03-05-2018, 14:28 | #16 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | |
The Following User Says Thank You to NoName® For This Useful Post: |
05-24-2018, 19:51 | #20 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | Me too am facing same problem i bought new jtag plus some time box detect but many times say box not found I changed pc but nothing ... Sent from my SM-A520F using Tapatalk |
05-30-2019, 16:16 | #23 (permalink) | |
Registered User Join Date: Aug 2004 Location: India Age: 46
Member: 77443 Status: Offline Thanks Meter: 24 | mr blang pls give solution here is details Code: EasyJTAG SPI Flasher v 1.1.0.0 Action: Registering device insert notification... Info: Success register device notification Action: Initialize programmer Info: Starting programmer with device on port COM138 Info: Clock rate ~ 14MHz Error: Cant init box! Error: Programmer initialization is failed. please request u to give solution drivers also applied from latest setup of easy jtag but still cant found easy jtag box log of diag software Quote:
05-30-2019, 18:28 | #24 (permalink) | |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Quote:
The Following User Says Thank You to royalnasim For This Useful Post: |
05-30-2019, 19:04 | #25 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2287102 Status: Offline Thanks Meter: 119 | same problem to my easy jtag plus v2 after i install latest version can not open my easy jtag and my other jtag box affected can not open after install that latest version of easy jtag |
05-30-2019, 19:14 | #26 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: Ahmednagar,india Age: 40
Member: 471816 Status: Offline Sonork: 100.1623472 Thanks Meter: 57 | I have same problem solved Quote:
post pics Last edited by .:gsmXpert:.; 05-30-2019 at 19:23. | |
05-31-2019, 15:12 | #28 (permalink) | |
Member: 77443 Status: Offline Thanks Meter: 24 | problem solved probem solved in easy jtag ver 2 whenever new upadate come and problem occur like this tend press SHIFT KEY and run software and continue pressed until exe open thats all Quote:
08-12-2021, 02:28 | #29 (permalink) |
Crazy Poster Join Date: Mar 2011 Location: pilipines
Member: 1546592 Status: Offline Sonork: arr david12 Thanks Meter: 10 | same to me i face that problem.. how to solve....up up up up i tried all tricks above but same issue......all software open except to easy jtag plus software... |
08-12-2021, 02:45 | #30 (permalink) |
Member: 1546592 Status: Offline Sonork: arr david12 Thanks Meter: 10 | problem solve guys ....the problem is...please download and install latest emm plus software....your problem solve. easy jtag emmc plus 1.6.6.0 |
