04-02-2014, 08:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | N7100 Dead Boot Repir Done Not Power Up CMD Active Level:1866 mV EMMC CID 15010056545530304DF1D5A83C728F03 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3584572530 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM0 Write Speed: 303 kB/s Done !!! Writing file...F:\soft ware\EasyJtag\Repair file\i9300\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_0 0200000.bin Successfully connected to box on COM3 Box S/N: ---------------------, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.107.3 Loading eMMC Addon Firmware... CMD Pullup Level:1278 mV CMD Active Level:1856 mV EMMC CID 15010056545530304DF1D5A83C728F03 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3584572530 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM0 Write Speed: 218 kB/s Done !!! Writing file...F:\soft ware\EasyJtag\Repair file\i9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000 _20000000.bin Successfully connected to box on COM3 Box S/N: ------------------, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.107.3 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (257 mV) too low , check cables etc.!!! CMD Active Level:1577 mV eMMC ACK Error ( Check Connection ) Warning: Error purging CDC device: 0 Writing file...F:\soft ware\EasyJtag\Repair file\i9300\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_0 0200000.bin Successfully connected to box on COM3 Box S/N: ------------------------, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.107.3 Loading eMMC Addon Firmware... CMD Pullup Level:1289 mV CMD Active Level:1845 mV EMMC CID 15010056545530304DF1D5A83C728F03 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3584572530 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM0 Write Speed: 216 kB/s Done !!! Writing file...F:\soft ware\EasyJtag\Repair file\i9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000 _20000000.bin Successfully connected to box on COM3 Box S/N: --------------------, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.107.3 Loading eMMC Addon Firmware... CMD Pullup Level:1268 mV CMD Active Level:1845 mV EMMC CID 15010056545530304DF1D5A83C728F03 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3584572530 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM0 Write Speed: 302 kB/s Done !!! Running:SAMSUNG: Smart Factory Reset + Format... Successfully connected to box on COM3 Box S/N: ----------------------, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.107.3 Loading eMMC Addon Firmware... CMD Pullup Level:1278 mV CMD Active Level:1835 mV EMMC CID 15010056545530304DF1D5A83C728F03 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3584572530 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: 呖さ䴰_3584572530_20140303_1307.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_3584572530_20140 302_1934.extcsd Running:Repair extCSD... Successfully connected to box on COM3 Box S/N: ---------------------, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.107.3 Loading eMMC Addon Firmware... CMD Pullup Level:1278 mV CMD Active Level:1866 mV EMMC CID 15010056545530304DF1D5A83C728F03 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3584572530 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! |
04-02-2014, 10:07 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
you are writing i9300 files as your log show here are the correct steps for repair phone factory format movinand restore / repair extcsd if you are repaing n7100 you must write rom2 boot partition size 2 mb and this file : EMMC_00000000_00200000.bin in user ''Rom1 main user data '' select size 512mb and write this files : N7100_Rom1_Alive_Dump_BN.bin Regards | |
The Following User Says Thank You to c_ahmad79 For This Useful Post: |
04-02-2014, 11:27 | #3 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
but product i9300 | |
04-04-2014, 15:59 | #7 (permalink) |
Freak Poster Join Date: Apr 2008 Location: CHINA Zhuhai Age: 40
Member: 760531 Status: Offline Sonork: [email protected] Thanks Meter: 58 | |
The Following User Says Thank You to 电源ic For This Useful Post: |
04-07-2014, 07:34 | #8 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | |
