03-17-2017, 10:35 | #1 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Lumia 520 eMMC dump via JTAG - not dumping full 8GB Log from dumping full 8GB with 32Gb preset. Don't mind the "continue ... bytes" as i had to renew the connection since it breaks every once in a while. Dump itself is a 4 294 967 296 bytes, 4GB. Quote:
04-01-2019, 13:31 | #2 (permalink) |
Junior Member Join Date: Mar 2019 Location: Germany
Member: 2903119 Status: Offline Thanks Meter: 1 | I have the same problem. Want to create a 16GB dump via JTAG. Did you find out why it is or did you find a solution? Or do you always create 4Gb parts and put them together? |
04-01-2019, 13:48 | #3 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
You need save dump to NTFS partition, not FAT32. Temp folder need to be at NTFS partiton also FAT32 have limit for 4GB files, opened for write | |
04-01-2019, 21:58 | #4 (permalink) | |
Member: 25996 Status: Offline Thanks Meter: 253 | Quote:
To be honest i don't remember. I guess i dumped the other part and joined files togeter (this can be done with a hex editor or just "copy /b file_a + file_b"). It's also possible this was fixed at some point. @layder, i would be surprised if anyone would still use FAT32 as a main filesystem. There was a problem in dumping data over 4GB back in 2017 and i was already using NTFS on every drive i had connected so that wasn't an issue. | |
