05-28-2014, 15:55 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: spain Age: 35
Member: 65061 Status: Offline Thanks Meter: 30 | i8730 support PLEASE Thanks Best Regards Warning , you are using custom pinout config make shure that NRST and GND on proper places! EasyJtag Suite ver.: 1.5.1.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7600). For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. - The best eMMC and JTAG service solution. Total repair and forensics tool for Android devices! Check security...OK Initialising: SAMSUNG GT-I9505 Config ver.:1.01 I/O Level set to : 2200 mV Box S/N: 10100416241CBA99 ,FW Ver.: 01.50 Connecting to Target... Halting CPU... Initialize hardware... Starting target communication... KNOX WARRANTY VOID: 0 Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00450000 Reading dump to file...C:\Users\Jose\Desktop\SAMSUNG_GT-I9505_0x00000000_0x00200000.bin Reading 0x000000200000 bytes from emmc adress 0x000000000000 Dumped 2097152 bytes in 9.065518s (225.911 KiB/s) OK. |
05-28-2014, 15:56 | #2 (permalink) |
Member: 65061 Status: Offline Thanks Meter: 30 | Now as I9190 gets CPU Code: For support and updates visit http://easy-jtag.com Check security...OK Initialising: SAMSUNG GT-I9195 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 10100416241CBA99 ,FW Ver.: 01.50 Connecting to Target... JTAG device: MSM8930AB. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8930AB. CPU IDCODE : 0x207230E1 Mfg.: 0x070, Part: 0x0723, Ver.: 0x2 CPU Manufacturer: QUALCOMM , CPU Name: Unknown Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00450000 |
10-17-2015, 14:38 | #4 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | GT-i8730 eMMC connection Here you can find a eMMC connection in case of needs: For full dump - write me a message, please. WBR, DebeliaMark, BG |
The Following User Says Thank You to debeliamark For This Useful Post: |
10-17-2015, 15:03 | #5 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | P.S. What mean Code: Z3X EasyJtag Software ver. 2.0.5.0 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 0C0C0313F73xxxx8, ,FW Ver.: 01.52 CMD Pullup Level:2640 mV CMD Active Level:2351 mV eMMC Device Information EMMC CID : 02000053444D30333290FFFFFFFF29BC EMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AA EMMC Manufacturer ID: 0002 , OEM ID: 0000 EMMC Date: 02/2006 Rev.0x90 EMMC NAME: SDM032 , S/N: 4294967295 EMMC NAME (HEX): 53444D30333200 EMMC ROM1 (Main User Data) Capacity: 30 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: SDM032_4294967295_20150906_1701.extcsd Done. A third time i face this in SanDisk eMMC IC-s. |
