Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 05-11-2019, 16:37   #1 (permalink)
Member: 157870
Thanks Meter: 24
LG H815 Repair Boot Failed
Hi everybody
I have a hang on logo LG G4 H815.
I flashed it so it become dead.
then flashed it with ROM1 from the support; still dead.
then flashed it with ROM1, ROM2, SD-Card from a link in this forum; still dead.
here is the last LOG, Please HELP:
Z3X EasyJtag Software ver. 3.5.0.1
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 01FFxxxxxxxxxxx, ,FW Ver.: 01.63
CMD Pullup Level:1722 mV
CMD Active Level:1753 mV
Box IO Level:1800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 11010030333247373400C79656B242DC
eMMC CSD : D02700320F5903FFFFFFFFE78640009A
eMMC Manufacturer ID: 0011 , OEM ID: 0100
eMMC Date: 04/2015  Rev.0x0
eMMC NAME: 032G74 , S/N: 3348518578
eMMC NAME (HEX): 303332473734
IC Name: TOSHIBA , eSD_THGBMFG8C4LBAIR/32GB @FBGA153
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 372 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 032G74_3348518578_20190511_1827.extcsd
Partition table scan:
 GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200  bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 61071326
Partition info successfully found
Found Data areas (firmware parts) count is: 51
P0 (MODEM) [0x1000000 0x5600000] Size: 86.0MB
P1 (PMIC) [0x7000000 0x80000] Size: 512.0KB
P2 (SBL1) [0x7080000 0x100000] Size: 1.0MB
P3 (TZ) [0x7180000 0x100000] Size: 1.0MB
P4 (SDI) [0x7280000 0x80000] Size: 512.0KB
P5 (HYP) [0x7300000 0x80000] Size: 512.0KB
P6 (RPM) [0x7380000 0x80000] Size: 512.0KB
P7 (ABOOT) [0x7400000 0x200000] Size: 2.0MB
P8 (SBL1BAK) [0x7600000 0x100000] Size: 1.0MB
P9 (PMICBAK) [0x7700000 0x80000] Size: 512.0KB
P10 (TZBAK) [0x7780000 0x100000] Size: 1.0MB
P11 (HYPBAK) [0x7880000 0x80000] Size: 512.0KB
P12 (RPMBAK) [0x7900000 0x80000] Size: 512.0KB
P13 (ABOOTBAK) [0x7980000 0x200000] Size: 2.0MB
P14 (SDIBAK) [0x7b80000 0x80000] Size: 512.0KB
P15 (LIMITS) [0x7c00000 0x80000] Size: 512.0KB
P16 (DEVINFO) [0x7c80000 0x80000] Size: 512.0KB
P17 (APDP) [0x7d00000 0x80000] Size: 512.0KB
P18 (MSADP) [0x7d80000 0x80000] Size: 512.0KB
P19 (DPO) [0x7e00000 0x80000] Size: 512.0KB
P20 (SPARE1) [0x7e80000 0x180000] Size: 1.500MB
P21 (MISC) [0x8000000 0x1000000] Size: 16.0MB
P22 (PERSIST) [0x9000000 0x2000000] Size: 32.0MB
P23 (MODEMST1) [0xb000000 0x180000] Size: 1.500MB
P24 (MODEMST2) [0xb180000 0x180000] Size: 1.500MB
P25 (FSG) [0xb300000 0x180000] Size: 1.500MB
P26 (FSC) [0xb480000 0x80000] Size: 512.0KB
P27 (SSD) [0xb500000 0x80000] Size: 512.0KB
P28 (KEYSTORE) [0xb580000 0x80000] Size: 512.0KB
P29 (DDR) [0xb600000 0x200000] Size: 2.0MB
P30 (SEC) [0xb800000 0x80000] Size: 512.0KB
P31 (ENCRYPT) [0xb880000 0x80000] Size: 512.0KB
P32 (EKSST) [0xb900000 0x80000] Size: 512.0KB
P33 (RCT) [0xb980000 0x80000] Size: 512.0KB
P34 (PERSISTENT) [0xba00000 0x200000] Size: 2.0MB
P35 (SPARE2) [0xbc00000 0x400000] Size: 4.0MB
P36 (LAF) [0xc000000 0x3000000] Size: 48.0MB
P37 (BOOT) [0xf000000 0x2800000] Size: 40.0MB
P38 (RECOVERY) [0x11800000 0x2800000] Size: 40.0MB
P39 (DRM) [0x14000000 0x800000] Size: 8.0MB
P40 (SNS) [0x14800000 0x800000] Size: 8.0MB
P41 (MPT) [0x15000000 0x2000000] Size: 32.0MB
P42 (FACTORY) [0x17000000 0x2e00000] Size: 46.0MB
P43 (FOTA) [0x19e00000 0xa00000] Size: 10.0MB
P44 (RAW_RESOURCES) [0x1a800000 0x400000] Size: 4.0MB
P45 (RAW_RESOURCESBAK) [0x1ac00000 0x400000] Size: 4.0MB
P46 (SYSTEM) [0x1b000000 0x102c00000] Size: 4.42GB
P47 (CUST) [0x11dc00000 0x10000000] Size: 256.0MB
P48 (CACHE) [0x12e000000 0x4d000000] Size: 1.203GB
P49 (USERDATA) [0x17b000000 0x5cc000000] Size: 23.187GB
P50 (GROW) [0x747000000 0xbfbe00] Size: 11.983MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x001B000000 (4.42GB)
Detected USERDATA USERDATA : 0x017B000000 (23.187GB)
Unable to read gesture.key , code 2
Done.
Selected eMMC Interface
Old 05-11-2019, 20:58   #2 (permalink)
Member: 13148
Thanks Meter: 954
this model need reball CPU for work
The Following User Says Thank You to layder For This Useful Post:
Page generated in 3.66245 seconds with 7 queries
