04-21-2018, 14:30 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 54
Member: 166398 Status: Offline Thanks Meter: 21 | mediapad s7-721u repair deadboot Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2640 mV Input file : C:\Users\GSM\Downloads\Compressed\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2640 mV Input file : C:\Users\GSM\Downloads\Compressed\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM2_H8G2d_609439 77_00000000_00400000.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 4 sec. Average Write Speed: 864 kB/s Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2640 mV Input file : C:\Users\GSM\Downloads\Compressed\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM3_H8G2d_609439 77_00000000_00400000.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done, time taken: 4 sec. Average Write Speed: 867 kB/s but rom1 always erreur |
04-21-2018, 14:39 | #2 (permalink) |
Member: 166398 Status: Offline Thanks Meter: 21 | Partition table scan: GPT: damaged Partitions list is successefuly loaded! Current partition is not supported... Caution: invalid main GPT header, but valid a backup header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged how to repair this problem and this Caution: The CRC for the backup partition table is invalid. This table may be corrupt. This program will automatically create a new backup partition table when you save your partitions. Problem: The main header's self-pointer doesn't point to itself. This problem is being automatically corrected, but it may be a symptom of more serious problems. Think carefully before saving changes with 'w' or using this disk. Problem: main GPT header's first usable LBA pointer (9) doesn'tmatch the backup GPT header's first usable LBA pointer (22) Problem: main GPT header's last usable LBA pointer (747FF7) doesn'tmatch the backup GPT header's last usable LBA pointer (747FDE) The 'e' option on the experts' menu can probably fix this problem. You should use the 'b' or 'd' option on the recovery & transformation menu to select one or the other header. Final checks complete. Writing a new GPT data... Successfully written a new GPT table to eMMC. The operation has completed successfully. Caution: invalid main GPT header, but valid a backup header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Partitions list is successefuly loaded! Current partition is not supported... |
04-22-2018, 14:11 | #4 (permalink) |
Member: 166398 Status: Offline Thanks Meter: 21 | all clock from 1 to 21 Processing file...C:\Users\GSM\Downloads\Compressed\HUAWEI_ME DIAPAD_7_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin Writing as RAW data Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2124 mV CMD Active Level:3052 mV Input file : C:\Users\GSM\Downloads\Compressed\HUAWEI_MEDIAPAD_ 7_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) |
04-23-2018, 06:01 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Atleast there no need to use eMMC tools to revive S7-721u - can be handled via Qualcomm 9008 , but ... in most cases - 3 from 4 - if normal standard SD update do not rework Software related problems - probably eMMC is dead. So - change it and repeat operation. For sure you can use eMMC from tablet with broken screen or put a brand new inside |
The Following User Says Thank You to debeliamark For This Useful Post: |
