04-18-2019, 16:34 | #16 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
I did not write instructions for increasing the RAM all that is written is still on http://www.gsmforum.ru/forums/880-%D...8-EasyJTAGPlus it will be transferred to the wiki | |
The Following 3 Users Say Thank You to layder For This Useful Post: |
05-23-2019, 10:13 | #17 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | LYDER SIR I TRY TO REPIAR SAMSUNG J701F, I CHANGE EMMC SINCE FIRST EMMC IS DAMAGE WHEN I DID ALL PROCESS , I CHECK IT SHOW RPMB AREA EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) SIR THIS IS SAMSUNG EMMC I TRIED TO CHANGE IT BUT IT REMAIN UNCHANGED SIR HOW I REPAIR THIS EMMC IS THIS POSSIBLE TO REPAIR PLZ GUIDE , LOG IS HERE- Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100414A5444345200C86BFE9A7475 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: AJTD4R , HEX: 414A54443452 , S/N: C86BFE9A , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJTD4R_C86BFE9A_20190523_143026.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: bota1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: efs, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: cpefs, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: carrier, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: param, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: boot, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: recovery, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: ota, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: radio, [000008B00000 - 00000E300000], size: 000005800000 (88.0 MB) Partition: tombstones, [00000E300000 - 00000E400000], size: 000000100000 (1.00 MB) Partition: persistent, [00000E400000 - 00000E480000], size: 000000080000 (512. KB) Partition: steady, [00000E480000 - 00000E880000], size: 000000400000 (4.00 MB) Partition: reserved2, [00000E880000 - 00000F000000], size: 000000780000 (7.50 MB) Partition: system, [00000F000000 - 0000CF000000], size: 0000C0000000 (3.00 GB) Partition: cache, [0000CF000000 - 0000DB800000], size: 00000C800000 (200. MB) Partition: hidden, [0000DB800000 - 0000E1C00000], size: 000006400000 (100. MB) Partition: cp_debug, [0000E1C00000 - 0000E2100000], size: 000000500000 (5.00 MB) Partition: nad_fw, [0000E2100000 - 0000E3500000], size: 000001400000 (20.0 MB) Partition: nad_refer, [0000E3500000 - 0000E3600000], size: 000000100000 (1.00 MB) Partition: userdata, [0000E3600000 - 0003AB3FBE00], size: 0002C7DFBE00 (11.1 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j7velte Model = SM-J701F Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 8.1.0 Firmware version = M1AJQ.J701FDDS6BSC2 Firmware date = Tue Mar 12 15:45:08 KST 2019 |
10-18-2019, 13:11 | #20 (permalink) | |
Insane Poster Join Date: Jul 2006
Member: 312449 Status: Offline Thanks Meter: 9 | Quote:
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) 18-10-2019 15:29:27> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) 18-10-2019 15:29:27> 18-10-2019 15:29:27> Looking for EasyJTAG box... 18-10-2019 15:29:27> EasyJTAG API ver. 3307 18-10-2019 15:29:27> OpenUSB returned = 0 18-10-2019 15:29:28> EasyJTAG Box Serial = 0E3BDDA1ADACBEE2 18-10-2019 15:29:29> Card Serial = AAD2B952 18-10-2019 15:29:29> EasyJTAG Box Firmware = 2.44 18-10-2019 15:29:29> 18-10-2019 15:29:45> Looking for EasyJTAG box... 18-10-2019 15:29:45> EasyJTAG API ver. 3307 18-10-2019 15:29:45> Setting IO Levels to 2.8V 18-10-2019 15:29:45> Setting frequence to 42 MHz 18-10-2019 15:29:45> EasyJTAG Box Serial = 0E3BDDA1ADACBEE2 18-10-2019 15:29:45> EasyJTAG Box Firmware = 2.44 18-10-2019 15:29:46> Setting interface to EasyJtag2/E-Socket 18-10-2019 15:29:46> Setting bus width to 8 Bit 18-10-2019 15:29:46> 18-10-2019 15:30:11> Looking for EasyJTAG box... 18-10-2019 15:30:11> EasyJTAG API ver. 3307 18-10-2019 15:30:11> Setting IO Levels to 2.8V 18-10-2019 15:30:11> Setting frequence to 42 MHz 18-10-2019 15:30:11> EasyJTAG Box Serial = 0E3BDDA1ADACBEE2 18-10-2019 15:30:11> EasyJTAG Box Firmware = 2.44 18-10-2019 15:30:12> Setting interface to EasyJtag2/E-Socket 18-10-2019 15:30:12> Setting bus width to 8 Bit 18-10-2019 15:30:12> Setting frequence to 42 MHz 18-10-2019 15:30:12> eMMC Init returned = -1 18-10-2019 15:30:12> Can't init device. Reason: CMD Timeout Error 18-10-2019 15:30:12> 18-10-2019 15:31:28> eMMC Init returned = 0 18-10-2019 15:31:28> EMMC Device Information : 18-10-2019 15:31:28> EMMC CID: 90014A484147346132A54A2626011539 18-10-2019 15:31:28> EMMC CSD: D02701328F5903FFFFFFFFE78A400017 18-10-2019 15:31:28> EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 4A262601 , rev. 0xA5 18-10-2019 15:31:28> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 18-10-2019 15:31:28> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 18-10-2019 15:31:28> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 18-10-2019 15:31:28> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 42916 , Response: Not Clean 18-10-2019 15:31:28> EMMC Permanent Write Protection: No 18-10-2019 15:31:28> EMMC Temporary Write Protection: No 18-10-2019 15:31:28> Extended CSD Information : 18-10-2019 15:31:28> Extended CSD rev: 1.8 (MMC 5.1) 18-10-2019 15:31:28> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 18-10-2019 15:31:28> Boot Bus Config: 0x00 , width 1bit 18-10-2019 15:31:28> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 18-10-2019 15:31:28> Supported partition features [PARTITIONING_SUPPORT]: 0x07 18-10-2019 15:31:28> Device supports partitioning features 18-10-2019 15:31:28> Device can have enhanced technological features in partitions and user data area 18-10-2019 15:31:28> Device can have extended partitions attribute 18-10-2019 15:31:28> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 18-10-2019 15:31:28> Backup saved: HAG4a2_4A262601_20191018_153128.extcsd 18-10-2019 15:31:28> EMMC Init completed. 18-10-2019 15:31:28> 18-10-2019 15:31:28> Get firmware version 18-10-2019 15:31:28> 18-10-2019 15:31:31> Brand = Xiaomi 18-10-2019 15:31:31> Manufacturer = Xiaomi 18-10-2019 15:31:31> Device = riva 18-10-2019 15:31:31> Model = Redmi 5A 18-10-2019 15:31:31> Phone platform = msm8937 18-10-2019 15:31:31> CPU Abi = arm64-v8a 18-10-2019 15:31:31> Android release = 7.1.2 18-10-2019 15:31:31> Firmware version = N2G47H 18-10-2019 15:31:31> Miui Version = V9.5.10.0.NCKMIFA 18-10-2019 15:31:31> Firmware date = Thu May 24 21:25:16 WIB 2018 | |
