08-11-2017, 12:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1713460 Status: Offline Thanks Meter: 28 | Motorola XYBOARD mz609 help to repair after eMMC replacement. I have mz609 with broken eMMC in read-only mode [SPOILER]---------- eMMC Device Information ---------- EMMC CID : 02010053454D31364790327A22C56EC8 EMMC CSD : D00F00320F5903FFFFFFFFFF92404010 EMMC Manufacturer ID: 0002 , OEM ID: 0100 EMMC Date: 06/2011 Rev.0x90 EMMC NAME: SEM16G , S/N: 846865093 EMMC NAME (HEX): 53454D31364700 EMMC ROM1 (Main User Data) Capacity: 15188 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SEM16G_ 846865093_20170807_1642.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 7188E9F5-4EB8-723D-1701-7A5379077E75 Warning: Entries Count = 128 MMCBLK0P0 (MBMLOADER) Range: [0X20000,0X3FE00] ,Len: 20000 MMCBLK0P1 (MBM) Range: [0X80000,0XFFE00] ,Len: 80000 MMCBLK0P2 (MBMBACKUP) Range: [0X100000,0X17FE00] ,Len: 80000 MMCBLK0P3 (CDT.BIN) Range: [0X280000,0X29FE00] ,Len: 20000 MMCBLK0P4 (PDS) Range: [0X300000,0X6FFE00] ,Len: 400000 MMCBLK0P5 (UTAGS) Range: [0X700000,0X77FE00] ,Len: 80000 MMCBLK0P6 (LOGO.BIN) Range: [0X800000,0X8FFE00] ,Len: 100000 MMCBLK0P7 (SP) Range: [0X900000,0XAFFE00] ,Len: 200000 MMCBLK0P8 (DEVTREE) Range: [0XB00000,0XB7FE00] ,Len: 80000 MMCBLK0P9 (DEVTREE_BACKUP) Range: [0XB80000,0XBFFE00] ,Len: 80000 MMCBLK0P10 (BOOT) Range: [0XC00000,0X13FFE00] ,Len: 800000 MMCBLK0P11 (RECOVERY) Range: [0X1400000,0X1CFFE00] ,Len: 900000 MMCBLK0P12 (CDROM) Range: [0X1D00000,0XF0FFE00] ,Len: D400000 MMCBLK0P13 (MISC) Range: [0XF100000,0XF17FE00] ,Len: 80000 MMCBLK0P14 (CID) Range: [0XF180000,0XF1FFE00] ,Len: 80000 MMCBLK0P15 (KPANIC) Range: [0XF200000,0XF5FFE00] ,Len: 400000 MMCBLK0P16 (SYSTEM) Range: [0XF600000,0X34DFFE00] ,Len: 25800000 MMCBLK0P17 (CACHE) Range: [0X34E00000,0X70BFFE00] ,Len: 3BE00000 MMCBLK0P18 (PREINSTALL) Range: [0X70C00000,0X9C7FFE00] ,Len: 2BC00000 MMCBLK0P19 (USERDATA) Range: [0X9C800000,0X3B37FFE00] ,Len: 317000000 Done...Presets has been updated... [/SPOILER] I have backed up 512MB of ROM1, 1MB ROM2/ROM3, extCSD. Replaced eMMC to another one from motorola XT912, restored backups. (sorry but I have updated box software at this moment so new log is different) [SPOILER]---------- eMMC Device Information ---------- EMMC CID : 45010053454D3136479023D1188ACEA2 EMMC CSD : D00F00320F5903FFFFFFFFFF92404010 EMMC Manufacturer ID: 0045 , OEM ID: 0100 EMMC Date: 12/2011 Rev.0x90 EMMC NAME: SEM16G , S/N: 600905866 EMMC NAME (HEX): 53454D31364700 EMMC ROM1 (Main User Data) Capacity: 15188 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SEM16G_ 600905866_20170811_1445.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1DAA000 sectors 14.8 GiB Soft (Partitioned) Disk/Image size: 1D9BFDD sectors 14.8 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 7188E9F5-4EB8-723D-1701-7A5379077E75 First usable sector: 34 Last usable sector: 31047679 Found Data areas (firmware parts) count is: 20 Partition info successfully found --------------------------------------------- P0 (MBMLOADER) [0x20000 0x20000] Size: 128.0KB P1 (MBM) [0x80000 0x80000] Size: 512.0KB P2 (MBMBACKUP) [0x100000 0x80000] Size: 512.0KB P3 (CDT.BIN) [0x280000 0x20000] Size: 128.0KB P4 (PDS) [0x300000 0x400000] Size: 4.0MB P5 (UTAGS) [0x700000 0x80000] Size: 512.0KB P6 (LOGO.BIN) [0x800000 0x100000] Size: 1.0MB P7 (SP) [0x900000 0x200000] Size: 2.0MB P8 (DEVTREE) [0xb00000 0x80000] Size: 512.0KB P9 (DEVTREE_BACKUP) [0xb80000 0x80000] Size: 512.0KB P10 (BOOT) [0xc00000 0x800000] Size: 8.0MB P11 (RECOVERY) [0x1400000 0x900000] Size: 9.0MB P12 (CDROM) [0x1d00000 0xd400000] Size: 212.0MB P13 (MISC) [0xf100000 0x80000] Size: 512.0KB P14 (CID) [0xf180000 0x80000] Size: 512.0KB P15 (KPANIC) [0xf200000 0x400000] Size: 4.0MB P16 (SYSTEM) [0xf600000 0x25800000] Size: 600.0MB P17 (CACHE) [0x34e00000 0x3be00000] Size: 958.0MB P18 (PREINSTALL) [0x70c00000 0x2bc00000] Size: 700.0MB P19 (USERDATA) [0x9c800000 0x317000000] Size: 12.359GB[/SPOILER] Tablet booted to fastboot mode. Tried to flash stock ROM bot flasher will hang on "flashing 1/14 mbm-..................". will not flash it and will not stop with error. After disconnect tablet won't boot to fastboot more Everything excepRPMB partition is the same. Cant understand what's wrong. How to restore tablet with new eMMC? Last edited by nick_fc; 08-11-2017 at 13:04. |
