02-14-2020, 12:33 | #1 (permalink) |
Junior Member Join Date: Feb 2020 Location: Spain
Member: 2947928 Status: Offline Thanks Meter: 0 | Moorc - Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] I'm using Easyjtag+moorc, and the last 4 chips I tried to read (2 bga153 and 2 bga221), easyjtag software shows me the error "Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]". I tried to read them on 2 pc's, with every combination of volts, speed, bits... In every chip, the software shows every pin in green. What could I be doing wrong?? Thank you!! |
02-15-2020, 14:06 | #2 (permalink) |
Member: 2947928 Status: Offline Thanks Meter: 0 | An example: Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1688mV pin connected ok command: 1696mV pin connected ok data0: 1697mV pin connected ok data1: 1695mV pin connected ok data2: 1697mV pin connected ok data3: 1696mV pin connected ok data4: 1691mV pin connected ok data5: 1696mV pin connected ok data6: 1695mV pin connected ok data7: 1697mV pin connected ok Box S/N: E162E6CF59026F53, ,FW Ver.: 02.50 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1684mV pin connected ok command: 1693mV pin connected ok data0: 1695mV pin connected ok data1: 1689mV pin connected ok data2: 1693mV pin connected ok data3: 1691mV pin connected ok data4: 1691mV pin connected ok data5: 1691mV pin connected ok data6: 1690mV pin connected ok data7: 1691mV pin connected ok Box S/N: E162E6CF59026F53, ,FW Ver.: 02.50 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 971mV pin connected ok command: 977mV pin connected ok data0: 980mV pin connected ok data1: 975mV pin connected ok data2: 979mV pin connected ok data3: 979mV pin connected ok data4: 976mV pin connected ok data5: 977mV pin connected ok data6: 977mV pin connected ok data7: 977mV pin connected ok Box S/N: E162E6CF59026F53, ,FW Ver.: 02.50 Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 972mV pin connected ok command: 976mV pin connected ok data0: 977mV pin connected ok data1: 976mV pin connected ok data2: 977mV pin connected ok data3: 975mV pin connected ok data4: 976mV pin connected ok data5: 975mV pin connected ok data6: 976mV pin connected ok data7: 977mV pin connected ok Box S/N: E162E6CF59026F53, ,FW Ver.: 02.50 Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1678mV pin connected ok command: 1688mV pin connected ok data0: 1689mV pin connected ok data1: 1683mV pin connected ok data2: 1688mV pin connected ok data3: 1688mV pin connected ok data4: 1685mV pin connected ok data5: 1685mV pin connected ok data6: 1685mV pin connected ok data7: 1687mV pin connected ok Box S/N: E162E6CF59026F53, ,FW Ver.: 02.50 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:4bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1677mV pin connected ok command: 1688mV pin connected ok data0: 1687mV pin connected ok data1: 1682mV pin connected ok data2: 1685mV pin connected ok data3: 1685mV pin connected ok data4: 1685mV pin connected ok data5: 1685mV pin connected ok data6: 1684mV pin connected ok data7: 1687mV pin connected ok Box S/N: E162E6CF59026F53, ,FW Ver.: 02.50 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Thanks! |
05-19-2022, 09:34 | #5 (permalink) |
Junior Member Join Date: Dec 2007
Member: 644926 Status: Offline Thanks Meter: 2 | Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1116mV pin connected ok command: 1643mV pin connected ok data0: 1589mV pin connected ok data1: 1639mV pin connected ok data2: 1643mV pin connected ok data3: 1636mV pin connected ok data4: 1608mV pin connected ok data5: 1635mV pin connected ok data6: 1638mV pin connected ok data7: 1643mV pin connected ok Box S/N: F1864FE1DDA8E03C, ,FW Ver.: 02.53 Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:8bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
07-05-2022, 17:44 | #6 (permalink) |
Freak Poster Join Date: Aug 2007 Location: JO-JO-JO Age: 40
Member: 576742 Status: Offline Thanks Meter: 20 | EasyJtag Suite Classic ver.: 3.7.0.24 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (compilación 22000), edición de 64 bits. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.22000.653 Z3X Card Serial : AA37-FA06 , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM7 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Dispositivo serie USB (COM7) COM1 ACPI\VEN_PNP&DEV_0501 Puerto de comunicaciones (COM1) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Setting box Pinout ... Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Setting box Pinout ... Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1696mV pin connected ok command: 1707mV pin connected ok data0: 1708mV pin connected ok data1: 1704mV pin connected ok data2: 1706mV pin connected ok data3: 1705mV pin connected ok data4: 1706mV pin connected ok data5: 1705mV pin connected ok data6: 1706mV pin connected ok data7: 1704mV pin connected ok Box S/N: xxxxxxxxxxxxFA7F, ,FW Ver.: 02.53 Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:8bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Setting box Pinout ... Checking security ... Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Setting box Pinout ... Checking security ... Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1697mV pin connected ok command: 1706mV pin connected ok data0: 1707mV pin connected ok data1: 1701mV pin connected ok data2: 1705mV pin connected ok data3: 1706mV pin connected ok data4: 1706mV pin connected ok data5: 1705mV pin connected ok data6: 1704mV pin connected ok data7: 1704mV pin connected ok Box S/N: xxxxxxxxxFA7F, ,FW Ver.: 02.53 Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:8bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. esocket the two |
