07-21-2019, 12:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | Micromax a102 without dump flasing done with scatter Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.1) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 16160C0455030F93 Card Serial = AA0FE272 EasyJTAG Box Firmware = 1.63 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3691 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 90014A4834473164040501A1EB2A311C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 01A1EB2A , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_01A1EB2A_20190721_125329.extcsd EMMC Init completed. HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3681 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 90014A4834473164040501A1EB2A311C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 01A1EB2A , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_01A1EB2A_20190721_125339.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3681 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 90014A4834473164040501A1EB2A311C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 01A1EB2A , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_01A1EB2A_20190721_125352.extcsd EMMC Init completed. Operation: Erasing eMMC... Erasing for: ROM1 , start: 0x000000000000 , size: 0x0000E9000000 eMMC switching to ROM1 Erasing partition... Done erasing partition. HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3681 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 90014A4834473164040501A1EB2A311C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 01A1EB2A , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_01A1EB2A_20190721_130135.extcsd EMMC Init completed. Opening file: MT6572_Android_scatter.txt The new format of scatter config_version: V1.1.1 platform: MT6572 preloader_huaqin72_we_iba_jb3.bin Found 2 supported eMMC CID: name = 'H4G1d' hex = 0x483447316404 [SKHYNIX] name = 'MMC04G' hex = 0x4D4D43303447 [KINGSTONE] The size of the last section has been updated HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3681 mV CMD Active Level: 2753 mV EMMC Device Information : EMMC CID: 90014A4834473164040501A1EB2A311C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 01A1EB2A , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_01A1EB2A_20190721_130141.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Partition name: PRELOADER Filename: preloader_huaqin72_we_iba_jb3.bin , Offset: 000000000000 , filesize: 100896 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 318.36 KB/s Partition name: MBR Filename: MBR , Offset: 000000C00000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 66.24 KB/s Partition name: EBR1 Filename: EBR1 , Offset: 000000C80000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 16.01 KB/s Partition name: UBOOT Filename: lk.bin , Offset: 000002920000 , filesize: 261632 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 465.56 KB/s Partition name: BOOTIMG Filename: boot.img , Offset: 000002980000 , filesize: 4739072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 844.42 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000002F80000 , filesize: 5251072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 937.31 KB/s Partition name: SEC_RO Filename: secro.img , Offset: 000003580000 , filesize: 135168 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 850.66 KB/s Partition name: LOGO Filename: logo.bin , Offset: 000003640000 , filesize: 488274 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 922.41 KB/s Partition name: ANDROID Filename: system.img , Offset: 000004340000 , filesize: 823399720 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1473 Done writing partition. Write speed: 925.64 KB/s Partition name: CACHE Filename: cache.img , Offset: 000044340000 , filesize: 12034364 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 24 Done writing partition. Write speed: 920.38 KB/s Partition name: USRDATA Filename: userdata.img , Offset: 000069B40000 , filesize: 28676712 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 49 Done writing partition. Write speed: 959.18 KB/s Writing DL_Info... Writing DL_Info done Partition PROTECT_F : formatting as EXT4. Please wait ... Formatting completed Partition PROTECT_S : formatting as EXT4. Please wait ... Formatting completed Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 All done time: [00:20:53:467] HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3681 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 90014A4834473164040501A1EB2A311C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 01A1EB2A , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_01A1EB2A_20190721_132305.extcsd EMMC Init completed. Scanning soft partitions GPT header is not found MBR header is found. Analyzing data ... EBR detected at address: 000000080000 Partition: mmcblk0p0 [000000900000 - 000001300000], size: 000000A00000 (10.0 MB) Partition: mmcblk0p1 [000001300000 - 000001D00000], size: 000000A00000 (10.0 MB) Partition: mmcblk0p2 [000003740000 - 000043740000], size: 000040000000 (1.00 GB) Partition: mmcblk0p3 [000043740000 - 000068F40000], size: 000025800000 Partition: mmcblk0p4 [000068F40000 - 0000BBB40000], size: 000052C00000 Partition: mmcblk0p5 [0000BBB40000 - 02000007FE00], size: 01FF4453FE00 MBR header successfully parsed Get firmware version GPT header is not found GPT header is not found Brand = Micromax Manufacturer = Micromax Device = MicromaxA102 Model = Micromax A102 CPU Abi = armeabi-v7a Mediatek platform = MT6572 Android release = 4.2.2 Firmware version = ZAW1800A_060A_V8_0_6 Firmware date = Fri Mar 14 16:22:21 CST 2014 |
