Old 12-22-2017, 15:26   #1 (permalink)
gsm_shamim's Avatar
Member: 1845954
Sonork: 100.1622497
Thanks Meter: 397
LG H811 boot repair done but phone no power
EasyJtag Suite Classic ver.: 2.8.0.2 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 7 (build 7600). Admin rights OK
Android Explorer ver:1.0.0.24
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.11.3
QUALCOMM Direct ver:1.0.6306.57125
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AA43-C247 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Compression is ON
Z3X EasyJtag Software ver. 2.8.0.2
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0EFF901ADE07A5AB, ,FW Ver.: 01.62
CMD Pullup Level:402 mV
CMD Active Level:1897 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
Compression is ON
CMD Pullup Level:2010 mV
CMD Active Level:2526 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
---------- eMMC Device Information ----------
EMMC CID : 11010030333247333200506866E41314
EMMC CSD : D02700328F5903FFFFFFFFE7864000A6
EMMC Manufacturer ID: 0011 , OEM ID: 0100
EMMC Date: 01/2016 Rev.0x0
EMMC NAME: 032G32 , S/N: 1349019364
EMMC NAME (HEX): 30333247333200
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 032G32_1349019364_20171222_2015.extcsd
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 61071326
Found Data areas (firmware parts) count is: 56
Partition info successfully found
P0 (MODEM) [0x1000000 0x5600000] Size: 86.0MB
P1 (PMIC) [0x7000000 0x80000] Size: 512.0KB
P2 (SBL1) [0x7080000 0x100000] Size: 1.0MB
P3 (TZ) [0x7180000 0x100000] Size: 1.0MB
P4 (SDI) [0x7280000 0x80000] Size: 512.0KB
P5 (HYP) [0x7300000 0x80000] Size: 512.0KB
P6 (RPM) [0x7380000 0x80000] Size: 512.0KB
P7 (ABOOT) [0x7400000 0x200000] Size: 2.0MB
P8 (SBL1BAK) [0x7600000 0x100000] Size: 1.0MB
P9 (PMICBAK) [0x7700000 0x80000] Size: 512.0KB
P10 (TZBAK) [0x7780000 0x100000] Size: 1.0MB
P11 (HYPBAK) [0x7880000 0x80000] Size: 512.0KB
P12 (RPMBAK) [0x7900000 0x80000] Size: 512.0KB
P13 (ABOOTBAK) [0x7980000 0x200000] Size: 2.0MB
P14 (SDIBAK) [0x7b80000 0x80000] Size: 512.0KB
P15 (LIMITS) [0x7c00000 0x80000] Size: 512.0KB
P16 (DEVINFO) [0x7c80000 0x80000] Size: 512.0KB
P17 (APDP) [0x7d00000 0x80000] Size: 512.0KB
P18 (MSADP) [0x7d80000 0x80000] Size: 512.0KB
P19 (DPO) [0x7e00000 0x80000] Size: 512.0KB
P20 (SPARE1) [0x7e80000 0x180000] Size: 1.500MB
P21 (MISC) [0x8000000 0x1000000] Size: 16.0MB
P22 (PERSIST) [0x9000000 0x2000000] Size: 32.0MB
P23 (MODEMST1) [0xb000000 0x180000] Size: 1.500MB
P24 (MODEMST2) [0xb180000 0x180000] Size: 1.500MB
P25 (FSG) [0xb300000 0x180000] Size: 1.500MB
P26 (FSC) [0xb480000 0x80000] Size: 512.0KB
P27 (SSD) [0xb500000 0x80000] Size: 512.0KB
P28 (KEYSTORE) [0xb580000 0x80000] Size: 512.0KB
P29 (DDR) [0xb600000 0x200000] Size: 2.0MB
P30 (SEC) [0xb800000 0x80000] Size: 512.0KB
P31 (ENCRYPT) [0xb880000 0x80000] Size: 512.0KB
P32 (EKSST) [0xb900000 0x80000] Size: 512.0KB
P33 (RCT) [0xb980000 0x80000] Size: 512.0KB
P34 (PERSISTENT) [0xba00000 0x200000] Size: 2.0MB
P35 (SPARE2) [0xbc00000 0x400000] Size: 4.0MB
P36 (LAF) [0xc000000 0x3000000] Size: 48.0MB
P37 (BOOT) [0xf000000 0x2800000] Size: 40.0MB
P38 (RECOVERY) [0x11800000 0x2800000] Size: 40.0MB
P39 (DRM) [0x14000000 0x800000] Size: 8.0MB
P40 (SNS) [0x14800000 0x800000] Size: 8.0MB
P41 (MPT) [0x15000000 0x2000000] Size: 32.0MB
P42 (ERI) [0x17000000 0x800000] Size: 8.0MB
P43 (RAW_RESOURCES) [0x17800000 0x400000] Size: 4.0MB
P44 (RAW_RESOURCESBAK) [0x17c00000 0x400000] Size: 4.0MB
P45 (OPERATORLOGGING) [0x18000000 0x1000000] Size: 16.0MB
P46 (CARRIER) [0x19000000 0x2800000] Size: 40.0MB
P47 (FELICA) [0x1b800000 0x800000] Size: 8.0MB
P48 (FACTORY) [0x1c000000 0x2e00000] Size: 46.0MB
P49 (SPARE3) [0x1ee00000 0x200000] Size: 2.0MB
P50 (FOTA) [0x1f000000 0xa00000] Size: 10.0MB
P51 (SPARE4) [0x1fa00000 0x600000] Size: 6.0MB
P52 (SYSTEM) [0x20000000 0x10bc00000] Size: 4.183GB
P53 (CACHE) [0x12bc00000 0x4d000000] Size: 1.203GB
P54 (USERDATA) [0x178c00000 0x5ce400000] Size: 23.222GB
P55 (GROW) [0x747000000 0xbfbe00] Size: 11.983MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0020000000 (4.183GB)
Build ID: MRA58K
Display Build ID: MRA58K
Release ID: 6.0
Device Model: LG-H811
Device Name: p1_tmo_us
Architecture ABI: arm64-v8a
Device manufacturer: LGE
Device Platform: msm8992
Product ID: p1
Build Description: p1_tmo_us-user 6.0 MRA58K 161651603dd1f release-keys
Done.
Checking NAND Image : E:\Lg\H811\Dead boot repair\Easy Jtag file\LG_H811_dump_rom1.bin
Autodetected RAW data
Warning! Disk size is smaller than the main header indicates! Loading
Caution: invalid backup GPT header, but valid main header!
GPT: damaged
Linux partitions is not found in image...
File successefuly loaded!
Real (Hardware) Disk/Image size: 8C000 sectors 280.0 MiB
Processing file...E:\Lg\H811\Dead boot repair\Easy Jtag file\LG_H811_dump_rom1.bin
Writing as RAW data
Skip loading eMMC Addon Firmware
Input file : E:\Lg\H811\Dead boot repair\Easy Jtag file\LG_H811_dump_rom1.bin
Writing 0011800000 bytes to 0000000000... ROM1 (USER ROM)
Done, time taken: 134 sec. Average Write Speed: 2177 kB/s
Old 12-23-2017, 14:53   #2 (permalink)
gsm_shamim's Avatar
Member: 1845954
Sonork: 100.1622497
Thanks Meter: 397
Dear team where u. Replay here.
Old 12-24-2017, 08:55   #3 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
I'm sure you have CPU problem because all models based on MSM8992 have problem
Anyway.you can test.just reheat CPU for 5~10 second then try power on
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post:
Old 12-25-2017, 05:53   #4 (permalink)
gsm_shamim's Avatar
Member: 1845954
Sonork: 100.1622497
Thanks Meter: 397
Originally Posted by babak nuri View Post
hi
i'm sure you have cpu problem because all models based on msm8992 have problem
anyway.you can test.just reheat cpu for 5~10 second then try power on
phone was dead after flash.
Page generated in 0.15627 seconds with 8 queries
