MI S2 cant start after success emmc repair Mi S2 blink logo for 1 second power off, success emmc repair but mobile cant power on - 2/8/2020 2:50:25 PM> Looking for EasyJTAG box... 2/8/2020 2:50:25 PM> EasyJTAG API ver. 3307 2/8/2020 2:50:25 PM> Setting IO Levels to 2.8V 2/8/2020 2:50:25 PM> Setting frequence to 21 MHz 2/8/2020 2:50:25 PM> EasyJTAG Box Serial = 83323A0B74DCC77C 2/8/2020 2:50:25 PM> EasyJTAG Box Firmware = 2.50 2/8/2020 2:50:27 PM> Setting interface to EasyJtag2/E-Socket 2/8/2020 2:50:27 PM> Setting bus width to 8 Bit 2/8/2020 2:50:27 PM> Setting frequence to 21 MHz 2/8/2020 2:50:28 PM> eMMC Init returned = 0 2/8/2020 2:50:28 PM> EMMC Device Information : 2/8/2020 2:50:28 PM> EMMC CID: 90014A484347386134A2295315CC552B 2/8/2020 2:50:28 PM> EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 2/8/2020 2:50:28 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 295315CC , rev. 0xA2 2/8/2020 2:50:28 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 5/2018 2/8/2020 2:50:28 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 2/8/2020 2:50:28 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 2/8/2020 2:50:28 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 97029 , Response: Not Clean 2/8/2020 2:50:28 PM> EMMC Permanent Write Protection: No 2/8/2020 2:50:28 PM> EMMC Temporary Write Protection: No 2/8/2020 2:50:28 PM> Extended CSD Information : 2/8/2020 2:50:28 PM> Extended CSD rev: 1.8 (MMC 5.1) 2/8/2020 2:50:28 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 2/8/2020 2:50:28 PM> Boot Bus Config: 0x00 , width 1bit 2/8/2020 2:50:28 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 2/8/2020 2:50:28 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 2/8/2020 2:50:28 PM> Device supports partitioning features 2/8/2020 2:50:28 PM> Device can have enhanced technological features in partitions and user data area 2/8/2020 2:50:28 PM> Device can have extended partitions attribute 2/8/2020 2:50:28 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 2/8/2020 2:50:28 PM> Backup saved: HCG8a4_295315CC_20200208_145028.extcsd 2/8/2020 2:50:28 PM> EMMC Init completed. 2/8/2020 2:50:28 PM> 2/8/2020 2:50:28 PM> Opening file: M:\MIUI\Firmwares\ysl_global_images_V11.0.2.0.PEFM IXM_20191108.0000.00_9.0_global\images\rawprogram0 .xml 2/8/2020 2:50:28 PM> 2/8/2020 2:50:28 PM> The size of the last section has been updated 2/8/2020 2:50:55 PM> 2/8/2020 2:50:55 PM> Looking for EasyJTAG box... 2/8/2020 2:50:55 PM> EasyJTAG API ver. 3307 2/8/2020 2:50:55 PM> Setting IO Levels to 2.8V 2/8/2020 2:50:55 PM> Setting frequence to 21 MHz 2/8/2020 2:50:55 PM> EasyJTAG Box Serial = 83323A0B74DCC77C 2/8/2020 2:50:55 PM> EasyJTAG Box Firmware = 2.50 2/8/2020 2:50:56 PM> Setting interface to EasyJtag2/E-Socket 2/8/2020 2:50:56 PM> Setting bus width to 8 Bit 2/8/2020 2:50:56 PM> Setting frequence to 21 MHz 2/8/2020 2:50:57 PM> eMMC Init returned = 0 2/8/2020 2:50:57 PM> EMMC Device Information : 2/8/2020 2:50:57 PM> EMMC CID: 90014A484347386134A2295315CC552B 2/8/2020 2:50:57 PM> EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 2/8/2020 2:50:57 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 295315CC , rev. 0xA2 2/8/2020 2:50:57 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 5/2018 2/8/2020 2:50:57 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 2/8/2020 2:50:57 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 2/8/2020 2:50:57 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 97029 , Response: Not Clean 2/8/2020 2:50:57 PM> EMMC Permanent Write Protection: No 2/8/2020 2:50:57 PM> EMMC Temporary Write Protection: No 2/8/2020 2:50:57 PM> Extended CSD Information : 2/8/2020 2:50:57 PM> Extended CSD rev: 1.8 (MMC 5.1) 2/8/2020 2:50:57 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 2/8/2020 2:50:57 PM> Boot Bus Config: 0x00 , width 1bit 2/8/2020 2:50:57 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 2/8/2020 2:50:57 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 2/8/2020 2:50:57 PM> Device supports partitioning features 2/8/2020 2:50:57 PM> Device can have enhanced technological features in partitions and user data area 2/8/2020 2:50:57 PM> Device can have extended partitions attribute 2/8/2020 2:50:57 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 2/8/2020 2:50:57 PM> Backup saved: HCG8a4_295315CC_20200208_145057.extcsd 2/8/2020 2:50:57 PM> EMMC Init completed. 2/8/2020 2:50:57 PM> 2/8/2020 2:50:57 PM> Operation: Write by vendor (Qualcomm/HiSilicon/Omap) 2/8/2020 2:50:57 PM> 2/8/2020 2:50:57 PM> Creating GPT-partitioninig 2/8/2020 2:50:57 PM> Writing PrimaryGPT at address: 000000000000 2/8/2020 2:50:57 PM> Writing BackupGPT at address: 000E8F7FBE00 2/8/2020 2:50:57 PM> GPT-partitioning done 2/8/2020 2:50:57 PM> 2/8/2020 2:50:57 PM> Partition name: config 2/8/2020 2:50:57 PM> Filename: config.bin , Offset: 000000028000 , filesize: 32768 bytes 2/8/2020 2:50:57 PM> eMMC switching to ROM1 2/8/2020 2:50:57 PM> Erasing partition... 2/8/2020 2:50:58 PM> Writing partition... 2/8/2020 2:50:58 PM> Done writing partition. Write speed: 2534.51 KB/s 2/8/2020 2:50:58 PM> Partition name: lksecapp 2/8/2020 2:50:58 PM> Filename: lksecapp.mbn , Offset: 000000040000 , filesize: 57352 bytes 2/8/2020 2:50:58 PM> eMMC switching to ROM1 2/8/2020 2:50:58 PM> Erasing partition... 2/8/2020 2:50:59 PM> Writing partition... 2/8/2020 2:50:59 PM> Done writing partition. Write speed: 3269.53 KB/s 2/8/2020 2:50:59 PM> Partition name: lksecappbak 2/8/2020 2:50:59 PM> Filename: lksecapp.mbn , Offset: 000000060000 , filesize: 57352 bytes 2/8/2020 2:50:59 PM> eMMC switching to ROM1 2/8/2020 2:50:59 PM> Erasing partition... 2/8/2020 2:51:00 PM> Writing partition... 2/8/2020 2:51:00 PM> Done writing partition. Write speed: 4719.26 KB/s 2/8/2020 2:51:00 PM> Partition name: devcfg 2/8/2020 2:51:00 PM> Filename: devcfg.mbn , Offset: 000000080000 , filesize: 40052 bytes 2/8/2020 2:51:00 PM> eMMC switching to ROM1 2/8/2020 2:51:00 PM> Erasing partition... 2/8/2020 2:51:00 PM> Writing partition... 2/8/2020 2:51:00 PM> Done writing partition. Write speed: 1396.68 KB/s 2/8/2020 2:51:00 PM> Partition name: devcfgbak 2/8/2020 2:51:01 PM> Filename: devcfg.mbn , Offset: 0000000C0000 , filesize: 40052 bytes 2/8/2020 2:51:01 PM> eMMC switching to ROM1 2/8/2020 2:51:01 PM> Erasing partition... 2/8/2020 2:51:01 PM> Writing partition... 2/8/2020 2:51:01 PM> Done writing partition. Write speed: 3089.14 KB/s 2/8/2020 2:51:01 PM> Partition name: rpm 2/8/2020 2:51:01 PM> Filename: rpm.mbn , Offset: 000000180000 , filesize: 174468 bytes 2/8/2020 2:51:01 PM> eMMC switching to ROM1 2/8/2020 2:51:02 PM> Erasing partition... 2/8/2020 2:51:02 PM> Writing partition... 2/8/2020 2:51:02 PM> Done writing partition. Write speed: 6158.94 KB/s 2/8/2020 2:51:02 PM> Partition name: rpmbak 2/8/2020 2:51:02 PM> Filename: rpm.mbn , Offset: 000000200000 , filesize: 174468 bytes 2/8/2020 2:51:02 PM> eMMC switching to ROM1 2/8/2020 2:51:02 PM> Erasing partition... 2/8/2020 2:51:03 PM> Writing partition... 2/8/2020 2:51:03 PM> Done writing partition. Write speed: 6042.47 KB/s 2/8/2020 2:51:03 PM> Partition name: sbl1 2/8/2020 2:51:03 PM> Filename: sbl1.mbn , Offset: 000000600000 , filesize: 387032 bytes 2/8/2020 2:51:03 PM> eMMC switching to ROM1 2/8/2020 2:51:03 PM> Erasing partition... 2/8/2020 2:51:04 PM> Writing partition... 2/8/2020 2:51:04 PM> Done writing partition. Write speed: 8583.90 KB/s 2/8/2020 2:51:04 PM> Partition name: sbl1bak 2/8/2020 2:51:04 PM> Filename: sbl1.mbn , Offset: 000000700000 , filesize: 387032 bytes 2/8/2020 2:51:04 PM> eMMC switching to ROM1 2/8/2020 2:51:04 PM> Erasing partition... 2/8/2020 2:51:05 PM> Writing partition... 2/8/2020 2:51:05 PM> Done writing partition. Write speed: 13433.62 KB/s 2/8/2020 2:51:05 PM> Partition name: cmnlib 2/8/2020 2:51:05 PM> Filename: cmnlib_30.mbn , Offset: 000000800000 , filesize: 213856 bytes 2/8/2020 2:51:05 PM> eMMC switching to ROM1 2/8/2020 2:51:05 PM> Erasing partition... 2/8/2020 2:51:05 PM> Writing partition... 2/8/2020 2:51:05 PM> Done writing partition. Write speed: 7370.59 KB/s 2/8/2020 2:51:05 PM> Partition name: cmnlibbak 2/8/2020 2:51:05 PM> Filename: cmnlib_30.mbn , Offset: 000000900000 , filesize: 213856 bytes 2/8/2020 2:51:05 PM> eMMC switching to ROM1 2/8/2020 2:51:06 PM> Erasing partition... 2/8/2020 2:51:06 PM> Writing partition... 2/8/2020 2:51:06 PM> Done writing partition. Write speed: 7435.95 KB/s 2/8/2020 2:51:06 PM> Partition name: cmnlib64 2/8/2020 2:51:06 PM> Filename: cmnlib64_30.mbn , Offset: 000000A00000 , filesize: 269088 bytes 2/8/2020 2:51:06 PM> eMMC switching to ROM1 2/8/2020 2:51:06 PM> Erasing partition... 2/8/2020 2:51:07 PM> Writing partition... 2/8/2020 2:51:07 PM> Done writing partition. Write speed: 9382.92 KB/s 2/8/2020 2:51:07 PM> Partition name: cmnlib64bak 2/8/2020 2:51:07 PM> Filename: cmnlib64_30.mbn , Offset: 000000B00000 , filesize: 269088 bytes 2/8/2020 2:51:07 PM> eMMC switching to ROM1 2/8/2020 2:51:07 PM> Erasing partition... 2/8/2020 2:51:08 PM> Writing partition... 2/8/2020 2:51:08 PM> Done writing partition. Write speed: 9445.70 KB/s 2/8/2020 2:51:08 PM> Partition name: keymaster 2/8/2020 2:51:08 PM> Filename: keymaster64.mbn , Offset: 000000C00000 , filesize: 271480 bytes 2/8/2020 2:51:08 PM> eMMC switching to ROM1 2/8/2020 2:51:08 PM> Erasing partition... 2/8/2020 2:51:09 PM> Writing partition... 2/8/2020 2:51:09 PM> Done writing partition. Write speed: 9558.19 KB/s 2/8/2020 2:51:09 PM> Partition name: keymasterbak 2/8/2020 2:51:09 PM> Filename: keymaster64.mbn , Offset: 000000D00000 , filesize: 271480 bytes 2/8/2020 2:51:09 PM> eMMC switching to ROM1 2/8/2020 2:51:09 PM> Erasing partition... 2/8/2020 2:51:09 PM> Writing partition... 2/8/2020 2:51:09 PM> Done writing partition. Write speed: 9426.81 KB/s 2/8/2020 2:51:09 PM> Partition name: aboot 2/8/2020 2:51:09 PM> Filename: emmc_appsboot.mbn , Offset: 000000E00000 , filesize: 720452 bytes 2/8/2020 2:51:09 PM> eMMC switching to ROM1 2/8/2020 2:51:10 PM> Erasing partition... 2/8/2020 2:51:10 PM> Writing partition... 2/8/2020 2:51:10 PM> Done writing partition. Write speed: 11849.45 KB/s 2/8/2020 2:51:10 PM> Partition name: abootbak 2/8/2020 2:51:10 PM> Filename: emmc_appsboot.mbn , Offset: 000001000000 , filesize: 720452 bytes 2/8/2020 2:51:10 PM> eMMC switching to ROM1 2/8/2020 2:51:11 PM> Erasing partition... 2/8/2020 2:51:11 PM> Writing partition... 2/8/2020 2:51:11 PM> Done writing partition. Write speed: 11912.33 KB/s 2/8/2020 2:51:11 PM> Partition name: tz 2/8/2020 2:51:11 PM> Filename: tz.mbn , Offset: 000001400000 , filesize: 1535872 bytes 2/8/2020 2:51:11 PM> eMMC switching to ROM1 2/8/2020 2:51:11 PM> Erasing partition... 2/8/2020 2:51:12 PM> Writing partition... 2/8/2020 2:51:12 PM> Done writing partition. Write speed: 16573.02 KB/s 2/8/2020 2:51:12 PM> Partition name: tzbak 2/8/2020 2:51:12 PM> Filename: tz.mbn , Offset: 000001800000 , filesize: 1535872 bytes 2/8/2020 2:51:12 PM> eMMC switching to ROM1 2/8/2020 2:51:12 PM> Erasing partition... 2/8/2020 2:51:13 PM> Writing partition... 2/8/2020 2:51:13 PM> Done writing partition. Write speed: 16511.43 KB/s 2/8/2020 2:51:13 PM> Partition name: dsp 2/8/2020 2:51:13 PM> Filename: adspso.bin , Offset: 000004000000 , filesize: 16777216 bytes 2/8/2020 2:51:13 PM> eMMC switching to ROM1 2/8/2020 2:51:13 PM> Erasing partition... 2/8/2020 2:51:14 PM> Writing partition... 2/8/2020 2:51:15 PM> Done writing partition. Write speed: 17612.75 KB/s 2/8/2020 2:51:15 PM> Partition name: splash 2/8/2020 2:51:15 PM> Filename: splash.img , Offset: 000006000000 , filesize: 473290 bytes 2/8/2020 2:51:15 PM> eMMC switching to ROM1 2/8/2020 2:51:15 PM> Erasing partition... 2/8/2020 2:51:16 PM> Writing partition... 2/8/2020 2:51:16 PM> Done writing partition. Write speed: 10500.22 KB/s 2/8/2020 2:51:16 PM> Partition name: mdtp 2/8/2020 2:51:16 PM> Filename: mdtp.img , Offset: 000010000000 , filesize: 17808306 bytes 2/8/2020 2:51:16 PM> eMMC switching to ROM1 2/8/2020 2:51:16 PM> Erasing partition... 2/8/2020 2:51:16 PM> Writing partition... 2/8/2020 2:51:17 PM> Done writing partition. Write speed: 17200.12 KB/s 2/8/2020 2:51:17 PM> Partition name: boot 2/8/2020 2:51:17 PM> Filename: boot.img , Offset: 000018000000 , filesize: 27925834 bytes 2/8/2020 2:51:17 PM> eMMC switching to ROM1 2/8/2020 2:51:18 PM> Erasing partition... 2/8/2020 2:51:18 PM> Writing partition... 2/8/2020 2:51:20 PM> Done writing partition. Write speed: 16676.11 KB/s 2/8/2020 2:51:20 PM> Partition name: recovery 2/8/2020 2:51:20 PM> Filename: recovery.img , Offset: 00001C000000 , filesize: 32793934 bytes 2/8/2020 2:51:20 PM> eMMC switching to ROM1 2/8/2020 2:51:20 PM> Erasing partition... 2/8/2020 2:51:21 PM> Writing partition... 2/8/2020 2:51:23 PM> Done writing partition. Write speed: 17420.96 KB/s 2/8/2020 2:51:23 PM> Partition name: modem 2/8/2020 2:51:23 PM> Filename: NON-HLOS.bin , Offset: 000020000000 , filesize: 88080384 bytes 2/8/2020 2:51:23 PM> eMMC switching to ROM1 2/8/2020 2:51:23 PM> Erasing partition... 2/8/2020 2:51:24 PM> Writing partition... 2/8/2020 2:51:29 PM> Done writing partition. Write speed: 17466.26 KB/s 2/8/2020 2:51:29 PM> Partition name: cache 2/8/2020 2:51:29 PM> Filename: cache.img , Offset: 000030000000 , filesize: 131220 bytes 2/8/2020 2:51:29 PM> eMMC switching to ROM1 2/8/2020 2:51:29 PM> Erasing partition... 2/8/2020 2:51:31 PM> Writing partition... 2/8/2020 2:51:31 PM> Sparse image found v.1.0 Total chunks: 10 2/8/2020 2:51:31 PM> Done writing partition. Write speed: 1572.47 KB/s 2/8/2020 2:51:31 PM> Partition name: cust 2/8/2020 2:51:31 PM> Filename: cust.img , Offset: 000050000000 , filesize: 224452780 bytes 2/8/2020 2:51:31 PM> eMMC switching to ROM1 2/8/2020 2:51:31 PM> Erasing partition... 2/8/2020 2:51:34 PM> Writing partition... 2/8/2020 2:51:34 PM> Sparse image found v.1.0 Total chunks: 12 2/8/2020 2:51:46 PM> Done writing partition. Write speed: 17341.79 KB/s 2/8/2020 2:51:46 PM> Partition name: vendor 2/8/2020 2:51:46 PM> Filename: vendor.img , Offset: 000070000000 , filesize: 450248936 bytes 2/8/2020 2:51:46 PM> eMMC switching to ROM1 2/8/2020 2:51:47 PM> Erasing partition... 2/8/2020 2:51:51 PM> Writing partition... 2/8/2020 2:51:51 PM> Sparse image found v.1.0 Total chunks: 17 2/8/2020 2:52:16 PM> Done writing partition. Write speed: 17288.94 KB/s 2/8/2020 2:52:16 PM> Partition name: system 2/8/2020 2:52:16 PM> Filename: system.img , Offset: 0000B0000000 , filesize: 2696479000 bytes 2/8/2020 2:52:16 PM> eMMC switching to ROM1 2/8/2020 2:52:17 PM> Erasing partition... 2/8/2020 2:52:29 PM> Writing partition... 2/8/2020 2:52:29 PM> Sparse image found v.1.0 Total chunks: 21 2/8/2020 2:55:01 PM> Done writing partition. Write speed: 17374.80 KB/s 2/8/2020 2:55:01 PM> Partition name: userdata 2/8/2020 2:55:01 PM> Filename: userdata.img , Offset: 000170000000 , filesize: 111595860 bytes 2/8/2020 2:55:01 PM> eMMC switching to ROM1 2/8/2020 2:55:01 PM> Erasing partition... 2/8/2020 2:58:32 PM> Writing partition... 2/8/2020 2:58:32 PM> Sparse image found v.1.0 Total chunks: 26 2/8/2020 2:58:39 PM> Done writing partition. Write speed: 16946.75 KB/s 2/8/2020 2:58:39 PM> 2/8/2020 2:58:39 PM> All done time: [00:07:41:683] 2/8/2020 2:58:39 PM> Get firmware version Brand = xiaomi Manufacturer = Xiaomi evice = ysl Model = Redmi S2 CPU Abi = armeabi-v7a Android release = 9 Firmware version = PKQ1.181203.001 Miui Version = V11.0.2.0.PEFMIXM irmware date = Fri Nov 8 13:34:15 WIB 2019 solution need. |
Problem solve after change cpu. |
