LG H810 how to recover dead by easy jtag 03-12-2018 13:42:36> 03-12-2018 13:42:36> eMMC_tool Suite ver. 1.5.2.0 (release date: 06.08.2018) 03-12-2018 13:42:37> Microsoft Windows 10 (64 bit) build 17134 (10.0.17134.376) 03-12-2018 13:42:37> 03-12-2018 13:42:37> Looking for EasyJTAG box... 03-12-2018 13:42:37> EasyJTAG API ver. 2100 03-12-2018 13:42:38> OpenUSB returned = 0 03-12-2018 13:42:38> EasyJTAG Box Serial = 617B0E64AEE654F2 03-12-2018 13:42:39> Card Serial = AAEBF71F 03-12-2018 13:42:39> EasyJTAG Box Firmware = 2.30 03-12-2018 13:42:39> 03-12-2018 13:46:14> Nothing to read. Process stopped. 03-12-2018 13:46:14> 03-12-2018 13:46:18> Nothing to read. Process stopped. 03-12-2018 13:46:18> 03-12-2018 13:46:23> Nothing to read. Process stopped. 03-12-2018 13:46:23> 03-12-2018 13:46:26> You must select one partition. Process stopped. 03-12-2018 13:46:26> 03-12-2018 13:46:40> Looking for EasyJTAG box... 03-12-2018 13:46:40> EasyJTAG API ver. 2100 03-12-2018 13:46:40> Setting IO Levels to 1.8V 03-12-2018 13:46:40> Setting frequence to 36 Mhz 03-12-2018 13:46:40> EasyJTAG Box Serial = 617B0E64AEE654F2 03-12-2018 13:46:40> EasyJTAG Box Firmware = 2.30 03-12-2018 13:46:40> Setting interface to EasyJtag2/ISP_HiPower 03-12-2018 13:46:40> Setting bus width to 1 Bit 03-12-2018 13:46:40> HiPower mode is ON 03-12-2018 13:46:40> Setting frequence to 36 Mhz 03-12-2018 13:46:40> CMD Pullup Level: 927 mV 03-12-2018 13:46:40> CMD Active Level: 1878 mV 03-12-2018 13:46:41> eMMC Init returned = 0 03-12-2018 13:46:41> EMMC Device Information : 03-12-2018 13:46:41> EMMC CID: 11010030333247373400E286D1A432A3 03-12-2018 13:46:41> EMMC CSD: D02700320F5903FFFFFFFFE78640009B 03-12-2018 13:46:41> EMMC Manufacture : TOSHIBA , EMMC NAME: 032G74 , HEX: 303332473734 , S/N: E286D1A4 , rev. 0x00 03-12-2018 13:46:41> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2015 03-12-2018 13:46:41> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 03-12-2018 13:46:41> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 03-12-2018 13:46:41> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 03-12-2018 13:46:41> EMMC Permanent Write Protection: No 03-12-2018 13:46:41> EMMC Temporary Write Protection: No 03-12-2018 13:46:41> Extended CSD Information : 03-12-2018 13:46:41> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 03-12-2018 13:46:41> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 03-12-2018 13:46:41> Boot Bus Config: 0x00 , width 1bit 03-12-2018 13:46:41> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 03-12-2018 13:46:41> Supported partition features [PARTITIONING_SUPPORT]: 0x07 03-12-2018 13:46:41> Device supports partitioning features 03-12-2018 13:46:41> Device can have enhanced technological features in partitions and user data area 03-12-2018 13:46:41> Device can have extended partitions attribute 03-12-2018 13:46:41> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 03-12-2018 13:46:41> Backup saved: 032G74_E286D1A4_20181203_134641.extcsd 03-12-2018 13:46:41> EMMC Init completed. 03-12-2018 13:46:41> 03-12-2018 13:46:41> Scan from: 032G74 03-12-2018 13:46:41> 03-12-2018 13:46:41> Vendor: Qualcomm 03-12-2018 13:46:41> Searching GPT ... 03-12-2018 13:46:41> GPT header is found and is valid 03-12-2018 13:46:41> 03-12-2018 13:46:42> GPT header successfully parsed 03-12-2018 13:46:44> 03-12-2018 13:46:44> Scan done 03-12-2018 13:46:44> 03-12-2018 13:46:44> Mount [system] successfully PartType: LINUX 03-12-2018 13:46:44> Mount [data] SKIPPED PartType: Full Disk Encryption 03-12-2018 13:46:44> 03-12-2018 13:57:30> Looking for EasyJTAG box... 03-12-2018 13:57:30> EasyJTAG API ver. 2100 03-12-2018 13:57:30> Setting IO Levels to 1.8V 03-12-2018 13:57:30> Setting frequence to 36 Mhz 03-12-2018 13:57:30> EasyJTAG Box Serial = 617B0E64AEE654F2 03-12-2018 13:57:30> EasyJTAG Box Firmware = 2.30 03-12-2018 13:57:31> Setting interface to EasyJtag2/ISP_HiPower 03-12-2018 13:57:31> Setting bus width to 1 Bit 03-12-2018 13:57:31> HiPower mode is ON 03-12-2018 13:57:31> Setting frequence to 36 Mhz 03-12-2018 13:57:31> CMD Pullup Level: 910 mV 03-12-2018 13:57:31> CMD Active Level: 1879 mV 03-12-2018 13:57:31> eMMC Init returned = 0 03-12-2018 13:57:31> EMMC Device Information : 03-12-2018 13:57:31> EMMC CID: 11010030333247373400E286D1A432A3 03-12-2018 13:57:31> EMMC CSD: D02700320F5903FFFFFFFFE78640009B 03-12-2018 13:57:31> EMMC Manufacture : TOSHIBA , EMMC NAME: 032G74 , HEX: 303332473734 , S/N: E286D1A4 , rev. 0x00 03-12-2018 13:57:31> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2015 03-12-2018 13:57:31> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 03-12-2018 13:57:31> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 03-12-2018 13:57:31> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 03-12-2018 13:57:31> EMMC Permanent Write Protection: No 03-12-2018 13:57:31> EMMC Temporary Write Protection: No 03-12-2018 13:57:31> Extended CSD Information : 03-12-2018 13:57:31> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 03-12-2018 13:57:31> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 03-12-2018 13:57:31> Boot Bus Config: 0x00 , width 1bit 03-12-2018 13:57:31> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 03-12-2018 13:57:31> Supported partition features [PARTITIONING_SUPPORT]: 0x07 03-12-2018 13:57:31> Device supports partitioning features 03-12-2018 13:57:31> Device can have enhanced technological features in partitions and user data area 03-12-2018 13:57:31> Device can have extended partitions attribute 03-12-2018 13:57:31> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 03-12-2018 13:57:31> Backup saved: 032G74_E286D1A4_20181203_135731.extcsd 03-12-2018 13:57:31> EMMC Init completed. 03-12-2018 13:57:31> 03-12-2018 13:57:32> Opening file: E:\Box\Z3X\Easy Jtag\Dumps\LG_H811_dump_rom1.bin 03-12-2018 13:57:32> 03-12-2018 13:57:32> Analyzing Image: LG_H811_dump_rom1.bin 03-12-2018 13:57:32> 03-12-2018 13:57:32> Vendor: Qualcomm 03-12-2018 13:57:32> Searching GPT ... 03-12-2018 13:57:32> GPT header is found and is valid 03-12-2018 13:57:32> 03-12-2018 13:57:32> GPT header successfully parsed 03-12-2018 13:57:32> 03-12-2018 13:58:03> Looking for EasyJTAG box... 03-12-2018 13:58:03> EasyJTAG API ver. 2100 03-12-2018 13:58:03> Setting IO Levels to 1.8V 03-12-2018 13:58:03> Setting frequence to 36 Mhz 03-12-2018 13:58:03> EasyJTAG Box Serial = 617B0E64AEE654F2 03-12-2018 13:58:03> EasyJTAG Box Firmware = 2.30 03-12-2018 13:58:04> Setting interface to EasyJtag2/ISP_HiPower 03-12-2018 13:58:04> Setting bus width to 1 Bit 03-12-2018 13:58:04> HiPower mode is ON 03-12-2018 13:58:04> Setting frequence to 36 Mhz 03-12-2018 13:58:04> CMD Pullup Level: 909 mV 03-12-2018 13:58:04> CMD Active Level: 1878 mV 03-12-2018 13:58:04> eMMC Init returned = 0 03-12-2018 13:58:04> EMMC Device Information : 03-12-2018 13:58:04> EMMC CID: 11010030333247373400E286D1A432A3 03-12-2018 13:58:04> EMMC CSD: D02700320F5903FFFFFFFFE78640009B 03-12-2018 13:58:04> EMMC Manufacture : TOSHIBA , EMMC NAME: 032G74 , HEX: 303332473734 , S/N: E286D1A4 , rev. 0x00 03-12-2018 13:58:04> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2015 03-12-2018 13:58:04> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 03-12-2018 13:58:04> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 03-12-2018 13:58:04> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 03-12-2018 13:58:04> EMMC Permanent Write Protection: No 03-12-2018 13:58:04> EMMC Temporary Write Protection: No 03-12-2018 13:58:04> Extended CSD Information : 03-12-2018 13:58:04> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 03-12-2018 13:58:04> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 03-12-2018 13:58:04> Boot Bus Config: 0x00 , width 1bit 03-12-2018 13:58:04> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 03-12-2018 13:58:04> Supported partition features [PARTITIONING_SUPPORT]: 0x07 03-12-2018 13:58:04> Device supports partitioning features 03-12-2018 13:58:04> Device can have enhanced technological features in partitions and user data area 03-12-2018 13:58:04> Device can have extended partitions attribute 03-12-2018 13:58:04> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 03-12-2018 13:58:04> Backup saved: 032G74_E286D1A4_20181203_135804.extcsd 03-12-2018 13:58:04> EMMC Init completed. 03-12-2018 13:58:04> 03-12-2018 13:58:04> Operation: Write by vendor (Qualcomm/HiSilicon) 03-12-2018 13:58:04> 03-12-2018 13:58:04> Partition name: GPT 03-12-2018 13:58:04> Filename: LG_H811_dump_rom1.bin , Offset: 000000000000 , filesize: 17408 bytes 03-12-2018 13:58:04> eMMC switching to ROM1 03-12-2018 13:58:05> Erasing partition... 03-12-2018 13:58:05> Writing partition... 03-12-2018 13:58:05> Done writing partition. Write speed: 397.07 KB/s 03-12-2018 13:58:05> Partition name: modem 03-12-2018 13:58:05> Filename: LG_H811_dump_rom1.bin , Offset: 000001000000 , filesize: 90177536 bytes 03-12-2018 13:58:05> eMMC switching to ROM1 03-12-2018 13:58:05> Erasing partition... 03-12-2018 13:58:09> Writing partition... 03-12-2018 13:58:10> Error writing at address: 0000012A0000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:58:10> Error writing at address: 000001380000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:58:11> Error writing at address: 000001460000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:58:20> Error writing at address: 0000033E0000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:58:27> Error writing at address: 000004F00000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:58:34> Done writing partition. Write speed: 3465.29 KB/s 03-12-2018 13:58:34> Partition name: pmic 03-12-2018 13:58:34> Filename: LG_H811_dump_rom1.bin , Offset: 000007000000 , filesize: 524288 bytes 03-12-2018 13:58:34> eMMC switching to ROM1 03-12-2018 13:58:34> Erasing partition... 03-12-2018 13:58:35> Writing partition... 03-12-2018 13:58:35> Done writing partition. Write speed: 3271.47 KB/s 03-12-2018 13:58:35> Partition name: sbl1 03-12-2018 13:58:35> Filename: LG_H811_dump_rom1.bin , Offset: 000007080000 , filesize: 1048576 bytes 03-12-2018 13:58:35> eMMC switching to ROM1 03-12-2018 13:58:35> Erasing partition... 03-12-2018 13:58:36> Writing partition... 03-12-2018 13:58:36> Done writing partition. Write speed: 3541.33 KB/s 03-12-2018 13:58:36> Partition name: tz 03-12-2018 13:58:36> Filename: LG_H811_dump_rom1.bin , Offset: 000007180000 , filesize: 1048576 bytes 03-12-2018 13:58:36> eMMC switching to ROM1 03-12-2018 13:58:37> Erasing partition... 03-12-2018 13:58:37> Writing partition... 03-12-2018 13:58:37> Done writing partition. Write speed: 3471.72 KB/s 03-12-2018 13:58:37> Partition name: sdi 03-12-2018 13:58:37> Filename: LG_H811_dump_rom1.bin , Offset: 000007280000 , filesize: 524288 bytes 03-12-2018 13:58:37> eMMC switching to ROM1 03-12-2018 13:58:38> Erasing partition... 03-12-2018 13:58:38> Writing partition... 03-12-2018 13:58:38> Done writing partition. Write speed: 3448.32 KB/s 03-12-2018 13:58:38> Partition name: hyp 03-12-2018 13:58:38> Filename: LG_H811_dump_rom1.bin , Offset: 000007300000 , filesize: 524288 bytes 03-12-2018 13:58:38> eMMC switching to ROM1 03-12-2018 13:58:39> Erasing partition... 03-12-2018 13:58:39> Writing partition... 03-12-2018 13:58:39> Done writing partition. Write speed: 3609.31 KB/s 03-12-2018 13:58:39> Partition name: rpm 03-12-2018 13:58:39> Filename: LG_H811_dump_rom1.bin , Offset: 000007380000 , filesize: 524288 bytes 03-12-2018 13:58:39> eMMC switching to ROM1 03-12-2018 13:58:40> Erasing partition... 03-12-2018 13:58:40> Writing partition... 03-12-2018 13:58:40> Done writing partition. Write speed: 3469.11 KB/s 03-12-2018 13:58:40> Partition name: aboot 03-12-2018 13:58:40> Filename: LG_H811_dump_rom1.bin , Offset: 000007400000 , filesize: 2097152 bytes 03-12-2018 13:58:40> eMMC switching to ROM1 03-12-2018 13:58:41> Erasing partition... 03-12-2018 13:58:41> Writing partition... 03-12-2018 13:58:42> Done writing partition. Write speed: 3670.70 KB/s 03-12-2018 13:58:42> Partition name: sbl1bak 03-12-2018 13:58:42> Filename: LG_H811_dump_rom1.bin , Offset: 000007600000 , filesize: 1048576 bytes 03-12-2018 13:58:42> eMMC switching to ROM1 03-12-2018 13:58:42> Erasing partition... 03-12-2018 13:58:43> Writing partition... 03-12-2018 13:58:43> Done writing partition. Write speed: 3469.02 KB/s 03-12-2018 13:58:43> Partition name: pmicbak 03-12-2018 13:58:43> Filename: LG_H811_dump_rom1.bin , Offset: 000007700000 , filesize: 524288 bytes 03-12-2018 13:58:43> eMMC switching to ROM1 03-12-2018 13:58:43> Erasing partition... 03-12-2018 13:58:44> Writing partition... 03-12-2018 13:58:44> Done writing partition. Write speed: 3452.77 KB/s 03-12-2018 13:58:44> Partition name: tzbak 03-12-2018 13:58:44> Filename: LG_H811_dump_rom1.bin , Offset: 000007780000 , filesize: 1048576 bytes 03-12-2018 13:58:44> eMMC switching to ROM1 03-12-2018 13:58:44> Erasing partition... 03-12-2018 13:58:45> Writing partition... 03-12-2018 13:58:45> Done writing partition. Write speed: 3655.49 KB/s 03-12-2018 13:58:45> Partition name: hypbak 03-12-2018 13:58:45> Filename: LG_H811_dump_rom1.bin , Offset: 000007880000 , filesize: 524288 bytes 03-12-2018 13:58:45> eMMC switching to ROM1 03-12-2018 13:58:45> Erasing partition... 03-12-2018 13:58:46> Writing partition... 03-12-2018 13:58:46> Done writing partition. Write speed: 3600.94 KB/s 03-12-2018 13:58:46> Partition name: rpmbak 03-12-2018 13:58:46> Filename: LG_H811_dump_rom1.bin , Offset: 000007900000 , filesize: 524288 bytes 03-12-2018 13:58:46> eMMC switching to ROM1 03-12-2018 13:58:46> Erasing partition... 03-12-2018 13:58:47> Writing partition... 03-12-2018 13:58:47> Done writing partition. Write speed: 3122.71 KB/s 03-12-2018 13:58:47> Partition name: abootbak 03-12-2018 13:58:47> Filename: LG_H811_dump_rom1.bin , Offset: 000007980000 , filesize: 2097152 bytes 03-12-2018 13:58:47> eMMC switching to ROM1 03-12-2018 13:58:47> Erasing partition... 03-12-2018 13:58:48> Writing partition... 03-12-2018 13:58:48> Done writing partition. Write speed: 3669.59 KB/s 03-12-2018 13:58:48> Partition name: sdibak 03-12-2018 13:58:48> Filename: LG_H811_dump_rom1.bin , Offset: 000007B80000 , filesize: 524288 bytes 03-12-2018 13:58:48> eMMC switching to ROM1 03-12-2018 13:58:49> Erasing partition... 03-12-2018 13:58:49> Writing partition... 03-12-2018 13:58:49> Done writing partition. Write speed: 3776.50 KB/s 03-12-2018 13:58:49> Partition name: limits 03-12-2018 13:58:49> Filename: LG_H811_dump_rom1.bin , Offset: 000007C00000 , filesize: 524288 bytes 03-12-2018 13:58:49> eMMC switching to ROM1 03-12-2018 13:58:50> Erasing partition... 03-12-2018 13:58:50> Writing partition... 03-12-2018 13:58:50> Done writing partition. Write speed: 3451.69 KB/s 03-12-2018 13:58:50> Partition name: devinfo 03-12-2018 13:58:50> Filename: LG_H811_dump_rom1.bin , Offset: 000007C80000 , filesize: 524288 bytes 03-12-2018 13:58:50> eMMC switching to ROM1 03-12-2018 13:58:51> Erasing partition... 03-12-2018 13:58:51> Writing partition... 03-12-2018 13:58:51> Done writing partition. Write speed: 3451.62 KB/s 03-12-2018 13:58:51> Partition name: apdp 03-12-2018 13:58:51> Filename: LG_H811_dump_rom1.bin , Offset: 000007D00000 , filesize: 524288 bytes 03-12-2018 13:58:51> eMMC switching to ROM1 03-12-2018 13:58:52> Erasing partition... 03-12-2018 13:58:52> Writing partition... 03-12-2018 13:58:52> Done writing partition. Write speed: 3616.58 KB/s 03-12-2018 13:58:52> Partition name: msadp 03-12-2018 13:58:52> Filename: LG_H811_dump_rom1.bin , Offset: 000007D80000 , filesize: 524288 bytes 03-12-2018 13:58:52> eMMC switching to ROM1 03-12-2018 13:58:53> Erasing partition... 03-12-2018 13:58:53> Writing partition... 03-12-2018 13:58:53> Done writing partition. Write speed: 3472.59 KB/s 03-12-2018 13:58:53> Partition name: dpo 03-12-2018 13:58:53> Filename: LG_H811_dump_rom1.bin , Offset: 000007E00000 , filesize: 524288 bytes 03-12-2018 13:58:53> eMMC switching to ROM1 03-12-2018 13:58:54> Erasing partition... 03-12-2018 13:58:54> Writing partition... 03-12-2018 13:58:54> Done writing partition. Write speed: 3463.35 KB/s 03-12-2018 13:58:54> Partition name: spare1 03-12-2018 13:58:54> Filename: LG_H811_dump_rom1.bin , Offset: 000007E80000 , filesize: 1572864 bytes 03-12-2018 13:58:54> eMMC switching to ROM1 03-12-2018 13:58:55> Erasing partition... 03-12-2018 13:58:55> Writing partition... 03-12-2018 13:58:56> Done writing partition. Write speed: 3678.50 KB/s 03-12-2018 13:58:56> Partition name: misc 03-12-2018 13:58:56> Filename: LG_H811_dump_rom1.bin , Offset: 000008000000 , filesize: 16777216 bytes 03-12-2018 13:58:56> eMMC switching to ROM1 03-12-2018 13:58:56> Erasing partition... 03-12-2018 13:58:57> Writing partition... 03-12-2018 13:59:01> Done writing partition. Write speed: 3806.71 KB/s 03-12-2018 13:59:01> Partition name: persist 03-12-2018 13:59:01> Filename: LG_H811_dump_rom1.bin , Offset: 000009000000 , filesize: 33554432 bytes 03-12-2018 13:59:01> eMMC switching to ROM1 03-12-2018 13:59:01> Erasing partition... 03-12-2018 13:59:03> Writing partition... 03-12-2018 13:59:11> Done writing partition. Write speed: 3829.78 KB/s 03-12-2018 13:59:11> Partition name: modemst1 03-12-2018 13:59:11> Filename: LG_H811_dump_rom1.bin , Offset: 00000B000000 , filesize: 1572864 bytes 03-12-2018 13:59:11> eMMC switching to ROM1 03-12-2018 13:59:11> Erasing partition... 03-12-2018 13:59:12> Writing partition... 03-12-2018 13:59:12> Done writing partition. Write speed: 3883.07 KB/s 03-12-2018 13:59:12> Partition name: modemst2 03-12-2018 13:59:12> Filename: LG_H811_dump_rom1.bin , Offset: 00000B180000 , filesize: 1572864 bytes 03-12-2018 13:59:12> eMMC switching to ROM1 03-12-2018 13:59:13> Erasing partition... 03-12-2018 13:59:13> Writing partition... 03-12-2018 13:59:14> Done writing partition. Write speed: 3879.72 KB/s 03-12-2018 13:59:14> Partition name: fsg 03-12-2018 13:59:14> Filename: LG_H811_dump_rom1.bin , Offset: 00000B300000 , filesize: 1572864 bytes 03-12-2018 13:59:14> eMMC switching to ROM1 03-12-2018 13:59:14> Erasing partition... 03-12-2018 13:59:14> Writing partition... 03-12-2018 13:59:15> Done writing partition. Write speed: 3674.73 KB/s 03-12-2018 13:59:15> Partition name: fsc 03-12-2018 13:59:15> Filename: LG_H811_dump_rom1.bin , Offset: 00000B480000 , filesize: 524288 bytes 03-12-2018 13:59:15> eMMC switching to ROM1 03-12-2018 13:59:15> Erasing partition... 03-12-2018 13:59:16> Writing partition... 03-12-2018 13:59:16> Done writing partition. Write speed: 3602.91 KB/s 03-12-2018 13:59:16> Partition name: ssd 03-12-2018 13:59:16> Filename: LG_H811_dump_rom1.bin , Offset: 00000B500000 , filesize: 524288 bytes 03-12-2018 13:59:16> eMMC switching to ROM1 03-12-2018 13:59:16> Erasing partition... 03-12-2018 13:59:17> Writing partition... 03-12-2018 13:59:17> Done writing partition. Write speed: 3608.68 KB/s 03-12-2018 13:59:17> Partition name: keystore 03-12-2018 13:59:17> Filename: LG_H811_dump_rom1.bin , Offset: 00000B580000 , filesize: 524288 bytes 03-12-2018 13:59:17> eMMC switching to ROM1 03-12-2018 13:59:17> Erasing partition... 03-12-2018 13:59:18> Writing partition... 03-12-2018 13:59:18> Done writing partition. Write speed: 3465.90 KB/s 03-12-2018 13:59:18> Partition name: DDR 03-12-2018 13:59:18> Filename: LG_H811_dump_rom1.bin , Offset: 00000B600000 , filesize: 2097152 bytes 03-12-2018 13:59:18> eMMC switching to ROM1 03-12-2018 13:59:18> Erasing partition... 03-12-2018 13:59:19> Writing partition... 03-12-2018 13:59:19> Done writing partition. Write speed: 3567.35 KB/s 03-12-2018 13:59:19> Partition name: sec 03-12-2018 13:59:19> Filename: LG_H811_dump_rom1.bin , Offset: 00000B800000 , filesize: 524288 bytes 03-12-2018 13:59:19> eMMC switching to ROM1 03-12-2018 13:59:20> Erasing partition... 03-12-2018 13:59:20> Writing partition... 03-12-2018 13:59:20> Done writing partition. Write speed: 3604.22 KB/s 03-12-2018 13:59:20> Partition name: encrypt 03-12-2018 13:59:20> Filename: LG_H811_dump_rom1.bin , Offset: 00000B880000 , filesize: 524288 bytes 03-12-2018 13:59:20> eMMC switching to ROM1 03-12-2018 13:59:21> Erasing partition... 03-12-2018 13:59:21> Writing partition... 03-12-2018 13:59:21> Done writing partition. Write speed: 3448.62 KB/s 03-12-2018 13:59:21> Partition name: eksst 03-12-2018 13:59:21> Filename: LG_H811_dump_rom1.bin , Offset: 00000B900000 , filesize: 524288 bytes 03-12-2018 13:59:21> eMMC switching to ROM1 03-12-2018 13:59:22> Erasing partition... 03-12-2018 13:59:22> Writing partition... 03-12-2018 13:59:22> Done writing partition. Write speed: 3450.37 KB/s 03-12-2018 13:59:22> Partition name: rct 03-12-2018 13:59:22> Filename: LG_H811_dump_rom1.bin , Offset: 00000B980000 , filesize: 524288 bytes 03-12-2018 13:59:22> eMMC switching to ROM1 03-12-2018 13:59:23> Erasing partition... 03-12-2018 13:59:23> Writing partition... 03-12-2018 13:59:23> Done writing partition. Write speed: 3443.86 KB/s 03-12-2018 13:59:23> Partition name: persistent 03-12-2018 13:59:23> Filename: LG_H811_dump_rom1.bin , Offset: 00000BA00000 , filesize: 2097152 bytes 03-12-2018 13:59:23> eMMC switching to ROM1 03-12-2018 13:59:24> Erasing partition... 03-12-2018 13:59:24> Writing partition... 03-12-2018 13:59:25> Done writing partition. Write speed: 3670.37 KB/s 03-12-2018 13:59:25> Partition name: spare2 03-12-2018 13:59:25> Filename: LG_H811_dump_rom1.bin , Offset: 00000BC00000 , filesize: 4194304 bytes 03-12-2018 13:59:25> eMMC switching to ROM1 03-12-2018 13:59:25> Erasing partition... 03-12-2018 13:59:26> Writing partition... 03-12-2018 13:59:27> Done writing partition. Write speed: 3735.73 KB/s 03-12-2018 13:59:27> Partition name: laf 03-12-2018 13:59:27> Filename: LG_H811_dump_rom1.bin , Offset: 00000C000000 , filesize: 50331648 bytes 03-12-2018 13:59:27> eMMC switching to ROM1 03-12-2018 13:59:27> Erasing partition... 03-12-2018 13:59:28> Writing partition... 03-12-2018 13:59:41> Done writing partition. Write speed: 3835.41 KB/s 03-12-2018 13:59:41> Partition name: boot 03-12-2018 13:59:41> Filename: LG_H811_dump_rom1.bin , Offset: 00000F000000 , filesize: 41943040 bytes 03-12-2018 13:59:41> eMMC switching to ROM1 03-12-2018 13:59:42> Erasing partition... 03-12-2018 13:59:43> Writing partition... 03-12-2018 13:59:45> Error writing at address: 00000F620000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:59:46> Error writing at address: 00000F8C0000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:59:47> Error writing at address: 00000FD20000 , error: -8, DATA SND CRC Error ... Retry #1 03-12-2018 13:59:55> Done writing partition. Write speed: 3461.66 KB/s 03-12-2018 13:59:55> 03-12-2018 13:59:55> Partition USERDATA : formatting as EXT4. Please wait ... 03-12-2018 13:59:56> Error writing at address: 000179005000 ... Retry #1 03-12-2018 13:59:57> Error writing at address: 000179205000 ... Retry #1 03-12-2018 14:00:03> Formatting completed 03-12-2018 14:00:03> 03-12-2018 14:00:03> Check BootConfig for the selected vendor 03-12-2018 14:00:03> 03-12-2018 14:00:03> All done time: [00:01:59:043] 03-12-2018 14:00:03> 03-12-2018 14:08:03> Looking for EasyJTAG box... 03-12-2018 14:08:03> EasyJTAG API ver. 2100 03-12-2018 14:08:03> Setting IO Levels to 1.8V 03-12-2018 14:08:03> Setting frequence to 36 Mhz 03-12-2018 14:08:03> EasyJTAG Box Serial = 617B0E64AEE654F2 03-12-2018 14:08:03> EasyJTAG Box Firmware = 2.30 03-12-2018 14:08:03> Setting interface to EasyJtag2/ISP 03-12-2018 14:08:03> Setting bus width to 1 Bit 03-12-2018 14:08:03> 03-12-2018 14:08:59> Looking for EasyJTAG box... 03-12-2018 14:08:59> EasyJTAG API ver. 2100 03-12-2018 14:08:59> Setting IO Levels to 1.8V 03-12-2018 14:08:59> Setting frequence to 36 Mhz 03-12-2018 14:08:59> EasyJTAG Box Serial = 617B0E64AEE654F2 03-12-2018 14:08:59> EasyJTAG Box Firmware = 2.30 03-12-2018 14:09:00> Setting interface to EasyJtag2/ISP 03-12-2018 14:09:00> Setting bus width to 1 Bit 03-12-2018 14:09:00> Setting frequence to 36 Mhz 03-12-2018 14:09:00> CMD Pullup Level: 914 mV 03-12-2018 14:09:00> CMD Active Level: 1878 mV 03-12-2018 14:09:00> eMMC Init returned = 0 03-12-2018 14:09:00> EMMC Device Information : 03-12-2018 14:09:00> EMMC CID: 11010030333247373400E286D1A432A3 03-12-2018 14:09:00> EMMC CSD: D02700320F5903FFFFFFFFE78640009B 03-12-2018 14:09:00> EMMC Manufacture : TOSHIBA , EMMC NAME: 032G74 , HEX: 303332473734 , S/N: E286D1A4 , rev. 0x00 03-12-2018 14:09:00> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2015 03-12-2018 14:09:00> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 03-12-2018 14:09:00> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 03-12-2018 14:09:00> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 03-12-2018 14:09:00> EMMC Permanent Write Protection: No 03-12-2018 14:09:00> EMMC Temporary Write Protection: No 03-12-2018 14:09:00> Extended CSD Information : 03-12-2018 14:09:00> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 03-12-2018 14:09:00> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 03-12-2018 14:09:00> Boot Bus Config: 0x00 , width 1bit 03-12-2018 14:09:00> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 03-12-2018 14:09:00> Supported partition features [PARTITIONING_SUPPORT]: 0x07 03-12-2018 14:09:00> Device supports partitioning features 03-12-2018 14:09:00> Device can have enhanced technological features in partitions and user data area 03-12-2018 14:09:00> Device can have extended partitions attribute 03-12-2018 14:09:00> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 03-12-2018 14:09:00> Backup saved: 032G74_E286D1A4_20181203_140900.extcsd 03-12-2018 14:09:00> EMMC Init completed. 03-12-2018 14:09:00> 03-12-2018 14:09:00> Scanning soft partitions 03-12-2018 14:09:00> GPT header is found and is valid 03-12-2018 14:09:00> Partition: modem, [000001000000 - 000006600000], size: 000005600000 (86.0 MB) 03-12-2018 14:09:00> Partition: pmic, [000007000000 - 000007080000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: sbl1, [000007080000 - 000007180000], size: 000000100000 (1.00 MB) 03-12-2018 14:09:00> Partition: tz, [000007180000 - 000007280000], size: 000000100000 (1.00 MB) 03-12-2018 14:09:00> Partition: sdi, [000007280000 - 000007300000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: hyp, [000007300000 - 000007380000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: rpm, [000007380000 - 000007400000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: aboot, [000007400000 - 000007600000], size: 000000200000 (2.00 MB) 03-12-2018 14:09:00> Partition: sbl1bak, [000007600000 - 000007700000], size: 000000100000 (1.00 MB) 03-12-2018 14:09:00> Partition: pmicbak, [000007700000 - 000007780000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: tzbak, [000007780000 - 000007880000], size: 000000100000 (1.00 MB) 03-12-2018 14:09:00> Partition: hypbak, [000007880000 - 000007900000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: rpmbak, [000007900000 - 000007980000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: abootbak, [000007980000 - 000007B80000], size: 000000200000 (2.00 MB) 03-12-2018 14:09:00> Partition: sdibak, [000007B80000 - 000007C00000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: limits, [000007C00000 - 000007C80000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: devinfo, [000007C80000 - 000007D00000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: apdp, [000007D00000 - 000007D80000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: msadp, [000007D80000 - 000007E00000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: dpo, [000007E00000 - 000007E80000], size: 000000080000 (512. KB) 03-12-2018 14:09:00> Partition: spare1, [000007E80000 - 000008000000], size: 000000180000 (1.50 MB) 03-12-2018 14:09:00> Partition: misc, [000008000000 - 000009000000], size: 000001000000 (16.0 MB) 03-12-2018 14:09:00> Partition: persist, [000009000000 - 00000B000000], size: 000002000000 (32.0 MB) 03-12-2018 14:09:00> Partition: modemst1, [00000B000000 - 00000B180000], size: 000000180000 (1.50 MB) 03-12-2018 14:09:00> Partition: modemst2, [00000B180000 - 00000B300000], size: 000000180000 (1.50 MB) 03-12-2018 14:09:01> Partition: fsg, [00000B300000 - 00000B480000], size: 000000180000 (1.50 MB) 03-12-2018 14:09:01> Partition: fsc, [00000B480000 - 00000B500000], size: 000000080000 (512. KB) 03-12-2018 14:09:01> Partition: ssd, [00000B500000 - 00000B580000], size: 000000080000 (512. KB) 03-12-2018 14:09:01> Partition: keystore, [00000B580000 - 00000B600000], size: 000000080000 (512. KB) 03-12-2018 14:09:01> Partition: DDR, [00000B600000 - 00000B800000], size: 000000200000 (2.00 MB) 03-12-2018 14:09:01> Partition: sec, [00000B800000 - 00000B880000], size: 000000080000 (512. KB) 03-12-2018 14:09:01> Partition: encrypt, [00000B880000 - 00000B900000], size: 000000080000 (512. KB) 03-12-2018 14:09:01> Partition: eksst, [00000B900000 - 00000B980000], size: 000000080000 (512. KB) 03-12-2018 14:09:01> Partition: rct, [00000B980000 - 00000BA00000], size: 000000080000 (512. KB) 03-12-2018 14:09:01> Partition: persistent, [00000BA00000 - 00000BC00000], size: 000000200000 (2.00 MB) 03-12-2018 14:09:01> Partition: spare2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) 03-12-2018 14:09:01> Partition: laf, [00000C000000 - 00000F000000], size: 000003000000 (48.0 MB) 03-12-2018 14:09:01> Partition: boot, [00000F000000 - 000011800000], size: 000002800000 (40.0 MB) 03-12-2018 14:09:01> Partition: recovery, [000011800000 - 000014000000], size: 000002800000 (40.0 MB) 03-12-2018 14:09:01> Partition: drm, [000014000000 - 000014800000], size: 000000800000 (8.00 MB) 03-12-2018 14:09:01> Partition: sns, [000014800000 - 000015000000], size: 000000800000 (8.00 MB) 03-12-2018 14:09:01> Partition: mpt, [000015000000 - 000017000000], size: 000002000000 (32.0 MB) 03-12-2018 14:09:01> Partition: eri, [000017000000 - 000017800000], size: 000000800000 (8.00 MB) 03-12-2018 14:09:01> Partition: raw_resources, [000017800000 - 000017C00000], size: 000000400000 (4.00 MB) 03-12-2018 14:09:01> Partition: raw_resourcesbak, [000017C00000 - 000018000000], size: 000000400000 (4.00 MB) 03-12-2018 14:09:01> Partition: operatorlogging, [000018000000 - 000019000000], size: 000001000000 (16.0 MB) 03-12-2018 14:09:01> Partition: carrier, [000019000000 - 00001B800000], size: 000002800000 (40.0 MB) 03-12-2018 14:09:01> Partition: felica, [00001B800000 - 00001C000000], size: 000000800000 (8.00 MB) 03-12-2018 14:09:01> Partition: factory, [00001C000000 - 00001EE00000], size: 000002E00000 (46.0 MB) 03-12-2018 14:09:01> Partition: spare3, [00001EE00000 - 00001F000000], size: 000000200000 (2.00 MB) 03-12-2018 14:09:01> Partition: fota, [00001F000000 - 00001FA00000], size: 000000A00000 (10.0 MB) 03-12-2018 14:09:01> Partition: spare4, [00001FA00000 - 000020000000], size: 000000600000 (6.00 MB) 03-12-2018 14:09:01> Partition: system, [000020000000 - 00012BC00000], size: 00010BC00000 (4.18 GB) 03-12-2018 14:09:01> Partition: cache, [00012BC00000 - 000178C00000], size: 00004D000000 (1.20 GB) 03-12-2018 14:09:01> Partition: userdata, [000178C00000 - 000747000000], size: 0005CE400000 (23.2 GB) 03-12-2018 14:09:01> Partition: grow, [000747000000 - 000747BFBE00], size: 000000BFBE00 (11.9 MB) 03-12-2018 14:09:01> GPT header successfully parsed 03-12-2018 14:09:01> 03-12-2018 14:09:01> Get firmware version 03-12-2018 14:09:01> 03-12-2018 14:09:02> Firmware info not found ------------------------------------------------------------------ Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.3.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 617B0E64AEE654F2, ,FW Ver.: 02.30 CMD Pullup Level:1595 mV CMD Active Level:2529 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.3.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 617B0E64AEE654F2, ,FW Ver.: 02.30 CMD Pullup Level:817 mV CMD Active Level:2308 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Checking security ... Z3X EasyJtag Software ver. 3.3.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1584 mV CMD Active Level:2530 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.3.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 617B0E64AEE654F2, ,FW Ver.: 02.30 CMD Pullup Level:811 mV CMD Active Level:2335 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 11010030333247373400E286D1A432A3 eMMC CSD : D02700320F5903FFFFFFFFE78640009B eMMC Manufacturer ID: 0011 , OEM ID: 0100 eMMC Date: 03/2015 Rev.0x0 eMMC NAME: 032G74 , S/N: 3800486308 eMMC NAME (HEX): 303332473734 IC Name: TOSHIBA , eSD_THGBMFG8C4LBAIR/32GB @FBGA153 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 032G74_3800486308_20181203_1419.extcsd Done. ---------------------------------------------------------------- Is it possible to convert H810(US) to H815(International) |
This phones are have bad soldered CPU/RAM To repair it at 90% of cases you need reboll CPU/RAM |
