02-01-2014, 23:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 1000439 Status: Offline Thanks Meter: 13 | n7100 dead boot repair error EasyJtag Suite ver.: 1.0.100.0 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). Successefuly connected to box on COM21 Box S/N: ..............., ,FW Ver.: 01.48 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : ............ , ver: 22 Successfully connected to box on COM21 Box S/N: ..................., ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1309 mV CMD Active Level:1845 mV EMMC CID 15010056545530304DF17B2876499FE3 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2066249289 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2066249289_20140100_0008.extcsd Done. |
02-02-2014, 00:14 | #2 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
02-02-2014, 14:50 | #3 (permalink) |
Member: 1000439 Status: Offline Thanks Meter: 13 | rom2 boot error write Rom1 main error I then pulled erase error capacity was around here 0 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB |
02-04-2014, 10:54 | #5 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
why you not check FAQ. there all info about voltage http://forum.gsmhosting.com/vbb/f672...nnect-1691327/ | |
02-04-2014, 17:06 | #6 (permalink) |
Member: 1000439 Status: Offline Thanks Meter: 13 | There was only problem was trying to device software I change the boot config warning and rpmb sizes of all data will be erased did eMMC then began to fail and the main assignment of a kind I reserve at boot time error says I |
