06-09-2018, 11:20 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | MY Jtag not detect any phone how can fixed this problem ?? my box is EASY-JTAG Compression is ON Z3X EasyJtag Software ver. 2.9.0.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0CFF7009FE251F7E, ,FW Ver.: 01.62 CMD Pullup Level:371 mV CMD Active Level:1660 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
06-10-2018, 08:34 | #2 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: bangladesh
Member: 926902 Status: Offline Sonork: 100.1655575 Thanks Meter: 517 | Quote:
06-10-2018, 08:40 | #3 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | CMD Timeout Error appeared when isp connection not good. one more important thing that voltage should be 3.3v and frequency select 36mhz. if you select same as i wrote and still getting error that mean isp connection not good. Thanks. |
06-14-2018, 21:39 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
Did you have ISP adapter? if yes then what adapter you using? | |
06-23-2018, 09:03 | #5 (permalink) | |
Junior Member Join Date: May 2008
Member: 776170 Status: Offline Thanks Meter: 6 | Quote:
Try with working phone.. post the reply Sent from my iPhone using Tapatalk | |
