AM> Filename: system_5373952.bin , Offset: 0000A4000000 , filesize: 524288 bytes 4/25/2018 10:50:25 AM> eMMC switching to ROM1 4/25/2018 10:50:26 AM> Erasing partition... 4/25/2018 10:50:26 AM> Writing partition... 4/25/2018 10:50:27 AM> Done writing partition. Write speed: 571.89 KB/s 4/25/2018 10:50:27 AM> Partition name: SYSTEM 4/25/2018 10:50:27 AM> Filename: system_5636096.bin , Offset: 0000AC000000 , filesize: 524288 bytes 4/25/2018 10:50:27 AM> eMMC switching to ROM1 4/25/2018 10:50:27 AM> Erasing partition... 4/25/2018 10:50:28 AM> Writing partition... 4/25/2018 10:50:29 AM> Done writing partition. Write speed: 535.40 KB/s 4/25/2018 10:50:29 AM> Partition name: SYSTEM 4/25/2018 10:50:29 AM> Filename: system_5898240.bin , Offset: 0000B4000000 , filesize: 524288 bytes 4/25/2018 10:50:29 AM> eMMC switching to ROM1 4/25/2018 10:50:29 AM> Erasing partition... 4/25/2018 10:50:30 AM> Writing partition... 4/25/2018 10:50:31 AM> Done writing partition. Write speed: 520.17 KB/s 4/25/2018 10:50:31 AM> Partition name: SYSTEM 4/25/2018 10:50:31 AM> Filename: system_5901304.bin , Offset: 0000B417F000 , filesize: 31981568 bytes 4/25/2018 10:50:31 AM> eMMC switching to ROM1 4/25/2018 10:50:31 AM> Erasing partition... 4/25/2018 10:50:34 AM> Writing partition... 4/25/2018 10:51:31 AM> Done writing partition. Write speed: 542.80 KB/s 4/25/2018 10:51:31 AM> 4/25/2018 10:51:31 AM> Partition USERDATA : formatting as EXT4. Please wait ... 4/25/2018 10:52:47 AM> Formatting completed 4/25/2018 10:52:47 AM> 4/25/2018 10:52:47 AM> Check BOOT_PARTITION_EN for the selected vendor 4/25/2018 10:52:47 AM> 4/25/2018 10:52:47 AM> All done time: [01:03:20:549] 4/25/2018 10:52:47 AM> what now team? is this box for revival or for file xplorer only? my device is now dead,. |
04-25-2018, 07:30 | #5 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | i think u are using wrong firmware file visit this web https://lg-kdz-firmware.com/check-your-firmware.html and download firmware by imei full formate emmc and write by vender leave system.bin files and user data |
The Following User Says Thank You to ilyasrao For This Useful Post: |
