06-15-2019, 01:34 | #1 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2772222 Status: Offline Thanks Meter: 9 | Motorola, XT1683 Boot repair Inicial condition: Everything was ok but Radio was Off. I tried many procedures, hardware and software, but not results. Boot Loader was unlock. So I connect device with easyjtag. Check emmc and Health was very bad. So i replace the eMMC IC. I did a dump ROM1 500MB and another dump from CID partition. Use the same model of eMMC. I have two questions: 1) I flashed files from firmware and CID from backup and device still in QDloader, but i read by vendor and flash using xml file and device start in fastboot mode. Why i must read and write using xml file to boot repair? Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 1810 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D42075625A07B6343 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 5625A07B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_5625A07B_20190614_165922.extcsd EMMC Init completed. Writing eMMC Register ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Successfully Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 1812 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D42075625A07B6343 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 5625A07B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_5625A07B_20190614_170011.extcsd EMMC Init completed. Operation: Writing eMMC... Writing to: ROM1 , start: 0x000000000000 , size: 0x000000008000 Input file: E:\MaximoAssisTec\Motorola\Software\Room\Moto G5 plus XT1683\ClanSOFT_POTTER_OPS28.85-17-6-2_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml\gpt_main0.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 754,65 KB/s All done time: [00:00:00:212] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 1813 mV CMD Active Level: 1870 mV EMMC Device Information : EMMC CID: 150100515831334D42075625A07B6343 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 5625A07B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_5625A07B_20190614_170029.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 1811 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D42075625A07B6343 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 5625A07B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_5625A07B_20190614_170225.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Partition name: sbl1 Filename: sbl1.mbn , Offset: 000000020000 , filesize: 519296 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 902,77 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 0000000A0000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1016,54 KB/s Partition name: tz Filename: tz.mbn , Offset: 000000120000 , filesize: 1835008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1615,98 KB/s Partition name: devcfg Filename: devcfg.mbn , Offset: 000000320000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1481,25 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 000000360000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1948,25 KB/s Partition name: cmnlib Filename: cmnlib.mbn , Offset: 0000004E0000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1534,95 KB/s Partition name: cmnlib64 Filename: cmnlib64.mbn , Offset: 000000520000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1523,61 KB/s Partition name: keymaster Filename: keymaster.mbn , Offset: 000000560000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1624,99 KB/s Partition name: prov Filename: prov.mbn , Offset: 0000005A0000 , filesize: 191616 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1406,00 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 0000005E0000 , filesize: 519296 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1661,09 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 000000660000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1967,90 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 0000006E0000 , filesize: 1835008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2035,42 KB/s Partition name: devcfgbak Filename: devcfg.mbn , Offset: 0000008E0000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1897,84 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 000000920000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2047,76 KB/s Partition name: cmnlibbak Filename: cmnlib.mbn , Offset: 000000AA0000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1533,67 KB/s Partition name: cmnlib64bak Filename: cmnlib64.mbn , Offset: 000000AE0000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1664,70 KB/s Partition name: keymasterbak Filename: keymaster.mbn , Offset: 000000B20000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1545,24 KB/s Partition name: provbak Filename: prov.mbn , Offset: 000000B60000 , filesize: 191616 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1343,58 KB/s Partition name: cid Filename: cid.bin , Offset: 00000AD60000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1696,39 KB/s Partition USERDATA is small. Formatting canceled All done time: [00:06:12:476] Read by vendor and Flash XMLfile in Write by vendor Log: Operation: Read by vendor... Destination dir: E:\Program Files\Z3X\DUMP\Motorola\Moto G5 Plus\CID xml\Read by vendor XML\ Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 1811 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D42075625A07B6343 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 5625A07B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_5625A07B_20190614_175904.extcsd EMMC Init completed. Error: Mount [data] failed PartType: LINUX Backup partition: 8xxx_msimage Address: 000000004400, size: 00000001BC00 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1495,80 Kb/s XML-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: sbl1 Address: 000000020000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2110,52 Kb/s Partition name: rpm Address: 0000000A0000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2098,01 Kb/s Partition name: tz Address: 000000120000, size: 0000001C0000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2129,51 Kb/s Partition name: devcfg Address: 000000320000, size: 000000010000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1984,64 Kb/s Partition name: aboot Address: 000000360000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2109,88 Kb/s Partition name: cmnlib Address: 0000004E0000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2114,84 Kb/s Partition name: cmnlib64 Address: 000000520000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2124,79 Kb/s Partition name: keymaster Address: 000000560000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2118,20 Kb/s Partition name: prov Address: 0000005A0000, size: 000000030000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2097,83 Kb/s Partition name: sbl1bak Address: 0000005E0000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2076,62 Kb/s Partition name: rpmbak Address: 000000660000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2117,00 Kb/s Partition name: tzbak Address: 0000006E0000, size: 0000001C0000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2112,33 Kb/s Partition name: devcfgbak Address: 0000008E0000, size: 000000010000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1966,18 Kb/s Partition name: abootbak Address: 000000920000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2108,43 Kb/s Partition name: cmnlibbak Address: 000000AA0000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2101,81 Kb/s Partition name: cmnlib64bak Address: 000000AE0000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2116,78 Kb/s Partition name: keymasterbak Address: 000000B20000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2118,25 Kb/s Partition name: provbak Address: 000000B60000, size: 000000030000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2092,44 Kb/s Partition name: cid Address: 00000AD60000, size: 000000020000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2074,83 Kb/s All done time: [00:00:11:376] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 1811 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D42075625A07B6343 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 5625A07B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_5625A07B_20190614_180044.extcsd EMMC Init completed. Opening file: QX13MB_rawprogram0.xml The size of the last section has been updated Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 1810 mV CMD Active Level: 1867 mV EMMC Device Information : EMMC CID: 150100515831334D42075625A07B6343 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 5625A07B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_5625A07B_20190614_180055.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 GPT-partitioning done Writing image: 8xxx_msimage.bin GPT header is found and is valid Partition name: 8xxx_msimage Filename: 8xxx_msimage , Offset: 000000004400 , filesize: 113664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 721,70 KB/s Writing image done Partition name: sbl1 Filename: sbl1.bin , Offset: 000000020000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1033,75 KB/s Partition name: rpm Filename: rpm.bin , Offset: 0000000A0000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1025,08 KB/s Partition name: tz Filename: tz.bin , Offset: 000000120000 , filesize: 1835008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1660,40 KB/s Partition name: devcfg Filename: devcfg.bin , Offset: 000000320000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1565,28 KB/s Partition name: aboot Filename: aboot.bin , Offset: 000000360000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2061,40 KB/s Partition name: cmnlib Filename: cmnlib.bin , Offset: 0000004E0000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2113,05 KB/s Partition name: cmnlib64 Filename: cmnlib64.bin , Offset: 000000520000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2114,31 KB/s Partition name: keymaster Filename: keymaster.bin , Offset: 000000560000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2091,73 KB/s Partition name: prov Filename: prov.bin , Offset: 0000005A0000 , filesize: 196608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1877,90 KB/s Partition name: sbl1bak Filename: sbl1bak.bin , Offset: 0000005E0000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1983,86 KB/s Partition name: rpmbak Filename: rpmbak.bin , Offset: 000000660000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1934,05 KB/s Partition name: tzbak Filename: tzbak.bin , Offset: 0000006E0000 , filesize: 1835008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2051,59 KB/s Partition name: devcfgbak Filename: devcfgbak.bin , Offset: 0000008E0000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1996,87 KB/s Partition name: abootbak Filename: abootbak.bin , Offset: 000000920000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2039,09 KB/s Partition name: cmnlibbak Filename: cmnlibbak.bin , Offset: 000000AA0000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2093,81 KB/s Partition name: cmnlib64bak Filename: cmnlib64bak.bin , Offset: 000000AE0000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2094,70 KB/s Partition name: keymasterbak Filename: keymasterbak.bin , Offset: 000000B20000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2090,73 KB/s Partition name: provbak Filename: provbak.bin , Offset: 000000B60000 , filesize: 196608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1879,83 KB/s Partition name: cid Filename: cid.bin , Offset: 00000AD60000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1773,01 KB/s Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:00:20:691] Why OEM is lock now and says that firmware (is most recent and i used that same fimware to flash before eMMc be replaced) is downgrade? Code: Log Fastboot: C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: moto-msm8953-C0.92(*) (bootloader) product: potter (bootloader) board: potter (bootloader) secure: yes (bootloader) hwrev: P3B (bootloader) radio: 4 (bootloader) storage-type: emmc (bootloader) emmc: 32GB SAMSUNG QX13MB RV=08 PV=07 FV=0000000000000007 (bootloader) ram: 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F (bootloader) cpu: MSM8953 (bootloader) serialno: 5625a07b (bootloader) cid: 0xDEAD (bootloader) channelid: 0x00 (bootloader) uid: 0000000000000000000000000000 (bootloader) securestate: oem_locked (bootloader) iswarrantyvoid: n/a (bootloader) max-download-size: 534773760 (bootloader) reason: Failed to initialize partition table (bootloader) imei: 000000000000000 (bootloader) meid: (bootloader) date: 01-01-1970 (bootloader) sku: 000000000000000 (bootloader) carrier_sku: (bootloader) battid: (bootloader) iccid: (bootloader) cust_md5: (bootloader) max-sparse-size: 268435456 (bootloader) current-time: (bootloader) ro.build.fingerprint: (bootloader) poweroffalarm: 0 (bootloader) ro.build.version.full: (bootloader) ro.build.version.qcom: (bootloader) version-baseband: (bootloader) kernel.version: (bootloader) sbl1.git: sbl1.git (bootloader) rpm.git: rpm.git (bootloader) tz.git: tz.git (bootloader) devcfg.git: devcfg.git (bootloader) keymaster.git: keymaster.git (bootloader) cmnlib.git: cmnlib.git (bootloader) cmnlib64.git: cmnlib64.git (bootloader) prov.git: prov.git (bootloader) aboot.git: git=MBM-NG-VC0.92-0-g3ea8df0 (bootloader) frp-state: no protection (err) (bootloader) ro.carrier: (bootloader) current-slot: (bootloader) slot-suffixes: _a (bootloader) slot-count: 1 (bootloader) slot-successful:_a: INVALID (bootloader) slot-successful:_b: INVALID (bootloader) slot-bootable:_a: INVALID (bootloader) slot-bootable:_b: INVALID (bootloader) slot-retry-count:_a: unknown (bootloader) slot-retry-count:_b: unknown all: listed above finished. total time: 0.086s Tentativa de Flash: E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot getvar max-sparse-size max-sparse-size: 268435456 finished. total time: -0.000s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot oem fb_mode_set ... FAILED (remote failure) finished. total time: 0.001s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash partition gpt.bin sending 'partition' (45 KB)... OKAY [ 0.002s] writing 'partition'... Validating 'gpt.default.xml' Image primary_gpt failed validation Preflash validation failed Cancelling 'gpt.default.xml' FAILED (remote failure) finished. total time: 0.036s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash bootloader bootloader.im sending 'bootloader' (5115 KB)... OKAY [ 0.114s] writing 'bootloader'... Validating 'bootloader.default.xml' Invalid partition name aboot Invalid partition name rpm Invalid partition name tz Invalid partition name devcfg Invalid partition name cmnlib Invalid partition name cmnlib64 Invalid partition name keymaster Invalid partition name prov Invalid partition name sbl1 Cancelling 'bootloader.default.xml' FAILED (remote failure) finished. total time: 0.194s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash modem NON-HLOS.bin sending 'modem' (71921 KB)... OKAY [ 1.539s] writing 'modem'... Invalid partition name modem FAILED (remote failure) finished. total time: 1.541s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash fsg fsg.mbn sending 'fsg' (3012 KB)... OKAY [ 0.065s] writing 'fsg'... Invalid partition name fsg FAILED (remote failure) finished. total time: 0.067s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot erase modemst1 erasing 'modemst1'... Permission denied FAILED (remote failure) finished. total time: 0.118s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot erase modemst2 erasing 'modemst2'... Permission denied FAILED (remote failure) finished. total time: 0.119s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash dsp adspso.bin sending 'dsp' (16384 KB)... OKAY [ 0.349s] writing 'dsp'... Invalid partition name dsp FAILED (remote failure) finished. total time: 0.355s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash logo logo.bin sending 'logo' (2186 KB)... OKAY [ 0.049s] writing 'logo'... Invalid partition name logo FAILED (remote failure) finished. total time: 0.055s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash boot boot.img sending 'boot' (16384 KB)... OKAY [ 0.374s] writing 'boot'... Invalid partition name boot FAILED (remote failure) finished. total time: 0.380s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash recovery recovery.img sending 'recovery' (20580 KB)... OKAY [ 0.457s] writing 'recovery'... Invalid partition name recovery FAILED (remote failure) finished. total time: 0.463s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot flash oem oem.img sending 'oem' (104608 KB)... OKAY [ 2.240s] writing 'oem'... Invalid partition name oem FAILED (remote failure) finished. total time: 2.246s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot erase cache erasing 'cache'... Permission denied FAILED (remote failure) finished. total time: 0.104s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot erase userdata erasing 'userdata'... Permission denied FAILED (remote failure) finished. total time: 0.103s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot erase DDR erasing 'DDR'... Permission denied FAILED (remote failure) finished. total time: 0.110s E:\MaximoAssisTec\Motorola\Software\MFastboot1>mfastboot oem fb_mode_clear ... FAILED (remote failure) finished. total time: 0.105s |
06-25-2019, 14:45 | #3 (permalink) |
Member: 2772222 Status: Offline Thanks Meter: 9 | When a try Flash by ADB command. I did some test in another Phone (Moto G2, XT1069). Did a Dump 512Mb. Format Memory a Write again. Start in Fastboot Mode and show OEM LOCK, but after flash GPT and restar show correct infomation. https://drive.google.com/open?id=10C...BF-117z4C7Hagh So my Hypothesis is: In first case a Replace eMMC IC, so i think that the device dont accept any firmware because CID of eMMC. Cold be it? Obs: It would re-solder the old memory, but I created GP1 with 8Mb (in old memory) and now does not turn on. It is only in QD Loader. |
06-25-2019, 15:16 | #4 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) No need to create GP1. GP1 is present at some eMMC with Intel CPU | |
The Following User Says Thank You to layder For This Useful Post: |
06-26-2019, 16:33 | #7 (permalink) |
Junior Member Join Date: May 2014
Member: 2194334 Status: Offline Thanks Meter: 8 | Code: (bootloader) cid: 0xDEAD (bootloader) channelid: 0x00 (bootloader) uid: 0000000000000000000000000000 partition, it should not be blank or erased. CID will show up as 0xDEAD if certificate chain/signature in CID partition fails to verify. CID partition has UID of CPU, IMEI, and other device capability flags. If UID does not match CPU, it can fail also. It is also possible you need to flash GPT first before anything else so bootloader can find CID partition and verify. Last edited by oscardagrach; 06-26-2019 at 16:38. |
07-01-2019, 17:37 | #8 (permalink) | |
Member: 2772222 Status: Offline Thanks Meter: 9 | @Layder Quote:
eMMC Tool Log: Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 12 MHz CMD Pullup Level: 1811 mV CMD Active Level: 1866 mV EMMC Device Information : EMMC CID: 150100515831334D42072A84EC5BB3DB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 2A84EC5B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 44 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_2A84EC5B_20190701_112200.extcsd EMMC Init completed. Operation: Erasing eMMC... Erasing for: ROM1 , start: 0x000000000000 , size: 0x000747C00000 eMMC switching to ROM1 Erasing partition... Error erasing at address: 000000050000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0000AED80000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 0000AFEB0000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 000153650000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 00017C640000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 00018E700000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 0001ABF30000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 0001E3660000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 000275240000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 00055CB20000 , error: -100, CARD Status Error ... Retry #1 Error erasing at address: 00055CBC0000 , error: -100, CARD Status Error ... Retry #1 Done erasing partition. Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 12 MHz CMD Pullup Level: 1810 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D42072A84EC5BB3DB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 2A84EC5B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 44 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_2A84EC5B_20190701_114747.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000 Filename: EMMC_QX13MB_ROM1_000000000000_000020000000.bin eMMC switching to ROM1 Writing partition... Error writing at address: 000003FC0000 , error: -1, CMD Timeout Error ... Retry #1 Done writing partition. Write speed: 1020,97 KB/s All done time: [00:08:33:878] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 9 MHz CMD Pullup Level: 1810 mV CMD Active Level: 1870 mV EMMC Device Information : EMMC CID: 150100515831334D42072A84EC5BB3DB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 2A84EC5B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 44 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_2A84EC5B_20190701_122055.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... Error reading at address: 000000068000 , error: -1, CMD Timeout Error ... Retry #1 ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 9 MHz CMD Pullup Level: 1810 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D42072A84EC5BB3DB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 2A84EC5B , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 44 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_2A84EC5B_20190701_122121.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Partition name: cid Filename: cid.bin , Offset: 00000AD60000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 513,24 KB/s All done time: [00:00:05:066] Code: C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: moto-msm8953-C0.92(*) (bootloader) product: potter (bootloader) board: potter (bootloader) secure: yes (bootloader) hwrev: P3B (bootloader) radio: 4 (bootloader) storage-type: emmc (bootloader) emmc: 32GB SAMSUNG QX13MB RV=08 PV=07 FV=0000000000000007 (bootloader) ram: 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F (bootloader) cpu: MSM8953 (bootloader) serialno: 2a84ec5b (bootloader) cid: 0xDEAD (bootloader) channelid: 0x00 (bootloader) uid: 0000000000000000000000000000 (bootloader) securestate: oem_locked (bootloader) iswarrantyvoid: n/a (bootloader) max-download-size: 534773760 (bootloader) reason: Failed to initialize partition table (bootloader) imei: 000000000000000 (bootloader) meid: (bootloader) date: 01-01-1970 (bootloader) sku: 000000000000000 (bootloader) carrier_sku: (bootloader) battid: (bootloader) iccid: (bootloader) cust_md5: (bootloader) max-sparse-size: 268435456 (bootloader) current-time: (bootloader) ro.build.fingerprint: (bootloader) poweroffalarm: 0 (bootloader) ro.build.version.full: (bootloader) ro.build.version.qcom: (bootloader) version-baseband: (bootloader) kernel.version: (bootloader) sbl1.git: sbl1.git (bootloader) rpm.git: rpm.git (bootloader) tz.git: tz.git (bootloader) devcfg.git: devcfg.git (bootloader) keymaster.git: keymaster.git (bootloader) cmnlib.git: cmnlib.git (bootloader) cmnlib64.git: cmnlib64.git (bootloader) prov.git: prov.git (bootloader) aboot.git: git=MBM-NG-VC0.92-0-g3ea8df0 (bootloader) frp-state: no protection (err) (bootloader) ro.carrier: (bootloader) current-slot: (bootloader) slot-suffixes: _a (bootloader) slot-count: 1 (bootloader) slot-successful:_a: INVALID (bootloader) slot-successful:_b: INVALID (bootloader) slot-bootable:_a: INVALID (bootloader) slot-bootable:_b: INVALID (bootloader) slot-retry-count:_a: unknown (bootloader) slot-retry-count:_b: unknown all: listed above finished. total time: 0.089s @oscardagrach Many thanks for explanation about CID partition. After write memory look this log, please. Log Fastboot Try flash GPT first (To find CID partition) Code: C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash partition gpt.bin target reported max download size of 534773760 bytes sending 'partition' (45 KB)... OKAY [ 0.006s] writing 'partition'... (bootloader) Validating 'gpt.default.xml' (bootloader) Image primary_gpt failed validation (bootloader) Preflash validation failed (bootloader) Cancelling 'gpt.default.xml' FAILED (remote failure) finished. total time: 0.050s Code: C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash partition gpt.bin target reported max download size of 534773760 bytes sending 'partition' (45 KB)... OKAY [ 0.006s] writing 'partition'... (bootloader) Validating 'gpt.default.xml' (bootloader) Image primary_gpt failed validation (bootloader) Preflash validation failed (bootloader) Cancelling 'gpt.default.xml' FAILED (remote failure) finished. total time: 0.050s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash partition gpt.bin target reported max download size of 534773760 bytes sending 'partition' (45 KB)... OKAY [ 0.024s] writing 'partition'... (bootloader) Validating 'gpt.default.xml' (bootloader) Image primary_gpt failed validation (bootloader) Preflash validation failed (bootloader) Cancelling 'gpt.default.xml' FAILED (remote failure) finished. total time: 0.122s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash bootloader bootloader.img target reported max download size of 534773760 bytes sending 'bootloader' (5115 KB)... OKAY [ 0.196s] writing 'bootloader'... (bootloader) Validating 'bootloader.default.xml' (bootloader) Invalid partition name aboot (bootloader) Invalid partition name rpm (bootloader) Invalid partition name tz (bootloader) Invalid partition name devcfg (bootloader) Invalid partition name cmnlib (bootloader) Invalid partition name cmnlib64 (bootloader) Invalid partition name keymaster (bootloader) Invalid partition name prov (bootloader) Invalid partition name sbl1 (bootloader) Cancelling 'bootloader.default.xml' FAILED (remote failure) finished. total time: 0.352s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash modem NON-HLOS.bin target reported max download size of 534773760 bytes sending 'modem' (71921 KB)... OKAY [ 1.724s] writing 'modem'... (bootloader) Invalid partition name modem FAILED (remote failure) finished. total time: 1.749s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash fsg fsg.mbn target reported max download size of 534773760 bytes sending 'fsg' (3012 KB)... OKAY [ 0.088s] writing 'fsg'... (bootloader) Invalid partition name fsg FAILED (remote failure) finished. total time: 0.111s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot erase modemst1 erasing 'modemst1'... (bootloader) Permission denied FAILED (remote failure) finished. total time: 0.036s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot erase modemst2 erasing 'modemst2'... (bootloader) Permission denied FAILED (remote failure) finished. total time: 0.035s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash dsp adspso.bin target reported max download size of 534773760 bytes sending 'dsp' (16384 KB)... OKAY [ 0.576s] writing 'dsp'... (bootloader) Invalid partition name dsp FAILED (remote failure) finished. total time: 0.605s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash logo logo.bin target reported max download size of 534773760 bytes sending 'logo' (2186 KB)... OKAY [ 0.077s] writing 'logo'... (bootloader) Invalid partition name logo FAILED (remote failure) finished. total time: 0.105s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash boot boot.img target reported max download size of 534773760 bytes sending 'boot' (16384 KB)... OKAY [ 0.504s] writing 'boot'... (bootloader) Invalid partition name boot FAILED (remote failure) finished. total time: 0.526s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash recovery recovery.img target reported max download size of 534773760 bytes sending 'recovery' (20580 KB)... OKAY [ 0.578s] writing 'recovery'... (bootloader) Invalid partition name recovery FAILED (remote failure) finished. total time: 0.608s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.0 target reported max download size of 534773760 bytes sending 'system' (258396 KB)... OKAY [ 5.908s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 5.929s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.1 target reported max download size of 534773760 bytes sending 'system' (256514 KB)... OKAY [ 5.725s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 5.735s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.2 target reported max download size of 534773760 bytes sending 'system' (246302 KB)... OKAY [ 5.755s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 5.776s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.3 target reported max download size of 534773760 bytes sending 'system' (262141 KB)... OKAY [ 5.922s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 5.944s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.4 target reported max download size of 534773760 bytes sending 'system' (262141 KB)... OKAY [ 6.019s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 6.036s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.5 target reported max download size of 534773760 bytes sending 'system' (262141 KB)... OKAY [ 5.895s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 5.917s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.6 target reported max download size of 534773760 bytes sending 'system' (250531 KB)... OKAY [ 5.676s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 5.696s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.7 target reported max download size of 534773760 bytes sending 'system' (262059 KB)... OKAY [ 6.028s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 6.050s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash system system.img_sparsechunk.8 target reported max download size of 534773760 bytes sending 'system' (254142 KB)... OKAY [ 5.669s] writing 'system'... (bootloader) Invalid partition name system FAILED (remote failure) finished. total time: 5.680s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash oem oem.img target reported max download size of 534773760 bytes sending 'oem' (104608 KB)... OKAY [ 2.414s] writing 'oem'... (bootloader) Invalid partition name oem FAILED (remote failure) finished. total time: 2.439s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot erase cache erasing 'cache'... (bootloader) Permission denied FAILED (remote failure) finished. total time: 0.027s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot erase userdata erasing 'userdata'... (bootloader) Permission denied FAILED (remote failure) finished. total time: 0.036s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot erase DDR erasing 'DDR'... (bootloader) Permission denied FAILED (remote failure) finished. total time: 0.032s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot oem fb_mode_clear ... OKAY [ 0.016s] finished. total time: 0.017s | |
