09-21-2016, 06:33 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Lumia 520 unable to boot repaire done EMMC CSD : D02701320F5903FFF6DBFFEF96406006 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x0 EMMC NAME: M8G2YC , S/N: 1638842405 EMMC NAME (HEX): 4D384732594300 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M8G2YC_1638842405_20160921_1100.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: AE420040-13DD-41F2-AE7F-0DC35854C8D7 Warning: Entries Count = 128 MMCBLK0P0 (DPP) Range: [0X200000,0X9FFE00] ,Len: 800000 MMCBLK0P1 (MODEM_FSG) Range: [0XA00000,0XCFFE00] ,Len: 300000 MMCBLK0P2 (SSD) Range: [0XE00000,0XE03E00] ,Len: 4000 MMCBLK0P3 (SBL1) Range: [0X1000000,0X1176E00] ,Len: 177000 MMCBLK0P4 (SBL2) Range: [0X1200000,0X1376E00] ,Len: 177000 MMCBLK0P5 (SBL3) Range: [0X1400000,0X15FFE00] ,Len: 200000 MMCBLK0P6 (UEFI) Range: [0X1600000,0X1870E00] ,Len: 271000 MMCBLK0P7 (RPM) Range: [0X1A00000,0X1A7CE00] ,Len: 7D000 MMCBLK0P8 (TZ) Range: [0X1C00000,0X1C7CE00] ,Len: 7D000 MMCBLK0P9 (WINSECAPP) Range: [0X1E00000,0X1E7FE00] ,Len: 80000 MMCBLK0P10 (BACKUP_SBL1) Range: [0X2000000,0X2176E00] ,Len: 177000 MMCBLK0P11 (BACKUP_SBL2) Range: [0X2200000,0X2376E00] ,Len: 177000 MMCBLK0P12 (BACKUP_SBL3) Range: [0X2400000,0X25FFE00] ,Len: 200000 MMCBLK0P13 (BACKUP_UEFI) Range: [0X2600000,0X2870E00] ,Len: 271000 MMCBLK0P14 (BACKUP_RPM) Range: [0X2A00000,0X2A7CE00] ,Len: 7D000 MMCBLK0P15 (BACKUP_TZ) Range: [0X2C00000,0X2C7CE00] ,Len: 7D000 MMCBLK0P16 (BACKUP_WINSECAPP) Range: [0X2E00000,0X2E7FE00] ,Len: 80000 MMCBLK0P17 (UEFI_BS_NV) Range: [0X3000000,0X303FE00] ,Len: 40000 MMCBLK0P18 (UEFI_NV) Range: [0X3200000,0X323FE00] ,Len: 40000 MMCBLK0P19 (PLAT) Range: [0X3400000,0X3BFFE00] ,Len: 800000 MMCBLK0P20 (EFIESP) Range: [0X4000000,0X7FFFE00] ,Len: 4000000 MMCBLK0P21 (MODEM_FS1) Range: [0X8000000,0X82FFE00] ,Len: 300000 MMCBLK0P22 (MODEM_FS2) Range: [0X8400000,0X86FFE00] ,Len: 300000 MMCBLK0P23 (UEFI_RT_NV) Range: [0X8800000,0X883FE00] ,Len: 40000 MMCBLK0P24 (UEFI_RT_NV_RPMB) Range: [0X8A00000,0X8A1FE00] ,Len: 20000 MMCBLK0P25 (MMOS) Range: [0X8C00000,0XDBEBE00] ,Len: 4FEC000 MMCBLK0P26 (MAINOS) Range: [0XE000000,0X9752BE00] ,Len: 8952C000 MMCBLK0P27 (DATA) Range: [0X97800000,0X1D1FFBC00] ,Len: 13A7FBE00 Done...Presets has been updated... Done. Running:SAMSUNG: Remove Write Protection...Z3X EasyJtag Software ver. 2.3.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1412 mVCMD Active Level:1608 mV Box IO Level:2800 mV CLK Rate:21000 khz Removing write protection... Done. Z3X EasyJtag Software ver. 2.3.0.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.55CMD Pullup Level:2031 mV CMD Active Level:2330 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004D38473259430061AEC0259096 EMMC CSD : D02701320F5903FFF6DBFFEF96404062 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x0 EMMC NAME: M8G2YC , S/N: 1638842405 EMMC NAME (HEX): 4D384732594300 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M8G2YC_1638842405_20160921_1101.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: AE420040-13DD-41F2-AE7F-0DC35854C8D7 Warning: Entries Count = 128 MMCBLK0P0 (DPP) Range: [0X200000,0X9FFE00] ,Len: 800000 MMCBLK0P1 (MODEM_FSG) Range: [0XA00000,0XCFFE00] ,Len: 300000 MMCBLK0P2 (SSD) Range: [0XE00000,0XE03E00] ,Len: 4000 MMCBLK0P3 (SBL1) Range: [0X1000000,0X1176E00] ,Len: 177000 MMCBLK0P4 (SBL2) Range: [0X1200000,0X1376E00] ,Len: 177000 MMCBLK0P5 (SBL3) Range: [0X1400000,0X15FFE00] ,Len: 200000 MMCBLK0P6 (UEFI) Range: [0X1600000,0X1870E00] ,Len: 271000 MMCBLK0P7 (RPM) Range: [0X1A00000,0X1A7CE00] ,Len: 7D000 MMCBLK0P8 (TZ) Range: [0X1C00000,0X1C7CE00] ,Len: 7D000 MMCBLK0P9 (WINSECAPP) Range: [0X1E00000,0X1E7FE00] ,Len: 80000 MMCBLK0P10 (BACKUP_SBL1) Range: [0X2000000,0X2176E00] ,Len: 177000 MMCBLK0P11 (BACKUP_SBL2) Range: [0X2200000,0X2376E00] ,Len: 177000 MMCBLK0P12 (BACKUP_SBL3) Range: [0X2400000,0X25FFE00] ,Len: 200000 MMCBLK0P13 (BACKUP_UEFI) Range: [0X2600000,0X2870E00] ,Len: 271000 MMCBLK0P14 (BACKUP_RPM) Range: [0X2A00000,0X2A7CE00] ,Len: 7D000 MMCBLK0P15 (BACKUP_TZ) Range: [0X2C00000,0X2C7CE00] ,Len: 7D000 MMCBLK0P16 (BACKUP_WINSECAPP) Range: [0X2E00000,0X2E7FE00] ,Len: 80000 MMCBLK0P17 (UEFI_BS_NV) Range: [0X3000000,0X303FE00] ,Len: 40000 MMCBLK0P18 (UEFI_NV) Range: [0X3200000,0X323FE00] ,Len: 40000 MMCBLK0P19 (PLAT) Range: [0X3400000,0X3BFFE00] ,Len: 800000 MMCBLK0P20 (EFIESP) Range: [0X4000000,0X7FFFE00] ,Len: 4000000 MMCBLK0P21 (MODEM_FS1) Range: [0X8000000,0X82FFE00] ,Len: 300000 MMCBLK0P22 (MODEM_FS2) Range: [0X8400000,0X86FFE00] ,Len: 300000 MMCBLK0P23 (UEFI_RT_NV) Range: [0X8800000,0X883FE00] ,Len: 40000 MMCBLK0P24 (UEFI_RT_NV_RPMB) Range: [0X8A00000,0X8A1FE00] ,Len: 20000 MMCBLK0P25 (MMOS) Range: [0X8C00000,0XDBEBE00] ,Len: 4FEC000 MMCBLK0P26 (MAINOS) Range: [0XE000000,0X9752BE00] ,Len: 8952C000 MMCBLK0P27 (DATA) Range: [0X97800000,0X1D1FFBC00] ,Len: 13A7FBE00 Done...Presets has been updated... Done. |
