Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-28-2019, 02:29   #1 (permalink)
Member: 861495
Thanks Meter: 42
lg q710al need pinout
lg q710al i flashed with rom q710hs and it died need isp pinout please
Old 11-28-2019, 03:24   #2 (permalink)
Member: 861495
Thanks Meter: 42
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.329)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 4F5D14114E5B04AA
Card Serial = AAD7367B
EasyJTAG Box Firmware = 2.44
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting interface to EasyJtag2/E-Socket
Error: Previous operation is not finished yet.
Setting bus width to 4 Bit
Setting frequence to 42 MHz
EMMC Device Information :
EMMC CID: 150100515836334D4203622DDEF5466D
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: 622DDEF5 , rev. 0x03
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 31 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x50 , Boot from: ROM3 (Boot partition 2)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QX63MB_622DDEF5_20191127_190049.extcsd
EMMC Init completed.
Scanning soft partitions
Partition table not found
Get firmware version
Firmware info not found
Setting bus width to 1 Bit
Setting frequence to 21 MHz
Backup saved: QX63MB_622DDEF5_20191127_190130.extcsd
Setting interface to EasyJtag2/ISP
Backup saved: QX63MB_622DDEF5_20191127_190410.extcsd
Writing eMMC Register ...
Reg: 179 Value: 0x48
Reg: 177 Value: 0x00
Reg: 162 Value: 0x01
Successfully
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Backup saved: QX63MB_622DDEF5_20191127_190418.extcsd
Successfully
Backup saved: QX63MB_622DDEF5_20191127_191003.extcsd
Opening file: Q710HS10a_05_TCL_MX_OP_0309.kdz
Filename: Q710HS10a_05_TCL_MX_OP_0309.kdz
Model: LM-Q710
Software: Q71010w
BuildTime: 0000-00-00 00:00:00
Total Files: 105
preloader_0.bin
Found 11 supported eMMC CID:
name = 'HCG8a4' hex = 0x484347386134 [SKHYNIX]
name = 'HBG4a2' hex = 0x484247346132 [SKHYNIX]
eNAND_H9TQ26ADFTACUR-KUM/32GB @BGA221
name = 'S0J9F8' hex = 0x53304A394638 [MICRON]
name = 'S0J9B7' hex = 0x53304A394237 [MICRON]
name = 'HAG4a2' hex = 0x484147346132 [SKHYNIX]
H9TQ17ABJTACUR/16GB @BGA221
name = 'GX6BMB' hex = 0x475836424D42 [SAMSUNG]
name = 'QX13MB' hex = 0x515831334D42 [SAMSUNG]
name = 'RH64AB' hex = 0x524836344142 [SAMSUNG]
name = 'hB8aP>' hex = 0x68423861503E [SKHYNIX]
name = 'QX63MB' hex = 0x515836334D42 [SAMSUNG]
name = 'FAKEC' hex = 0xFF46414B4543 [Unknown vendor]
Backup saved: QX63MB_622DDEF5_20191127_191114.extcsd
Operation: Write by vendor (LG)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 000747BFBE00
GPT-partitioning done
Model: LM-Q710
Software: Q71010w
Total Files: 105
Unpacking files from the firmware. Please wait ...
Unpack done
Partition name: PRELOADER
Filename: preloader_0.bin , Offset: 000000000000 , filesize: 524288 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 1006.70 KB/s
Partition name: FTM
Filename: ftm_23552.bin , Offset: 000000B80000 , filesize: 8388608 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 5267.76 KB/s
Partition name: LK_A
Filename: lk_a_98304.bin , Offset: 000003000000 , filesize: 1048576 bytes
Done writing partition. Write speed: 8284.38 KB/s
Partition name: LK_B
Filename: lk_b_100352.bin , Offset: 000003100000 , filesize: 1048576 bytes
Done writing partition. Write speed: 8601.16 KB/s
Partition name: LAF_A
Filename: laf_a_102400.bin , Offset: 000003200000 , filesize: 19398656 bytes
Done writing partition. Write speed: 8767.96 KB/s
Partition name: LAF_B
Filename: laf_b_159744.bin , Offset: 000004E00000 , filesize: 19398656 bytes
Done writing partition. Write speed: 8810.60 KB/s
Partition name: BOOT_A
Filename: boot_a_218112.bin , Offset: 000006A80000 , filesize: 17825792 bytes
Done writing partition. Write speed: 8768.88 KB/s
Partition name: BOOT_B
Filename: boot_b_266240.bin , Offset: 000008200000 , filesize: 17825792 bytes
Done writing partition. Write speed: 8791.36 KB/s
Partition name: LOGO_A
Filename: logo_a_314368.bin , Offset: 000009980000 , filesize: 2621440 bytes
Done writing partition. Write speed: 8408.22 KB/s
Partition name: LOGO_B
Filename: logo_b_334848.bin , Offset: 00000A380000 , filesize: 2621440 bytes
Done writing partition. Write speed: 8829.23 KB/s
Partition name: SECRO
Filename: secro_425984.bin , Offset: 00000D000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7897.08 KB/s
Partition name: TEE_A
Filename: tee_a_454656.bin , Offset: 00000DE00000 , filesize: 524288 bytes
Done writing partition. Write speed: 6421.05 KB/s
Partition name: TEE_B
Filename: tee_b_464896.bin , Offset: 00000E300000 , filesize: 524288 bytes
Done writing partition. Write speed: 9054.85 KB/s
Partition name: RCT
Filename: rct_579584.bin , Offset: 000011B00000 , filesize: 524288 bytes
Done writing partition. Write speed: 8425.25 KB/s
Partition name: FACTORY
Filename: factory_581632.bin , Offset: 000011C00000 , filesize: 524288 bytes
Done writing partition. Write speed: 8269.29 KB/s
Partition name: EFUSE
Filename: efuse_696320.bin , Offset: 000015400000 , filesize: 524288 bytes
Done writing partition. Write speed: 9164.75 KB/s
Partition name: MD1IMG_A
Filename: md1img_a_943104.bin , Offset: 00001CC80000 , filesize: 17825792 bytes
Done writing partition. Write speed: 8795.06 KB/s
Partition name: MD1DSP_A
Filename: md1dsp_a_992256.bin , Offset: 00001E480000 , filesize: 1048576 bytes
Done writing partition. Write speed: 8923.85 KB/s
Partition name: MD1ARM7_A
Filename: md1arm7_a_1000448.bin , Offset: 00001E880000 , filesize: 524288 bytes
Done writing partition. Write speed: 8176.73 KB/s
Partition name: MD1IMG_B
Filename: md1img_b_1006592.bin , Offset: 00001EB80000 , filesize: 17825792 bytes
Done writing partition. Write speed: 8867.99 KB/s
Partition name: MD1DSP_B
Filename: md1dsp_b_1055744.bin , Offset: 000020380000 , filesize: 1048576 bytes
Done writing partition. Write speed: 9138.77 KB/s
Partition name: MD1ARM7_B
Filename: md1arm7_b_1063936.bin , Offset: 000020780000 , filesize: 524288 bytes
Done writing partition. Write speed: 9015.24 KB/s
Partition name: ODMDTBO_A
Filename: odmdtbo_a_1294336.bin , Offset: 000027800000 , filesize: 524288 bytes
Done writing partition. Write speed: 6336.52 KB/s
Partition name: VENDOR_A
Filename: vendor_a_1310720.bin , Offset: 000028000000 , filesize: 1048576 bytes
Done writing partition. Write speed: 9209.07 KB/s
Filename: vendor_a_1313792.bin , Offset: 000028180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8757.62 KB/s
Filename: vendor_a_1575936.bin , Offset: 000030180000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8758.52 KB/s
Filename: vendor_a_1838080.bin , Offset: 000038180000 , filesize: 524288 bytes
Done writing partition. Write speed: 6709.88 KB/s
Filename: vendor_a_1870848.bin , Offset: 000039180000 , filesize: 8388608 bytes
Done writing partition. Write speed: 9088.72 KB/s
Filename: vendor_a_2097152.bin , Offset: 000040000000 , filesize: 524288 bytes
Done writing partition. Write speed: 8257.19 KB/s
Filename: vendor_a_2359296.bin , Offset: 000048000000 , filesize: 524288 bytes
Done writing partition. Write speed: 8040.33 KB/s
Filename: vendor_a_2391040.bin , Offset: 000048F80000 , filesize: 8912896 bytes
Done writing partition. Write speed: 8703.99 KB/s
Partition name: SYSTEM_A
Filename: system_a_2408448.bin , Offset: 000049800000 , filesize: 2621440 bytes
Done writing partition. Write speed: 8556.44 KB/s
Filename: system_a_2413568.bin , Offset: 000049A80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8796.37 KB/s
Filename: system_a_2671616.bin , Offset: 000051880000 , filesize: 524288 bytes
Done writing partition. Write speed: 8260.85 KB/s
Filename: system_a_2675712.bin , Offset: 000051A80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8800.16 KB/s
Filename: system_a_2935808.bin , Offset: 000059980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8774.28 KB/s
Filename: system_a_3195904.bin , Offset: 000061880000 , filesize: 524288 bytes
Done writing partition. Write speed: 6028.90 KB/s
Filename: system_a_3200000.bin , Offset: 000061A80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8789.54 KB/s
Filename: system_a_3460096.bin , Offset: 000069980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8733.65 KB/s
Filename: system_a_3720192.bin , Offset: 000071880000 , filesize: 524288 bytes
Done writing partition. Write speed: 6434.75 KB/s
Filename: system_a_3724288.bin , Offset: 000071A80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8787.80 KB/s
Filename: system_a_3984384.bin , Offset: 000079980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8722.59 KB/s
Filename: system_a_4244480.bin , Offset: 000081880000 , filesize: 524288 bytes
Done writing partition. Write speed: 8144.40 KB/s
Filename: system_a_4248576.bin , Offset: 000081A80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8717.64 KB/s
Filename: system_a_4508672.bin , Offset: 000089980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8717.10 KB/s
Filename: system_a_4768768.bin , Offset: 000091880000 , filesize: 524288 bytes
Done writing partition. Write speed: 8013.92 KB/s
Filename: system_a_4772864.bin , Offset: 000091A80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8732.68 KB/s
Filename: system_a_5032960.bin , Offset: 000099980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8671.66 KB/s
Filename: system_a_5295104.bin , Offset: 0000A1980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8718.07 KB/s
Filename: system_a_5557248.bin , Offset: 0000A9980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8698.49 KB/s
Filename: system_a_5819392.bin , Offset: 0000B1980000 , filesize: 524288 bytes
Done writing partition. Write speed: 8104.63 KB/s
Filename: system_a_5950464.bin , Offset: 0000B5980000 , filesize: 66060288 bytes
Done writing partition. Write speed: 8667.00 KB/s
Filename: system_a_6081536.bin , Offset: 0000B9980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8746.26 KB/s
Filename: system_a_6343680.bin , Offset: 0000C1980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8668.88 KB/s
Filename: system_a_6605824.bin , Offset: 0000C9980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8704.29 KB/s
Filename: system_a_6867968.bin , Offset: 0000D1980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8731.93 KB/s
Filename: system_a_7130112.bin , Offset: 0000D9980000 , filesize: 70778880 bytes
Done writing partition. Write speed: 8681.46 KB/s
Filename: system_a_8962048.bin , Offset: 000111800000 , filesize: 524288 bytes
Done writing partition. Write speed: 6205.57 KB/s
Filename: system_a_9486336.bin , Offset: 000121800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7545.60 KB/s
Filename: system_a_9748480.bin , Offset: 000129800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7476.56 KB/s
Filename: system_a_9891840.bin , Offset: 00012DE00000 , filesize: 60817408 bytes
Done writing partition. Write speed: 8660.16 KB/s
Partition name: ODMDTBO_B
Filename: odmdtbo_b_10010624.bin , Offset: 000131800000 , filesize: 524288 bytes
Done writing partition. Write speed: 8066.96 KB/s
Partition name: VENDOR_B
Filename: vendor_b_10027008.bin , Offset: 000132000000 , filesize: 524288 bytes
Done writing partition. Write speed: 8058.31 KB/s
Partition name: SYSTEM_B
Filename: system_b_11124736.bin , Offset: 000153800000 , filesize: 1572864 bytes
Done writing partition. Write speed: 9288.19 KB/s
Filename: system_b_11129856.bin , Offset: 000153A80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8644.22 KB/s
Filename: system_b_11387904.bin , Offset: 00015B880000 , filesize: 524288 bytes
Done writing partition. Write speed: 7696.23 KB/s
Filename: system_b_11392000.bin , Offset: 00015BA80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8684.23 KB/s
Filename: system_b_11652096.bin , Offset: 000163980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8712.67 KB/s
Filename: system_b_11912192.bin , Offset: 00016B880000 , filesize: 524288 bytes
Done writing partition. Write speed: 7929.87 KB/s
Filename: system_b_11916288.bin , Offset: 00016BA80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8672.72 KB/s
Filename: system_b_12176384.bin , Offset: 000173980000 , filesize: 133169152 bytes
Done writing partition. Write speed: 8656.74 KB/s
Filename: system_b_12436480.bin , Offset: 00017B880000 , filesize: 524288 bytes
Done writing partition. Write speed: 7947.51 KB/s
Filename: system_b_12440576.bin , Offset: 00017BA80000 , filesize: 132120576 bytes
Done writing partition. Write speed: 8656.76 KB/s
Filename: system_b_12700672.bin , Offset: 000183980000 , filesize: 9961472 bytes
Done writing partition. Write speed: 8910.18 KB/s
Filename: system_b_12959744.bin , Offset: 00018B800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7912.96 KB/s
Filename: system_b_13484032.bin , Offset: 00019B800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7511.97 KB/s
Filename: system_b_14532608.bin , Offset: 0001BB800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7973.49 KB/s
Filename: system_b_14535680.bin , Offset: 0001BB980000 , filesize: 524288 bytes
Done writing partition. Write speed: 7902.67 KB/s
Filename: system_b_17678336.bin , Offset: 00021B800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7888.03 KB/s
Filename: system_b_18202624.bin , Offset: 00022B800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7978.45 KB/s
Filename: system_b_18464768.bin , Offset: 000233800000 , filesize: 524288 bytes
Done writing partition. Write speed: 7959.57 KB/s
Filename: system_b_18608128.bin , Offset: 000237E00000 , filesize: 60817408 bytes
Done writing partition. Write speed: 8659.06 KB/s
Partition name: OEM_A
Filename: oem_a_18726912.bin , Offset: 00023B800000 , filesize: 4718592 bytes
Done writing partition. Write speed: 8983.47 KB/s
Partition name: OP_S
Filename: 0_op_tcl_mx.img , Offset: 00023C800000 , filesize: 134217728 bytes
Done writing partition. Write speed: 8693.11 KB/s
Filename: 1_op_tcl_mx.img , Offset: 000244800000 , filesize: 134217728 bytes
Done writing partition. Write speed: 8704.31 KB/s
Filename: 2_op_tcl_mx.img , Offset: 00024C800000 , filesize: 134217728 bytes
Done writing partition. Write speed: 8890.47 KB/s
Filename: 3_op_tcl_mx.img , Offset: 000254800000 , filesize: 83886080 bytes
Done writing partition. Write speed: 8760.86 KB/s
Partition name: USERDATA
Filename: userdata_21921792.bin , Offset: 00029D000000 , filesize: 4718592 bytes
Done writing partition. Write speed: 8597.01 KB/s
Filename: userdata_21934080.bin , Offset: 00029D600000 , filesize: 524288 bytes
Done writing partition. Write speed: 7930.02 KB/s
Filename: userdata_22183936.bin , Offset: 0002A5000000 , filesize: 524288 bytes
Done writing partition. Write speed: 8252.42 KB/s
Filename: userdata_22708224.bin , Offset: 0002B5000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7901.55 KB/s
Filename: userdata_23232512.bin , Offset: 0002C5000000 , filesize: 524288 bytes
Done writing partition. Write speed: 8092.97 KB/s
Filename: userdata_23756800.bin , Offset: 0002D5000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7945.14 KB/s
Filename: userdata_24281088.bin , Offset: 0002E5000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7793.09 KB/s
Filename: userdata_28475392.bin , Offset: 000365000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7797.81 KB/s
Filename: userdata_28999680.bin , Offset: 000375000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7768.97 KB/s
Filename: userdata_34766848.bin , Offset: 000425000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7848.09 KB/s
Filename: userdata_40009728.bin , Offset: 0004C5000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7734.16 KB/s
Filename: userdata_40012800.bin , Offset: 0004C5180000 , filesize: 1048576 bytes
Done writing partition. Write speed: 8739.90 KB/s
Filename: userdata_40271872.bin , Offset: 0004CD000000 , filesize: 524288 bytes
Done writing partition. Write speed: 9018.13 KB/s
Filename: userdata_43155456.bin , Offset: 000525000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7779.42 KB/s
Filename: userdata_54689792.bin , Offset: 000685000000 , filesize: 524288 bytes
Done writing partition. Write speed: 7948.02 KB/s
Filename: userdata_58884096.bin , Offset: 000705000000 , filesize: 524288 bytes
Done writing partition. Write speed: 8013.80 KB/s
Operation: Writing BootConfig ...
Reg: 179 Value: 0x50
Done
All done time: [00:10:40:863]
Old 11-28-2019, 03:24   #3 (permalink)
Member: 861495
Thanks Meter: 42
Im wondering if i did everything right will try tommorrow and post results
Old 11-28-2019, 08:36   #4 (permalink)
Member: 13148
Thanks Meter: 1,388
1) Set Mediatek boot config at Presets
2) Set 8 bin 42MHz for E-Socket
The Following User Says Thank You to layder For This Useful Post:
Old 12-02-2019, 19:48   #5 (permalink)
Member: 861495
Thanks Meter: 42
ok will try that when i get back tommorrow
Page generated in 0.96268 seconds with 7 queries
