03-03-2014, 22:53 | #1 (permalink) |
Insane Poster Join Date: Mar 2012 Location: in gsmhosting
Member: 1729567 Status: Offline Sonork: 100.1601036 Thanks Meter: 9 | N7100 emmc repair done what is next step i have glaxy note n7100 which came in dead condition i successfully repaired emmc with easy jtag here is log <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... CMD Pullup Level:1412 mV CMD Active Level:1691 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1650 mV EMMC CID 15010056545530304DF155DD64709FA9 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1440572528 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1440572528_20140202_0026.extcsd Done. <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1175 mV) too low , check cables etc.!!!</font> CMD Active Level:1639 mV EMMC CID 15010056545530304DF155DD64709FA9 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1440572528 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1440572528_20140202_0026.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1175 mV) too low , check cables etc.!!!</font> CMD Active Level:1629 mV EMMC CID 15010056545530304DF155DD64709FA9 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1440572528 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1440572528_20140202_0027.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:SAMSUNG: MoviNAND Format... <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1629 mV EMMC CID 15010056545530304DF155DD64709FA9 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1440572528 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1440572528_20140202_0031.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:Repair extCSD... <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1639 mV EMMC CID 15010056545530304DF155DD64709FA9 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1440572528 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1175 mV) too low , check cables etc.!!!</font> CMD Active Level:1639 mV EMMC CID 15010056545530304DF155DD64709FA9 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1440572528 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 201 kB/s Done !!! <br>Successfully connected to box on COM33<b> Box S/N: 0A0070107B61CCB6, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1629 mV EMMC CID 15010056545530304DF155DD64709FA9 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 1440572528 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 295 kB/s Done !!! AFTER PROCESS DONE NOW PHONE GO TO IN DOWNLOADING MODE [IMG][/IMG] when i put phone in recovery mode see pic [IMG][/IMG] i flashed phone with spt box after flash phone in same condition help me team now what is next step after repair emmc because i am new in jtag i hope that team will help me <me waiting> |
The Following User Says Thank You to BabuGsm For This Useful Post: |
03-03-2014, 23:25 | #4 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Quote:
ex: Z3x see here succes repair efs with Z3x http://forum.gsmhosting.com/vbb/f453...fs-ok-1679700/ | |
The Following User Says Thank You to mr.omphonx For This Useful Post: |
03-04-2014, 11:47 | #6 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Delphi XE2
Member: 1004812 Status: Offline Thanks Meter: 152 | Quote: thanks :d regard |
The Following User Says Thank You to (Drity KING)-DK For This Useful Post: |
03-04-2014, 12:32 | #7 (permalink) | |
Member: 1729567 Status: Offline Sonork: 100.1601036 Thanks Meter: 9 | Quote:
i do all step but in rom1 and rom2 use n7100 files | |
03-04-2014, 12:33 | #8 (permalink) | |
03-04-2014, 14:28 | #9 (permalink) |
Member: 1004812 Status: Offline Thanks Meter: 152 | my phone dead afther repair maybe i wrong this my log Running:SAMSUNG: Smart Factory Reset + Format... <br>Successfully connected to box on COM41<b> Box S/N: 02FFA0050E37D43B, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (721 mV) too low , check cables etc.!!!</font> CMD Active Level:1588 mV EMMC CID 15010056545530304DF1BA7A7C029FE7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 3128589314 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_3128589314_20140202_1821.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> <br>Successfully connected to box on COM41<b> Box S/N: 02FFA0050E37D43B, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (732 mV) too low , check cables etc.!!!</font> CMD Active Level:1588 mV EMMC CID 15010056545530304DF1BA7A7C029FE7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 3128589314 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_3128589314_20140202_1828.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... <br>Successfully connected to box on COM41<b> Box S/N: 02FFA0050E37D43B, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (732 mV) too low , check cables etc.!!!</font> CMD Active Level:1598 mV EMMC CID 15010056545530304DF1BA7A7C029FE7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 3128589314 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_3128589314_20140202_1834.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:SAMSUNG: MoviNAND Format... <br>Successfully connected to box on COM41<b> Box S/N: 02FFA0050E37D43B, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (732 mV) too low , check cables etc.!!!</font> CMD Active Level:1598 mV EMMC CID 15010056545530304DF1BA7A7C029FE7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 3128589314 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_3128589314_20140202_1838.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:Repair extCSD... <br>Successfully connected to box on COM41<b> Box S/N: 02FFA0050E37D43B, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (742 mV) too low , check cables etc.!!!</font> CMD Active Level:1608 mV EMMC CID 15010056545530304DF1BA7A7C029FE7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 3128589314 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! <br>Successfully connected to box on COM41<b> Box S/N: 02FFA0050E37D43B, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (721 mV) too low , check cables etc.!!!</font> CMD Active Level:1598 mV EMMC CID 15010056545530304DF1BA7A7C029FE7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 3128589314 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 212 kB/s Done !!! <br>Successfully connected to box on COM41<b> Box S/N: 02FFA0050E37D43B, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.102.3 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (721 mV) too low , check cables etc.!!!</font> CMD Active Level:1598 mV EMMC CID 15010056545530304DF1BA7A7C029FE7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 3128589314 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 295 kB/s Done !!! |
