10-04-2017, 10:56 | #1 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | LYF LS-5009 eMMC Read Done By Easy Jtag...! HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 1722 mV CMD Active Level: 1794 mV EMMC Device Information : EMMC CID: 70010056313030303850158645CFC23A EMMC CSD: D04F01320F5903FFFFFFFFEF8A400060 EMMC Manufacture Name: KINGSTONE EMMC Manufacture ID: 0x70 , OEM ID: 0100 EMMC Manufacture Date: 12/2015 , Rev: 50 EMMC NAME: V10008 , S/N: 158645CF , rev. 50 EMMC NAME (HEX): 563130303038 EMMC ROM 1 (Main User Data) Capacity: 7216 MB (0001C3000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: V10008_158645CF_20171004_144857.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000008000000], size: 000004000000 Partition: sbl1, [000008000000 - 000008080000], size: 000000080000 Partition: sbl1bak, [000008080000 - 000008100000], size: 000000080000 Partition: aboot, [000008100000 - 000008200000], size: 000000100000 Partition: abootbak, [000008200000 - 000008300000], size: 000000100000 Partition: rpm, [000008300000 - 000008380000], size: 000000080000 Partition: rpmbak, [000008380000 - 000008400000], size: 000000080000 Partition: tz, [000008400000 - 0000084C0000], size: 0000000C0000 Partition: tzbak, [0000084C0000 - 000008580000], size: 0000000C0000 Partition: pad, [000008580000 - 000008680000], size: 000000100000 Partition: modemst1, [000008680000 - 000008800000], size: 000000180000 Partition: modemst2, [000008800000 - 000008980000], size: 000000180000 Partition: misc, [000008980000 - 000008A80000], size: 000000100000 Partition: fsc, [000008A80000 - 000008A80400], size: 000000000400 Partition: ssd, [000008A80400 - 000008A82400], size: 000000002000 Partition: splash, [000008A82400 - 000009482400], size: 000000A00000 Partition: DDR, [00000C000000 - 00000C008000], size: 000000008000 Partition: fsg, [00000C008000 - 00000C188000], size: 000000180000 Partition: sec, [00000C188000 - 00000C18C000], size: 000000004000 Partition: boot, [00000C18C000 - 00000E18C000], size: 000002000000 Partition: system, [00000E18C000 - 00008E18C000], size: 000080000000 Partition: persist, [00008E18C000 - 00009018C000], size: 000002000000 Partition: cache, [00009018C000 - 0000A018C000], size: 000010000000 Partition: recovery, [0000A018C000 - 0000A218C000], size: 000002000000 Partition: devinfo, [0000A218C000 - 0000A228C000], size: 000000100000 Partition: keystore, [0000A4000000 - 0000A4080000], size: 000000080000 Partition: oem, [0000A4080000 - 0000A8080000], size: 000004000000 Partition: config, [0000A8080000 - 0000A8100000], size: 000000080000 Partition: userdata, [0000A8100000 - 0001C2FFBE00], size: 00011AEFBE00 GPT header successfully parsed Get firmware version Brand = LYF Model = LS-5009 Phone platform = msm8909 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LS-5009-S11A_LYF_L11EN_213_160111 Firmware date = Mon Jan 11 11:32:14 CST 2016 Reading from: ROM1 , start: 0x000000000000 , size: 0x000020000000 Output file: C:\Users\BOSS\Desktop\New folder (8)\EMMC_V10008_ROM1_000000000000_000020000000.bin eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1085.80 Kb/s Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\BOSS\Desktop\New folder (8)\EMMC_V10008_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 1421.14 Kb/s Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\BOSS\Desktop\New folder (8)\EMMC_V10008_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 1133.54 Kb/s Here is Screenshot... ...*...THANK YOU...*... |
The Following 4 Users Say Thank You to Pijush Das For This Useful Post: |
10-04-2017, 11:41 | #3 (permalink) | |
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Quote:
Bcoz When u Change eMMC & When USB port not work correctly or USB Track missising Then Only this files help u... Tips by Me : File Reading is very inportant for every Jtag Users Last edited by Pijush Das; 10-04-2017 at 11:46. | |
10-04-2017, 13:23 | #4 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2587820 Status: Offline Sonork: [email protected] Thanks Meter: 2 | plzzz give me link bro |
04-14-2018, 10:27 | #10 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | sir for for general phone if usb not work you need full dump to make it go to menu .... some phone just need scatter some can alive with raw program .... some can have imei some not include imei .... for back up purpose you can back up 128mb- full dump depend on your disk space .... then back up security/imei image fsg modem12 persist etc .... the rest is not important thing |
11-17-2018, 12:47 | #11 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: hyderabad, india
Member: 1623940 Status: Offline Thanks Meter: 22 | Quote:
can u upload pz | |
09-18-2019, 16:32 | #13 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Check This Link For More INFO: http://forum.gsmhosting.com/vbb/f672...cv100-2268050/ Thanks & Regards By:All TECH 4 You |
