Old 07-25-2019, 03:58   #1 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
oppo a1k after format only mediatek usb port
I did wipe data ,but after assembly it connects as Mediatek usb port ! not power on
how to fix it ?
EasyJtag Suite Classic ver.: 3.6.1.4 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AAE1-01DB , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 3 serial devices
COM241 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM241)
COM183 root\rimports RIM Virtual Serial Port v2 (COM183)
COM90 root\rimports RIM Virtual Serial Port v2 (COM90)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.4
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 13130E17E1AD950F, ,FW Ver.: 01.63
CMD Pullup Level:2010 mV
CMD Active Level:2516 mV
Box IO Level:2800 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100514436334D4203980BCEA8266E
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 02/2019 Rev.0x3
eMMC NAME: QD63MB , S/N: 2550910632
eMMC NAME (HEX): 514436334D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 718 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QD63MB_2550910632_20190725_0258.extcsd
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
First usable sector: 34
Last usable sector: 61071326
Partition info successfully found
Found Data areas (firmware parts) count is: 42
P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB
P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB
P2 (PARA) [0x2108000 0x80000] Size: 512.0KB
P3 (OPPORESERVE1) [0x2188000 0x800000] Size: 8.0MB
P4 (OPPORESERVE2) [0x2988000 0x4000000] Size: 64.0MB
P5 (OPPORESERVE3) [0x6988000 0x4000000] Size: 64.0MB
P6 (OPPO_CUSTOM) [0xa988000 0x100000] Size: 1.0MB
P7 (EXPDB) [0xaa88000 0x1400000] Size: 20.0MB
P8 (FRP) [0xbe88000 0x100000] Size: 1.0MB
P9 (VBMETA) [0xbf88000 0x800000] Size: 8.0MB
P10 (NVCFG) [0xc788000 0x2000000] Size: 32.0MB
P11 (NVDATA) [0xe788000 0x4000000] Size: 64.0MB
P12 (METADATA) [0x12788000 0x2000000] Size: 32.0MB
P13 (PROTECT1) [0x14788000 0x800000] Size: 8.0MB
P14 (PROTECT2) [0x14f88000 0x878000] Size: 8.468MB
P15 (SECCFG) [0x15800000 0x800000] Size: 8.0MB
P16 (PERSIST) [0x16000000 0x3000000] Size: 48.0MB
P17 (SEC1) [0x19000000 0x200000] Size: 2.0MB
P18 (PROINFO) [0x19200000 0x300000] Size: 3.0MB
P19 (MD1IMG) [0x19500000 0x6400000] Size: 100.0MB
P20 (SPMFW) [0x1f900000 0x100000] Size: 1.0MB
P21 (SCP1) [0x1fa00000 0x100000] Size: 1.0MB
P22 (SCP2) [0x1fb00000 0x100000] Size: 1.0MB
P23 (SSPM_1) [0x1fc00000 0x100000] Size: 1.0MB
P24 (SSPM_2) [0x1fd00000 0x100000] Size: 1.0MB
P25 (GZ1) [0x1fe00000 0x1000000] Size: 16.0MB
P26 (GZ2) [0x20e00000 0x1000000] Size: 16.0MB
P27 (NVRAM) [0x21e00000 0x4000000] Size: 64.0MB
P28 (LK) [0x25e00000 0x100000] Size: 1.0MB
P29 (LK2) [0x25f00000 0x100000] Size: 1.0MB
P30 (BOOT) [0x26000000 0x2000000] Size: 32.0MB
P31 (LOGO) [0x28000000 0x1000000] Size: 16.0MB
P32 (DTBO) [0x29000000 0x1000000] Size: 16.0MB
P33 (TEE1) [0x2a000000 0x500000] Size: 5.0MB
P34 (TEE2) [0x2a500000 0xb00000] Size: 11.0MB
P35 (ODM) [0x2b000000 0x10000000] Size: 256.0MB
P36 (VENDOR) [0x3b000000 0x39800000] Size: 920.0MB
P37 (SYSTEM) [0x74800000 0x12c000000] Size: 4.687GB
P38 (CACHE) [0x1a0800000 0x1b000000] Size: 432.0MB
P39 (USERDATA) [0x1bb800000 0x5888fbe00] Size: 22.132GB
P40 (OTP) [0x7440fbe00 0x2b00000] Size: 43.0MB
P41 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB)
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x01BB800000 (22.132GB)
Unable to mount USERDATA , code : 95
Done.
Selected eMMC Interface
CMD Pullup Level:2021 mV
CMD Active Level:2578 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
GPT: present
Detected LINUX(Android) CACHE : 0x01A0800000 (432.0MB)
Erasing...
Done.
Detected LINUX(Android) USERDATA : 0x01BB800000 (22.132GB)
Erasing...
Done.
Done.
Old 07-25-2019, 16:47   #2 (permalink)
Member: 1095362
Thanks Meter: 70
how to fix it ?
Bro,
Can u share pinout?
where is gnd??
did u use clk,cmd,d0 only.
Z3X EasyJtag Software ver. 3.6.1.11
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 06009012EE2027F8, ,FW Ver.: 01.63
Warning: CMD Pullup Level (0 mV) too low , check cables etc.!
CMD Active Level:237 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD CRC Error
Done.
CMD Pullup Level:2031 mV
CMD Active Level:2949 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
Old 07-25-2019, 19:11   #3 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
make new thread bro ,pinout is on google
Old 07-26-2019, 01:49   #4 (permalink)
Member: 201359
Sonork: 100.1607870
Thanks Meter: 128
I can repaired if you bring to me the phone
Old 07-27-2019, 07:24   #5 (permalink)
Member: 1934898
oppo a1k edl point where is on bord sir
Old 07-27-2019, 17:15   #6 (permalink)
Member: 1763347
Sonork: md.salam76
oppo cph 1923 a1k format with ufi after only mediatek usb port
Factory Reset...
Creating filesystem... Done.
Writing cache... Wrote 80170784 blocks, expected to write 110592 blocks
Done.
Writing userdata... Unknown chunk type 0x0000 at 0x00E0A0C4
Wrote 50103502 blocks, expected to write 5802235 blocks
Done.
Done.
format after only mediatek usb port how to solve?
Old 07-27-2019, 21:54   #7 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
admin please delete posts out of subject
any suggestion to fix the phone ?
thank you
any help i still didn't fix the phone yet
Old 11-23-2019, 18:13   #8 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
yes we need solution with easyujtag we don't have other tool to do it !
thanks !
Old 11-23-2019, 20:16   #9 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 557
thank you
Can you post after format detection log
Old 11-23-2019, 20:17   #10 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
we hope supporters provide some help for similar issues
Old 11-25-2019, 08:08   #11 (permalink)
Member: 1813906
Sonork: 100.1618216
Thanks Meter: 33
I have done 4 oppo a1k never use format for any oppo. if you have qualcomm device then only Reset OppO if you have Mediatek device use only wipe user data .
The Following User Says Thank You to sharrymz For This Useful Post:
Old 11-26-2019, 14:59   #12 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
thats what i did ,but it ruined the phone's boot configuration
is there a way to fix it using scatter file
Old 11-26-2019, 16:39   #13 (permalink)
Member: 1865744
Thanks Meter: 13
wirte extcsd again will be done
Old 11-28-2019, 18:03   #14 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
I wrote it but still detected as mtk usb port
Old 01-02-2020, 06:45   #15 (permalink)
awanbrother's Avatar
Member: 2505147
Thanks Meter: 183
same here .... only mtk port after formate
The Following User Says Thank You to awanbrother For This Useful Post:
Page generated in 0.22289 seconds with 8 queries
