Micron MT29F4G08ABADA WP Need help to read this nand flash MT29F4G08ABADA WP. JTAGPlus can not identify chip. Is it supported? If i use custom layout, what settings should i key in? |
it`s onfi nand easyjtag can auto set layout but maybe incorrect. if it cant detect you need check your adapter. |
according to manual it's size 4Gb what page/spare size values should i put in? |
Hello , could you provide detection log? Your sizes is okay ( 0x800 and 0x840 ) This flash IC is ONFI1.0. Autodetect should work normally. What IO voltage you used ? Maybe there is a trick to switch 1.8/2.8. WBR |
post log or screen with detect, please |
Tried both 1.8/2.8 - no difference. Log with default settings If i use custom lyout settings, than detection log looks like this It changes chip ID and resets layout info (num of pages & blocks) |
I have see here number of problems: 1) You does not get correct chip ID. Each time you get another ID. ID it's constant value and doesn't change. So it may indicates to connection problem or NAND chip instability. 2) This model belongs to the model range, whtch supports ONFI standart. So chip layout information containts in NAND chip, but according to previus punct this information can't be recived. 3) To use custom layout you must set corresponding selectbox to treue. Other way custom layout settings will be ignored. 4) Custom layout doesn't allow zero value in the their fields. PS: until you dosen't fix the problem with NAND chip ID, any other actions have no any sense. |
Thank you man for typing so many letters, describing obvious things and providing zero help. |
I'm typing this obvious things because you did mistakes in it. And what help did you expected? Like I said your problem is hardware. So take tester and check your adapter and socket or whatever you use. If it's ok then problem in your chip and it no more usable. Nobody here except you can solve this problem for you. |
I checked adapter and found no problem with it, i soldered the chip back on the pcb and it works just fine as before. If you still 100% sure that current jtag software is suppose to read the IC, than please provide the solution how do i make it do so? |
https://www.upsieutoc.com/images/2019/03/15/onfi.md.png |
Good moning what have software for repair nand corrupt? |
1 Attachment(s) ALL NAND NOT DETECT EASY JTAG NAND SOCKET OR OTHER TOOL DETECTED FINE GIVING THIS ALL NAND Z3X EasyJtag Software ver. 3.7.0.24 Identify NAND Chip. Simple command type Id: 0x808080505046 Vendor: Unknown Full page size: 0x0 Page data size: 0x0 Page spare size: 0x0 Layout: number of CS: 1 number of LUNs per CS: 0 number of Planes per LUN: 0 number of Blocks per Plane: 0 number of Pages per Block: 0 Flash size: 0x0 / 0,000,000,000B / 0B Sending NAND report data... NAND Report sent ... Can't init device, Reason: Wrong layout info, you can try to use custom layout to fix it Done. https://forum.gsmhosting.com/vbb/att...1&d=1649052601 |
Z3X EasyJtag Software ver. 3.7.0.24 Identify NAND Chip. It's PPN NAND Id: 0x000000000000 Extended id: 0x000000000000 Full page size: 0x0 Page data size: 0x0 Page spare size: 0x0 Layout: number of CS: 0 number of LUNs per CS: 0 number of Planes per LUN: 0 number of Blocks per Plane: 0 number of Pages per Block: 0 Flash size: 0x0 / 0,000,000,000B / 0B Can't init device, Reason: PPN wrong parameter page Done. |
Hi! This is wrong id 0x808080505046. It could be because of bad connection, wrong voltage or Clock rate. Try to change those values and check your socket (also you could sold it on soldering plate) If it’s doesn’t help, please send me IC model id |
