10-26-2017, 14:01 | #1 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | motorola mb865 help log is here Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 0A0050225B0FD73F, ,FW Ver.: 01.60 CMD Pullup Level:1753 mV CMD Active Level:1918 mV Box IO Level:1800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1101003030384734420015184B341F54 EMMC CSD : D00E00320F5903FFFFFFFFE79640001E EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 01/2012 Rev.0x0 EMMC NAME: 008G4B , S/N: 353913652 EMMC NAME (HEX): 30303847344200 EMMC ROM1 (Main User Data) Capacity: 7584 MB , 0xED0000 pages , 0x1DA000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 256 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 008G4B_ 353913652_20171026_1757.extcsd ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x00] - Standard MMC command set HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x22] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x66] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x50] TRIM Multiplier [TRIM_MULT: 0x04] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x10] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x42] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x08] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x10] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x09] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00ed0000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x64] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x3c] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x1e] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x44] [PWR_CL_52_195: 0x44] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x01] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x02 Write reliability setting register [WR_REL_SET]: 0x00 Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003b4 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: ED0000 sectors 7.4 GiB Soft (Partitioned) Disk/Image size: ECFFBC sectors 7.4 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 8E434CC9-CE98-7A6E-FBD7-C9FDF6AFF723 First usable sector: 34 Last usable sector: 15531998 Found Data areas (firmware parts) count is: 25 Partition info successfully found --------------------------------------------- P0 (PARTITION_P83) [0x20000 0x20000] Size: 128.0KB P1 (PARTITION_P83) [0x80000 0x80000] Size: 512.0KB P2 (PARTITION_P83) [0x100000 0x80000] Size: 512.0KB P3 (PARTITION_P83) [0x200000 0x80000] Size: 512.0KB P4 (PARTITION_P83) [0x280000 0x80000] Size: 512.0KB P5 (PARTITION_P83) [0x300000 0x400000] Size: 4.0MB P6 (PARTITION_P83) [0x700000 0x80000] Size: 512.0KB P7 (PARTITION_P83) [0x780000 0x80000] Size: 512.0KB P8 (PARTITION_P83) [0x800000 0x100000] Size: 1.0MB P9 (PARTITION_P83) [0x900000 0x200000] Size: 2.0MB P10 (PARTITION_P83) [0xb00000 0x80000] Size: 512.0KB P11 (PARTITION_P83) [0xb80000 0x80000] Size: 512.0KB P12 (PARTITION_P83) [0xc00000 0x400000] Size: 4.0MB P13 (PARTITION_P83) [0x1000000 0x800000] Size: 8.0MB P14 (PARTITION_P83) [0x1800000 0x900000] Size: 9.0MB P15 (PARTITION_P83) [0x2100000 0xc00000] Size: 12.0MB P16 (PARTITION_P83) [0x2d00000 0x80000] Size: 512.0KB P17 (PARTITION_P83) [0x2d80000 0x80000] Size: 512.0KB P18 (PARTITION_P83) [0x2e00000 0x400000] Size: 4.0MB P19 (PARTITION_P83) [0x3400000 0x1e000000] Size: 480.0MB P20 (PARTITION_P83) [0x21400000 0x2bc00000] Size: 700.0MB P21 (PARTITION_P83) [0x4d000000 0x11400000] Size: 276.0MB P22 (PARTITION_P83) [0x5e400000 0x53800000] Size: 1.304GB P23 (PARTITION_P83) [0xb1c00000 0x127be0000] Size: 4.620GB P24 (PARTITION_P83) [0x1d97e0000 0x20000] Size: 128.0KB ------ Android information ------ --------------------------------------------- Done. |
10-26-2017, 14:02 | #2 (permalink) |
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | jtag plus log here HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 1815 mV CMD Active Level: 2505 mV EMMC Device Information : EMMC CID: 1101003030384734420015184B341F54 EMMC CSD: D00E00320F5903FFFFFFFFE79640001E EMMC Manufacture Name: TOSHIBA EMMC NAME: 008G4B , S/N: 15184B34 , rev. 00 EMMC NAME (HEX): 303038473442 EMMC ROM 1 (Main User Data) Capacity: 7584 MB (0001DA000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 256 KB (000000040000) Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Backup saved: 008G4B_15184B34_20171026_180157.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: PARTITION_P83, [000000020000 - 000000040000], size: 000000020000 Partition: PARTITION_P83, [000000080000 - 000000100000], size: 000000080000 Partition: PARTITION_P83, [000000100000 - 000000180000], size: 000000080000 Partition: PARTITION_P83, [000000200000 - 000000280000], size: 000000080000 Partition: PARTITION_P83, [000000280000 - 000000300000], size: 000000080000 Partition: PARTITION_P83, [000000300000 - 000000700000], size: 000000400000 Partition: PARTITION_P83, [000000700000 - 000000780000], size: 000000080000 Partition: PARTITION_P83, [000000780000 - 000000800000], size: 000000080000 Partition: PARTITION_P83, [000000800000 - 000000900000], size: 000000100000 Partition: PARTITION_P83, [000000900000 - 000000B00000], size: 000000200000 Partition: PARTITION_P83, [000000B00000 - 000000B80000], size: 000000080000 Partition: PARTITION_P83, [000000B80000 - 000000C00000], size: 000000080000 Partition: PARTITION_P83, [000000C00000 - 000001000000], size: 000000400000 Partition: PARTITION_P83, [000001000000 - 000001800000], size: 000000800000 Partition: PARTITION_P83, [000001800000 - 000002100000], size: 000000900000 Partition: PARTITION_P83, [000002100000 - 000002D00000], size: 000000C00000 Partition: PARTITION_P83, [000002D00000 - 000002D80000], size: 000000080000 Partition: PARTITION_P83, [000002D80000 - 000002E00000], size: 000000080000 Partition: PARTITION_P83, [000002E00000 - 000003200000], size: 000000400000 Partition: PARTITION_P83, [000003400000 - 000021400000], size: 00001E000000 Partition: PARTITION_P83, [000021400000 - 00004D000000], size: 00002BC00000 Partition: PARTITION_P83, [00004D000000 - 00005E400000], size: 000011400000 Partition: PARTITION_P83, [00005E400000 - 0000B1C00000], size: 000053800000 Partition: PARTITION_P83, [0000B1C00000 - 0001D97E0000], size: 000127BE0000 Partition: PARTITION_P83, [0001D97E0000 - 0001D9800000], size: 000000020000 GPT header successfully parsed Get firmware version Firmware info not found |
