10-15-2018, 16:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Please help with the correct ISP adoptor to choose https://www.google.co.in/url?q=https...8j4jqO21I_LDru I used the 6 point adaptor for ISP pinout on N7100, but easy jtag always showing - Can't init device, Reason: CMD Timeout Error, even on the working phone, please suggest which adaptor I should use from the 5 adaptors provided? |
10-16-2018, 07:52 | #3 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
Z3X EasyJtag Software ver. 3.2.0.3 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.30 CMD Pullup Level:899 mV CMD Active Level:2666 mV Box IO Level:3300 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. help | |
10-16-2018, 09:36 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | HIPower mode use with 4 wire connection (CMD/CKL/Dat_0/GND), and external power (USB to PCB) You need to set 1.8 IO levels at software, because IO signal levels at board are 1,8v amplitude. If you set 3.3 IO at box, the box wait 3,3v signal levels |
The Following User Says Thank You to layder For This Useful Post: |
10-16-2018, 16:00 | #5 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Thank you sir for the reply, I tried all things 1.8v, 2.7v and also 3.3 volts and connected all 6 points- (CMD/CKL/Dat_0/GND/1.8v and 2.8v), on adaptor with n7100 working board but still giving the same error, is there anything I am missing, do I need to buy gpg adaptor as every thread shows because that adaptor has USB port also, and in videos I have seen people inserting us cable in adaptor for additional power supply? |
10-16-2018, 16:07 | #6 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Barcelona
Member: 206476 Status: Offline Thanks Meter: 459 | Quote:
10-19-2018, 12:31 | #8 (permalink) | |
10-20-2018, 06:06 | #9 (permalink) | |
10-20-2018, 11:19 | #10 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | |
10-20-2018, 15:03 | #12 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | 1) if you connect 1,8 and 2,8v wires at isp mode, you need deselect "HiPower" checkbox 2) you need set IO voltage as board - select 1,8v (sometime you may set 2,8v but it not recomended, 3.3v also not recomended) 3) if you have not stable connection - reduce Frequency 4) 3 Wires to board (CMD/CLK/Dat_0) must be same lenght 5) "CMD timeout error" - check CLK and CMD connection, "Data RCV error" - Check Dat_0 connection 6) If you use HiPower mode (set checkbox) you need connect only 4 pins - CMD/CLK/Dat_0/GND, and power on PCB (connect USB for Qualcomm/MTK/Spreadtrum, connect USB and battary for Exynos) Code: 19.10.2018 10:58:45> Setting interface to EasyJtag2/ISP_HiPower 19.10.2018 10:58:45> Setting bus width to 1 Bit 19.10.2018 10:58:45> HiPower mode is ON 19.10.2018 10:58:45> Setting frequence to 24 Mhz 19.10.2018 10:58:45> CMD Pullup Level: 1827 mV 19.10.2018 10:58:45> CMD Active Level: 1885 mV 19.10.2018 10:58:45> eMMC Init returned = 0 19.10.2018 10:58:45> EMMC Device Information : 19.10.2018 10:58:45> EMMC CID: 90014A4834473164040303A2962EA1FD 19.10.2018 10:58:45> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 19.10.2018 10:58:45> EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 03A2962E , rev. 0x03 19.10.2018 10:58:45> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2014 19.10.2018 10:58:45> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 19.10.2018 10:58:45> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 19.10.2018 10:58:45> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 19.10.2018 10:58:45> EMMC Permanent Write Protection: No 19.10.2018 10:58:45> EMMC Temporary Write Protection: No 19.10.2018 10:58:45> Extended CSD Information : 19.10.2018 10:58:45> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 19.10.2018 10:58:45> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 19.10.2018 10:58:45> Boot Bus Config: 0x00 , width 1bit 19.10.2018 10:58:45> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 19.10.2018 10:58:45> Supported partition features [PARTITIONING_SUPPORT]: 0x07 19.10.2018 10:58:45> Device supports partitioning features 19.10.2018 10:58:45> Device can have enhanced technological features in partitions and user data area 19.10.2018 10:58:45> Device can have extended partitions attribute 19.10.2018 10:58:45> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 19.10.2018 10:58:45> Backup saved: H4G1d_03A2962E_20181019_105845.extcsd 19.10.2018 10:58:45> EMMC Init completed. Last edited by layder; 10-20-2018 at 15:11. |
10-20-2018, 15:35 | #13 (permalink) | |
10-20-2018, 16:03 | #14 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | I told you at previous message. check you connection. info about compression is system messages you focus on things you do not need |
10-20-2018, 16:29 | #15 (permalink) | |
Sir connections I checked, u can check the pic I attached, it was according to pinout provided in support, I changed each and every settings power volts, hight power on/off and everything but same result everytime and that phone was hand on logo, but dead after flashing and not connecting, I'll again check a different n7100 on Monday which is completely working and let you know, but sir in Samsung tool pro when we connect phone thought uart cable at that time we need to select z3x come port is there any settings like this in easy jtag plus, that we need to select com port? | |
