11-12-2019, 08:04 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1042338 Status: Offline Thanks Meter: 8 | good emmc can't be read from easy jtag hi ALL i have a emmc from huawei mate 20 lite and i need read the emmc chip, but the sw see like a dead emmc, after the sw see all the pins green i tried with a different vendor but the answer is the same eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 42062D4361FF9492 Card Serial = AAAA220E EasyJTAG Box Firmware = 2.44 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Canceled Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Canceled Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Canceled Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Canceled |
