05-11-2019, 16:37 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: UAE
Member: 157870 Status: Offline Thanks Meter: 29 | LG H815 Repair Boot Failed I have a hang on logo LG G4 H815. I flashed it so it become dead. then flashed it with ROM1 from the support; still dead. then flashed it with ROM1, ROM2, SD-Card from a link in this forum; still dead. here is the last LOG, Please HELP: Code: Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 01FFxxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:1722 mV CMD Active Level:1753 mV Box IO Level:1800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 11010030333247373400C79656B242DC eMMC CSD : D02700320F5903FFFFFFFFE78640009A eMMC Manufacturer ID: 0011 , OEM ID: 0100 eMMC Date: 04/2015 Rev.0x0 eMMC NAME: 032G74 , S/N: 3348518578 eMMC NAME (HEX): 303332473734 IC Name: TOSHIBA , eSD_THGBMFG8C4LBAIR/32GB @FBGA153 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 372 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 032G74_3348518578_20190511_1827.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Partition info successfully found Found Data areas (firmware parts) count is: 51 --------------------------------------------- P0 (MODEM) [0x1000000 0x5600000] Size: 86.0MB P1 (PMIC) [0x7000000 0x80000] Size: 512.0KB P2 (SBL1) [0x7080000 0x100000] Size: 1.0MB P3 (TZ) [0x7180000 0x100000] Size: 1.0MB P4 (SDI) [0x7280000 0x80000] Size: 512.0KB P5 (HYP) [0x7300000 0x80000] Size: 512.0KB P6 (RPM) [0x7380000 0x80000] Size: 512.0KB P7 (ABOOT) [0x7400000 0x200000] Size: 2.0MB P8 (SBL1BAK) [0x7600000 0x100000] Size: 1.0MB P9 (PMICBAK) [0x7700000 0x80000] Size: 512.0KB P10 (TZBAK) [0x7780000 0x100000] Size: 1.0MB P11 (HYPBAK) [0x7880000 0x80000] Size: 512.0KB P12 (RPMBAK) [0x7900000 0x80000] Size: 512.0KB P13 (ABOOTBAK) [0x7980000 0x200000] Size: 2.0MB P14 (SDIBAK) [0x7b80000 0x80000] Size: 512.0KB P15 (LIMITS) [0x7c00000 0x80000] Size: 512.0KB P16 (DEVINFO) [0x7c80000 0x80000] Size: 512.0KB P17 (APDP) [0x7d00000 0x80000] Size: 512.0KB P18 (MSADP) [0x7d80000 0x80000] Size: 512.0KB P19 (DPO) [0x7e00000 0x80000] Size: 512.0KB P20 (SPARE1) [0x7e80000 0x180000] Size: 1.500MB P21 (MISC) [0x8000000 0x1000000] Size: 16.0MB P22 (PERSIST) [0x9000000 0x2000000] Size: 32.0MB P23 (MODEMST1) [0xb000000 0x180000] Size: 1.500MB P24 (MODEMST2) [0xb180000 0x180000] Size: 1.500MB P25 (FSG) [0xb300000 0x180000] Size: 1.500MB P26 (FSC) [0xb480000 0x80000] Size: 512.0KB P27 (SSD) [0xb500000 0x80000] Size: 512.0KB P28 (KEYSTORE) [0xb580000 0x80000] Size: 512.0KB P29 (DDR) [0xb600000 0x200000] Size: 2.0MB P30 (SEC) [0xb800000 0x80000] Size: 512.0KB P31 (ENCRYPT) [0xb880000 0x80000] Size: 512.0KB P32 (EKSST) [0xb900000 0x80000] Size: 512.0KB P33 (RCT) [0xb980000 0x80000] Size: 512.0KB P34 (PERSISTENT) [0xba00000 0x200000] Size: 2.0MB P35 (SPARE2) [0xbc00000 0x400000] Size: 4.0MB P36 (LAF) [0xc000000 0x3000000] Size: 48.0MB P37 (BOOT) [0xf000000 0x2800000] Size: 40.0MB P38 (RECOVERY) [0x11800000 0x2800000] Size: 40.0MB P39 (DRM) [0x14000000 0x800000] Size: 8.0MB P40 (SNS) [0x14800000 0x800000] Size: 8.0MB P41 (MPT) [0x15000000 0x2000000] Size: 32.0MB P42 (FACTORY) [0x17000000 0x2e00000] Size: 46.0MB P43 (FOTA) [0x19e00000 0xa00000] Size: 10.0MB P44 (RAW_RESOURCES) [0x1a800000 0x400000] Size: 4.0MB P45 (RAW_RESOURCESBAK) [0x1ac00000 0x400000] Size: 4.0MB P46 (SYSTEM) [0x1b000000 0x102c00000] Size: 4.42GB P47 (CUST) [0x11dc00000 0x10000000] Size: 256.0MB P48 (CACHE) [0x12e000000 0x4d000000] Size: 1.203GB P49 (USERDATA) [0x17b000000 0x5cc000000] Size: 23.187GB P50 (GROW) [0x747000000 0xbfbe00] Size: 11.983MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x001B000000 (4.42GB) --------------------------------------------- Detected USERDATA USERDATA : 0x017B000000 (23.187GB) Unable to read gesture.key , code 2 Done. Selected eMMC Interface |
