10-01-2019, 23:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | LG M700TV Q6+ QDLoader via Test Point QC Core Version 2.10 Using Port :COM42 Detecting Device mode... Connecting to device without external programmers... Device Class: sahara Device Protocol: firehose Emergency Mode: true Reading QC Device information... SerialNumber: 0xD400C330 MSM_HW_ID: 0x0006B0E1 OEM_PK_HASH: 0x2CF7619A278D26073F7EEA79BB7F4B7949C221487FEA058E A072CFFE38CE1496 SBL SW Version: 0x00000000 You must select loader to get access to EDL functions Operation status: 0 Sucesso QC Core Version 2.10 Using Port :COM42 Detecting Device mode... Using EDL Programmer :C:\Program Files\Z3X\EASYJTAG\Loaders\prog_emmc_firehose_8937 _lite.mbn Sahara Connectting To Device Sahara Downloading flash programmer: C:\Program Files\Z3X\EASYJTAG\Loaders\prog_emmc_firehose_8937 _lite.mbn Waiting for flash programmer to boot Detecting Device mode... Device Class: sahara Device Protocol: firehose Emergency Mode: true Error call virtual function open_wrapper Warning! Can't open source to read GPT Partition info not found Operation status: -4 COM port read error... |
10-02-2019, 02:00 | #2 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | I am creating a backup of this device. It shows the logo and reboots, does not go into download mode and the customer needs the device data. How can I repair it? Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1822 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484347386134A22986DA722581 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2986DA72 , rev. 0xA2 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1187 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HCG8a4_2986DA72_20191001_194338.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed |
10-02-2019, 13:30 | #3 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | BAD EMMC? Code: Operation: Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Optimal Read Size [266]: 0x40 256 KB Optimal Write Size [265]: 0x40 256 KB Optimal Trim Unit Size [264]: 0x07 28 KB Code: Operation: Random verify eMMC ... If your restore data error occurs - the original data can be found in a folder: \Backups\RandomVerify\HCG8a4_2986DA72_20191002_092619 eMMC switching to ROM1 Address: 000000000000, size: 000000004000 - FAIL Address: 000000004000, size: 000000004000 - FAIL Address: 000000008000, size: 000000004000 - FAIL Address: 00000000C000, size: 000000004000 - FAIL Address: 000000010000, size: 000000004000 - FAIL Address: 000000014000, size: 000000004000 - FAIL Address: 000000018000, size: 000000004000 - FAIL Address: 00000001C000, size: 000000004000 - FAIL Address: 000000020000, size: 000000004000 - FAIL Address: 000000024000, size: 000000004000 - FAIL Address: 000000028000, size: 000000004000 - FAIL Address: 00000002C000, size: 000000004000 - FAIL Address: 000000030000, size: 000000004000 - FAIL Address: 000000034000, size: 000000004000 - FAIL Address: 000000038000, size: 000000004000 - FAIL Address: 00000003C000, size: 000000004000 - FAIL Address: 000000040000, size: 000000004000 - FAIL Address: 000000044000, size: 000000004000 - FAIL Address: 000000048000, size: 000000004000 - FAIL Address: 00000004C000, size: 000000004000 - FAIL Write Speed - Max : 2574,87 KB/s , Min : 2412,36 KB/s , Avg : 2691,43 KB/s , Slow blocks: 0 of 19 (0,00 %) , Verified: 304,00 KB Read Speed - Max : 2490,54 KB/s , Min : 2381,52 KB/s , Avg : 2595,62 KB/s , Slow blocks: 0 of 19 (0,00 %) , Verified: 304,00 KB Exceeded limit for errors Verified 0 MB. Errors - 20 |
10-05-2019, 08:31 | #5 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | 1) backup partititons 2) try this method: http://forum.gsmhosting.com/vbb/f672...ution-2585863/ 3) restore partititons 4) solder eMMC, run phone, backup data |
10-05-2019, 15:11 | #6 (permalink) | |
Member: 1789551 Status: Offline Thanks Meter: 90 | Quote:
I tried but no sucess I did type : "Confirm" , But alway got same error. I need remove EMMC and use socket for this operation ? Code: Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 15AEEBC0126DD0AB, ,FW Ver.: 02.44 CMD Pullup Level:1821 mV CMD Active Level:1877 mV Box IO Level:1800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484347386134A22986DA722581 eMMC CSD : D02701328F5903FFFFFFFFEF8A400027 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 02/2018 Rev.0xA2 eMMC NAME: HCG8a4 , S/N: 696703602 eMMC NAME (HEX): 484347386134 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 1187 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HCG8a4_ 696703602_20191004_2316.extcsd Done. Operation not allowed , confirmation password not match! Last edited by mcdiniz; 10-05-2019 at 15:19. | |
10-05-2019, 15:46 | #7 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | using emmc tool suite 1.6.2.0 Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1820 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484347386134A22986DA722581 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2986DA72 , rev. 0xA2 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1187 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HCG8a4_2986DA72_20191004_235320.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Operation: Changing GP sizes (test mode) ... GP1 size: 0 MB , WR_REL: 1 , ENH 1 GP2 size: 0 MB , WR_REL: 1 , ENH 0 GP3 size: 0 MB , WR_REL: 1 , ENH 0 GP4 size: 0 MB , WR_REL: 1 , ENH 0 Zero sizes. This may damage your eMMC Do you want to continue? HW_PART error. Reason: CMD Timeout Error |
10-07-2019, 02:55 | #9 (permalink) | |
I tried CONFIRM all big letters but got same error. Last edited by layder; 10-07-2019 at 08:03. Reason: merge posts | |
10-07-2019, 13:44 | #11 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Hi I am trying use EasyJtag Tool , But alway got same error "Operation not allowed , confirmation password not match!" I already tried these password below: confirm Confirm CONFIRM |
10-12-2019, 15:49 | #13 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Hi Layder Phone is alive now. more when starting he asked to restore the data. and I need to get the data from the phone (I backed up and went back all the partitions) but still when I turned on the phone to restore the phone. Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 592 mV CMD Active Level: 1867 mV EMMC Device Information : EMMC CID: 90014A484347386134A22986DA722581 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2986DA72 , rev. 0xA2 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1200 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HCG8a4_2986DA72_20191011_102443.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000000800000 - 000006000000], size: 000005800000 (88,0 MB) Partition: aboot, [000006000000 - 000006200000], size: 000000200000 (2,00 MB) Partition: abootbak, [000006200000 - 000006400000], size: 000000200000 (2,00 MB) Partition: tz, [000006400000 - 000006600000], size: 000000200000 (2,00 MB) Partition: tzbak, [000006600000 - 000006800000], size: 000000200000 (2,00 MB) Partition: sbl1, [000006800000 - 000006900000], size: 000000100000 (1,00 MB) Partition: sbl1bak, [000006900000 - 000006A00000], size: 000000100000 (1,00 MB) Partition: rpm, [000006A00000 - 000006A80000], size: 000000080000 (512 KB) Partition: rpmbak, [000006A80000 - 000006B00000], size: 000000080000 (512 KB) Partition: devcfg, [000006B00000 - 000006B80000], size: 000000080000 (512 KB) Partition: devcfgbak, [000006B80000 - 000006C00000], size: 000000080000 (512 KB) Partition: cmnlib, [000006C00000 - 000006C80000], size: 000000080000 (512 KB) Partition: cmnlibbak, [000006C80000 - 000006D00000], size: 000000080000 (512 KB) Partition: cmnlib64, [000006D00000 - 000006D80000], size: 000000080000 (512 KB) Partition: cmnlib64bak, [000006D80000 - 000006E00000], size: 000000080000 (512 KB) Partition: keymaster, [000006E00000 - 000006E80000], size: 000000080000 (512 KB) Partition: keymasterbak, [000006E80000 - 000006F00000], size: 000000080000 (512 KB) Partition: spare1, [000006F00000 - 000006F80000], size: 000000080000 (512 KB) Partition: spare2, [000006F80000 - 000007000000], size: 000000080000 (512 KB) Partition: persistent, [000007000000 - 000007080000], size: 000000080000 (512 KB) Partition: devinfo, [000007080000 - 000007180000], size: 000000100000 (1,00 MB) Partition: spare3, [000007180000 - 000007800000], size: 000000680000 (6,50 MB) Partition: modemst1, [000007800000 - 000007980000], size: 000000180000 (1,50 MB) Partition: modemst2, [000007980000 - 000007B00000], size: 000000180000 (1,50 MB) Partition: mcfg, [000007B00000 - 000007F00000], size: 000000400000 (4,00 MB) Partition: fsc, [000007F00000 - 000007F80000], size: 000000080000 (512 KB) Partition: ssd, [000007F80000 - 000008000000], size: 000000080000 (512 KB) Partition: fsg, [000008000000 - 000008180000], size: 000000180000 (1,50 MB) Partition: spare4, [000008180000 - 000008800000], size: 000000680000 (6,50 MB) Partition: dsp, [000008800000 - 000009800000], size: 000001000000 (16,0 MB) Partition: ftm, [000009800000 - 00000A000000], size: 000000800000 (8,00 MB) Partition: misc, [00000A000000 - 00000A800000], size: 000000800000 (8,00 MB) Partition: drm, [00000A800000 - 00000B000000], size: 000000800000 (8,00 MB) Partition: sns, [00000B000000 - 00000B800000], size: 000000800000 (8,00 MB) Partition: fota, [00000B800000 - 00000C200000], size: 000000A00000 (10,0 MB) Partition: sec, [00000C200000 - 00000C280000], size: 000000080000 (512 KB) Partition: keystore, [00000C280000 - 00000C300000], size: 000000080000 (512 KB) Partition: rct, [00000C300000 - 00000C380000], size: 000000080000 (512 KB) Partition: encrypt, [00000C380000 - 00000C400000], size: 000000080000 (512 KB) Partition: eksst, [00000C400000 - 00000C480000], size: 000000080000 (512 KB) Partition: apdp, [00000C480000 - 00000C500000], size: 000000080000 (512 KB) Partition: msadp, [00000C500000 - 00000C580000], size: 000000080000 (512 KB) Partition: dpo, [00000C580000 - 00000C600000], size: 000000080000 (512 KB) Partition: DDR, [00000C600000 - 00000C680000], size: 000000080000 (512 KB) Partition: spare5, [00000C680000 - 00000C800000], size: 000000180000 (1,50 MB) Partition: boot, [00000C800000 - 00000E800000], size: 000002000000 (32,0 MB) Partition: laf, [00000E800000 - 000010800000], size: 000002000000 (32,0 MB) Partition: lafbak, [000010800000 - 000012800000], size: 000002000000 (32,0 MB) Partition: recovery, [000012800000 - 000014800000], size: 000002000000 (32,0 MB) Partition: recoverybak, [000014800000 - 000016800000], size: 000002000000 (32,0 MB) Partition: factory, [000016800000 - 00001A000000], size: 000003800000 (56,0 MB) Partition: raw_resources, [00001A000000 - 00001A400000], size: 000000400000 (4,00 MB) Partition: raw_resourcesbak, [00001A400000 - 00001A800000], size: 000000400000 (4,00 MB) Partition: persist, [00001A800000 - 00001C800000], size: 000002000000 (32,0 MB) Partition: mpt, [00001C800000 - 00001E800000], size: 000002000000 (32,0 MB) Partition: srtc, [00001E800000 - 00001F000000], size: 000000800000 (8,00 MB) Partition: system, [00001F000000 - 00015F000000], size: 000140000000 (5,00 GB) Partition: cache, [00015F000000 - 00017F000000], size: 000020000000 (512 MB) Partition: OP, [00017F000000 - 000186000000], size: 000007000000 (112 MB) Partition: userdata, [000186000000 - 000E8F7FBC00], size: 000D097FBC00 (52,1 GB) Partition: grow, [000E8F7FBC00 - 000E8F7FBE00], size: 000000000200 (512 B) GPT header successfully parsed Get firmware version Brand = lge Manufacturer = LGE Device = mh Model = LG-M700 Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 7.1.1 Firmware version = NMF26X Firmware date = Thu Jul 11 11:57:18 IST 2019 Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 592 mV CMD Active Level: 1867 mV EMMC Device Information : EMMC CID: 90014A484347386134A22986DA722581 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2986DA72 , rev. 0xA2 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1200 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HCG8a4_2986DA72_20191011_102453.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000E8F7FBE00 GPT-partitioning done Partition name: modem Filename: modem.bin , Offset: 000000800000 , filesize: 92274688 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1950,79 KB/s Partition name: aboot Filename: aboot.bin , Offset: 000006000000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1982,18 KB/s Partition name: abootbak Filename: abootbak.bin , Offset: 000006200000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1953,94 KB/s Partition name: tz Filename: tz.bin , Offset: 000006400000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1969,85 KB/s Partition name: tzbak Filename: tzbak.bin , Offset: 000006600000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1995,36 KB/s Partition name: sbl1 Filename: sbl1.bin , Offset: 000006800000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1986,40 KB/s Partition name: sbl1bak Filename: sbl1bak.bin , Offset: 000006900000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1934,14 KB/s Partition name: rpm Filename: rpm.bin , Offset: 000006A00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1896,61 KB/s Partition name: rpmbak Filename: rpmbak.bin , Offset: 000006A80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1880,44 KB/s Partition name: devcfg Filename: devcfg.bin , Offset: 000006B00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1897,96 KB/s Partition name: devcfgbak Filename: devcfgbak.bin , Offset: 000006B80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1935,29 KB/s Partition name: cmnlib Filename: cmnlib.bin , Offset: 000006C00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1900,24 KB/s Partition name: cmnlibbak Filename: cmnlibbak.bin , Offset: 000006C80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1885,79 KB/s Partition name: cmnlib64 Filename: cmnlib64.bin , Offset: 000006D00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1829,15 KB/s Partition name: cmnlib64bak Filename: cmnlib64bak.bin , Offset: 000006D80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1888,39 KB/s Partition name: keymaster Filename: keymaster.bin , Offset: 000006E00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1923,74 KB/s Partition name: keymasterbak Filename: keymasterbak.bin , Offset: 000006E80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1934,17 KB/s Partition name: spare1 Filename: spare1.bin , Offset: 000006F00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1862,15 KB/s Partition name: spare2 Filename: spare2.bin , Offset: 000006F80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1897,80 KB/s Partition name: persistent Filename: persistent.bin , Offset: 000007000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1873,09 KB/s Partition name: devinfo Filename: devinfo.bin , Offset: 000007080000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1934,50 KB/s Partition name: spare3 Filename: spare3.bin , Offset: 000007180000 , filesize: 6815744 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1987,25 KB/s Partition name: modemst1 Filename: modemst1.bin , Offset: 000007800000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1962,94 KB/s Partition name: modemst2 Filename: modemst2.bin , Offset: 000007980000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1969,79 KB/s Partition name: mcfg Filename: mcfg.bin , Offset: 000007B00000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1947,44 KB/s Partition name: fsc Filename: fsc.bin , Offset: 000007F00000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1903,52 KB/s Partition name: ssd Filename: ssd.bin , Offset: 000007F80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1913,95 KB/s Partition name: fsg Filename: fsg.bin , Offset: 000008000000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1939,90 KB/s Partition name: spare4 Filename: spare4.bin , Offset: 000008180000 , filesize: 6815744 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1978,35 KB/s Partition name: dsp Filename: dsp.bin , Offset: 000008800000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1978,49 KB/s Partition name: ftm Filename: ftm.bin , Offset: 000009800000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1974,71 KB/s Partition name: misc Filename: misc.bin , Offset: 00000A000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1966,09 KB/s Partition name: drm Filename: drm.bin , Offset: 00000A800000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1979,94 KB/s Partition name: sns Filename: sns.bin , Offset: 00000B000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1982,21 KB/s Partition name: fota Filename: fota.bin , Offset: 00000B800000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1973,87 KB/s Partition name: sec Filename: sec.bin , Offset: 00000C200000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1867,06 KB/s Partition name: keystore Filename: keystore.bin , Offset: 00000C280000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1889,75 KB/s Partition name: rct Filename: rct.bin , Offset: 00000C300000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1920,22 KB/s Partition name: encrypt Filename: encrypt.bin , Offset: 00000C380000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1925,05 KB/s Partition name: eksst Filename: eksst.bin , Offset: 00000C400000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1916,81 KB/s Partition name: apdp Filename: apdp.bin , Offset: 00000C480000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1921,70 KB/s Partition name: msadp Filename: msadp.bin , Offset: 00000C500000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1892,86 KB/s Partition name: dpo Filename: dpo.bin , Offset: 00000C580000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1884,98 KB/s Partition name: DDR Filename: DDR.bin , Offset: 00000C600000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1892,19 KB/s Partition name: spare5 Filename: spare5.bin , Offset: 00000C680000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1963,90 KB/s Partition name: boot Filename: boot.bin , Offset: 00000C800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1975,41 KB/s Partition name: laf Filename: laf.bin , Offset: 00000E800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1976,55 KB/s Partition name: lafbak Filename: lafbak.bin , Offset: 000010800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1977,43 KB/s Partition name: recovery Filename: recovery.bin , Offset: 000012800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1971,95 KB/s Partition name: recoverybak Filename: recoverybak.bin , Offset: 000014800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1981,84 KB/s Partition name: factory Filename: factory.bin , Offset: 000016800000 , filesize: 58720256 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1971,73 KB/s Partition name: raw_resources Filename: raw_resources.bin , Offset: 00001A000000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1971,21 KB/s Partition name: raw_resourcesbak Filename: raw_resourcesbak.bin , Offset: 00001A400000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1973,11 KB/s Partition name: persist Filename: persist.bin , Offset: 00001A800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1981,11 KB/s Partition name: mpt Filename: mpt.bin , Offset: 00001C800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1982,88 KB/s Partition name: srtc Filename: srtc.bin , Offset: 00001E800000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1977,93 KB/s Partition name: system Filename: system.bin , Offset: 00001F000000 , filesize: 5368709120 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1981,42 KB/s Partition name: cache Filename: cache.bin , Offset: 00015F000000 , filesize: 536870912 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1980,97 KB/s Partition name: OP Filename: OP.bin , Offset: 00017F000000 , filesize: 117440512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1980,86 KB/s Partition name: userdata Filename: userdata.bin , Offset: 000186000000 , filesize: 55993940992 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1966,35 KB/s Partition name: grow Filename: grow.bin , Offset: 000E8F7FBC00 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 29,04 KB/s Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [09:10:35:231] |
10-15-2019, 22:17 | #14 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | How to restore userdata with Easy jtag? I made a full backup of all partitions and after repairing emmc I returned the full backup. more when turning on the phone appears error that the data is corrupted that it needs to restore the same. Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 587 mV CMD Active Level: 1867 mV EMMC Device Information : EMMC CID: 90014A484347386134A22986DA722581 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2986DA72 , rev. 0xA2 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1258 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HCG8a4_2986DA72_20191015_180858.extcsd EMMC Init completed. Operation: File Explorer... Scan from: HCG8a4 Vendor: Qualcomm Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [modem] successfully PartType: FAT16 Mount [dsp] successfully PartType: LINUX Mount [persist-lg] successfully PartType: LINUX Mount [sns] successfully PartType: LINUX Mount [persist] successfully PartType: LINUX Mount [mpt] successfully PartType: LINUX Mount [srtc] successfully PartType: LINUX Mount [system] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [OP] successfully PartType: LINUX Mount [data] SKIPPED PartType: Full Disk Encryption Get firmware version Brand = lge Manufacturer = LGE Device = mh Model = LG-M700 Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 7.1.1 Firmware version = NMF26X Firmware date = Thu Jul 11 11:57:18 IST 2019 |
